XG-FULLHD: NEC XG HDMI 1.3 Input Card
Goto page Previous  1, 2, 3 ... 10, 11, 12 ... 21, 22, 23  Next
Posted: Thu Jun 05, 2008 12:01 am    Post subject:
JuzWerkz wrote:
Well on the very optimistic side, that means they'd start shipping today. Kal, are they "supposed to" ship in the order in which they were purchased?
Yup. Moome always processes the orders in the order that they're received. They all require some assembly/testing so he's never able to send out 100's in one day.
KennyG
Posted: Wed Jun 11, 2008 5:08 am    Post subject:
Yesterday I received my input card back from Jerry, with the new resistor values.
I want to thank him very much for his great work!
There is no doubt this card creates an image that is better than the previous DVI card...colors are more natural, test patterns are sharper (but it really doesn't translate to the video image)
It's just to bad the gamma curve is not setup for the XG, and this is where the new HDMI card falls down.
Jerry's mod has increased the amount of adjustment to an acceptable level, but unfortunately the spot on the gamma curve it adjusts is incorrect...at least on this XG.
This adjustment seems to work in the 15 to 30 IRE range, but does nothing below 15IRE on my pj.
When I adjust brightness to the correct level, I can see 2 ire,4 ire and below black, however the raster is lit up. When I set Brightness to a level that is just below lighting the rasters, everything below 15 ire is crushed. Using a test pattern with grayscale in 5 ire increments, 5,10,&15 are all the same. There is simply no shading.
To bad, this could have been a great product had Moome taken the time to actually look at the XG's gamma curve, and design this card for it. An adjustment centered on 15 ire, and spanning 10 ire on either side of that would have been what my pj needs.
As he has told me, this card is actually designed for the Sony, so I'm assuming it's needs are higher up the grayscale.
Is the card worth $450? That would depend on your budget, and what you expect out of this product.
For myself, I say yes it's worth it...the PQ has taken a step forward, and just looks "right".
Using a compromise, I can get better blacks with better shadow detail than with the DVI card. So I will buy the product and be happy...until someone takes a look at it, and can figure how to get it's adjustment to work about 10 ire lower into the grayscale.
I will be looking at this card on a pristine 110 within the next few days...once I see how that pj reacts I will post again.
gaber
Posted: Wed Jun 11, 2008 1:12 pm    Post subject:
For $450, that's just not acceptable. What is the refund policy on these cards for those of us who have already paid?
Gabe
dbaisey
Posted: Wed Jun 11, 2008 2:29 pm    Post subject:
Kenny,
Have you and Jerry shared the same results using a known source device that has the same settings?
I ask this because I have seen some HDMI Blu-ray players not do as well as others at their default but can get a bit more out of them using 'user settings' that allows brightness, contrast and even gamma corrections on the HDMI out. Im assusming they have them there for a reason but not all are created equal. Doug
RobertR
Posted: Wed Jun 11, 2008 9:58 pm    Post subject:
What does this mean, exactly? Did you have to send the card to someone else (Jerry) when you received it from Moome? How much extra did that cost?
Posted: Thu Jun 12, 2008 12:00 am    Post subject:
No, no... the wording on some of these posts is deceiving. Jerry and Kenny were testers of the new card and had pre-release versions so there was some back and forth to get some things ironed out.
One the card starts shipping (hopefully soon!) everyone who orders gets a final/complete version of the card that works as expected. The wrinkles have been ironed out so the versions that Moome will be shipping out will not require and work of course. That's the whole point of using testers.
energeezer
Posted: Thu Jun 12, 2008 12:51 am    Post subject:
RobertR
Posted: Thu Jun 12, 2008 1:48 am    Post subject:
sigh...I guess I'll wait then.
KennyG
Posted: Thu Jun 12, 2008 2:49 am    Post subject:
dbaisey wrote:
Kenny,
Hey Doug,
Jerry does not use a Sumsung 1200, so our sources are different.
In his screen shots on page 10, I note that I can see shading differences down to about 10 ire, which will also depend on his pj's brightness setting.
My Brightness is set first by test pattern, then using the Blu-Ray "From Hell" and it's few FTB shots...several within the first five minutes of the start.
At about three feet in front of my face, I expect to be able to wave my hand in front of my face, and NOT see my hand.
Many don't mind a little glow, but I never had it on any other XG I've owned, and don't expect it on this one.
As I said earlier, the XG110 that you took a look at when you were here, will be back within a couple days. I'm going to set it up in the HT and see if it gives the same results.
Still, this card IS a step up in all areas of image reproduction, so it does have several merits as is.
AND I'm not saying this couldn't be my pj. However, you have spent a full day with it, stated the setup was a good one, and it doesn't have but 140 hours on it since then. So I'm thinking it's more the card than my setup.
This second XG may tell a different story, we'll see.
JuzWerkz
Posted: Thu Jun 12, 2008 4:36 am    Post subject:
KennyG wrote:
It's just to bad the gamma curve is not setup for the XG, and this is where the new HDMI card falls down. Jerry's mod has increased the amount of adjustment to an acceptable level, but unfortunately the spot on the gamma curve it adjusts is incorrect...at least on this XG. This adjustment seems to work in the 15 to 30 IRE range, but does nothing below 15IRE on my pj.An adjustment centered on 15 ire, and spanning 10 ire on either side of that would have been what my pj needs.
