Z-Photo
Joined: 07 Mar 2006 Posts: 2749 Location: Huntsville - Alabama
| Posted: Wed Apr 26, 2006 11:36 pm Post subject: |
Crap - forgot -
COLORED C-Elements (I got LOTs of extra clear C-Elements)
_________________ Engineer by Day
Photographer by Night
My Portfolio
Ile
| Posted: Thu Apr 27, 2006 12:21 pm Post subject: |
| Z-Photo wrote: | Crap - forgot -
COLORED C-Elements (I got LOTs of extra clear C-Elements) |
Newer heard of colored ones in 8" retros.
Z-Photo
| Posted: Thu Apr 27, 2006 1:22 pm Post subject: |
I have not seen or heard of them - The Zenith 1200 (Cine 8 Onyx) has them and the LC hardware is the same. The Lenses are basically the same - just different throw difference.
Pete
My Portfolio
Ile
| Posted: Thu Apr 27, 2006 6:58 pm Post subject: |
| Z-Photo wrote: | I have not seen or heard of them - The Zenith 1200 (Cine 8 Onyx) has them and the LC hardware is the same. The Lenses are basically the same - just different throw difference.
Pete | I have always thought Onyx have filters inside F1.18 lenses, because prochure mention only R/G filtered lenses.
Z-Photo
| Posted: Thu Apr 27, 2006 7:04 pm Post subject: |
interesting -
Kal - Dave
Where is the color elements on the 1200? LC or Lense?
My Portfolio
secstate
| Posted: Fri Apr 28, 2006 2:58 am Post subject: |
Based on this Kal's write up on Curt' site "Tinted (colour filtered) c-elements are used in the LC'ed assembly for the Red and Green lenses for more accurate colours. Other then the Cine series, all other 8" and 9" EM focusing Barcos are [SIC] use clear c-elements or clear glycol. Projectors without tinted glycol/c-elements tend to display red as red/orange and green as green/yellow." I would say it uses colored C Elements.
http://www.curtpalme.com/Zenith1200.htm
GREG1292
Z-Photo
| Posted: Sat Oct 13, 2007 1:59 am Post subject: |
Thats all :
Only issues occur with a BG(D) 808 (non s - 2 piece neckboard) - the neckboard wires are shorter and will not reach the 120 mhz neckboard. This is fixed by replacing the main board (not the most fun).
So - replace the sony tubes with the high res P16 and retain the 120 mhz neckboards - what a deal.
My Portfolio
bbfarmht
Joined: 27 May 2006 Posts: 1273 Location: Where the Mississippi runs east to west!!
| Posted: Sat Oct 13, 2007 2:22 am Post subject: |
Z was this a s model ? also what lenses did you use i was thinking of using hd 145 but Im not sure what would be compatible? how different is the ac mounting from the lc mounting?
GREG1292
| Posted: Sat Oct 13, 2007 12:14 pm Post subject: |
I'd forgotten about this thread. Two projectors of the same family to make a third, in Alabama. Why does this NOT surprise me
_________________ Chip
GREG1292
Z-Photo
| Posted: Thu Oct 25, 2007 12:55 pm Post subject: |
I ran it for quite a bit without a shim. The engineer in me would require a permanent fix.
My Portfolio
| Posted: Thu Oct 25, 2007 1:44 pm Post subject: |
Just like a CRT projector, the original thread on the forum will never die!
GREG1292
| Posted: Thu Nov 01, 2007