Hey Jerry,
Since you changed the resistors on the card, have you looked at the circuit layout enough to know basically what's going on? Could you put potentiometers in there to move the gamma adjustment point? This seems rather analagous to the frequency adjustment on a parametric equalizer... Most users might not need this "added feature" that we could solder in, but if it would make Kenny happier with the card, I'm sure it would for other users as well. I've never looked at any gamma correction circuitry, but I have to believe it's some sort of signal filtration again akin to the parametric eq I brought up...
cj
KennyG
Posted: Fri Jun 13, 2008 2:36 am    Post subject:
JuzWerkz wrote:
Hey Jerry,
cj
EXACTLY!!!! Move the adjustment down the grayscale. It really doesn't have to be adjustable.
Tacky
Posted: Sat Jun 14, 2008 2:03 am    Post subject:
Hello all,
Long time reader, first time poster - Love the site Curt!!! and Moome, love your work with helping us CRT analogue die hards run modern digital formats.
I have recently purchased the FullHD HDMI input card for my new runco 991.
Unfortunately the room my projector is installed does not allow for full surround sound and therefore I don't have a receiver.
I will be using the analogue output of this card as the main output to two very very nice stereo studio monitor speakers.
Can anyone tell me if this input card will be able to output a muxed stereo signal from both DTS (and all its variants) and Dolby Digital (and all its variants)
Any input on this would be most useful.
Thank you
jarseneau
Posted: Sat Jun 14, 2008 5:36 am    Post subject:
KennyG wrote:
JuzWerkz wrote:
Hey Jerry,
cj
I've been out of town this week and thus the late response to this question.
Moome sent me another recommendation to change the range by increasing the voltage available in the gamma adjustment. There are some diodes in the path that put a limit on the max voltage when the pot is at full CCW (the lightest end of the range). Right now the voltage is 0 with the pot full CW and .39 at full CCW. I'll try to get the parts tomorrow and see what happens. Bwahahaha /mad scientist laugh
Jerry
KennyG
Posted: Sun Jun 15, 2008 2:09 am    Post subject:
jarseneau wrote:
KennyG wrote:
JuzWerkz wrote:
Hey Jerry,
cj
Jerry, if your going to increase voltage to gamma adjust, is this going to increase the amount of adjustment? (which it sounds like it will)
OR will this move the adjustment point down the grayscale??? (Which is what I'd like to see happen)
I think it has enough adjustment range, I just think it needs to start it's adjustment closer to black (maybe around 5-7 ire)
EDIT: or a little higher depending on the width of the adjustment...I would think the adjustment should stay out of the bottom few ire.
Tacky
Posted: Tue Jun 17, 2008 12:22 pm    Post subject:
Can anyone point me to the correct person to talk to regarding my question about audio above?
Also - any word on shipping?
I think the last post regarding shipping was early this month....
Can't wait to get my card and get it working!
Posted: Tue Jun 17, 2008 2:32 pm    Post subject:
I don't think it does this as I don't see how it could. I simply outputs over SPDIF whatever you feed it. So if it feed it a 2 channel stereo signal then that's what it'll output. Feed it 7.1 multichannel (lossy) audio then it'll spit that out over SPDIF. The card cannot take a 7.1 multichannel DTS/DD signal and downmix it to 2-channel. There's no card settings or switches to tell it to do that (versus just outputting 7.1). Otherwise how would it know what you want to do?
You need to set your source to 2 channel audio output or have the source downmix for you. The card just passes through what it sees.
Before someone else asks: The audio output is only for lossy multi-channel audio (ie: Dolby Digital/DTS) or lossless 2 channel audio. It can't take lossless multi-channel (Dolby Digital TrueHD/ DTS-HD Master Audio) and output over SPDIF as the SPDIF spec doesn't allow for such high bandwidth. See the FAQ in the first post of this thread for more info.
No word on shipping. Sorry. As soon as I know it'll be posted here.
jarseneau
Posted: Mon Jun 23, 2008 2:00 pm    Post subject:
Moome has been giving me some items to do to improve the gamma situation. At this point I am able to get the same results as shown in the 'review' post but now at my normal brightness setting of 60 rather than 80 to 90. I'll post some pics of the results tonight.
Update: I've been struggling with material that would show the gamma improvement. Part of the issue is getting the digital camera to capture as it looks in person. KennyG told me about the above difficult scene from Casino Royale where LeChifre is wearing a black suit layered with black shirt and tie with the main difference being the texture of each. The picture below was taken after improving gamma boost and with the projector set to reference black via test pattern.
Jerry
Billm
Posted: Tue Jul 01, 2008 1:03 am    Post subject:
I have just received my input card from Moome so
they are shipping. No chance to try it out for a few days.
Posted: Tue Jul 01, 2008 1:07 am    Post subject:
Excellent news! Thanks for posting!
JuzWerkz
Posted: Tue Jul 01, 2008 4:33 am    Post subject:
When I got home from work, I had a postcard in the mailbox telling me the post office had a package for me, but since no one was home, they did not deliver it. The sender was Moome. I will have to go to the post office tomorrow after work and pick it up. It will probably be the weekend before I have mine dialed in properly as well.
cj
Page 11 of 23
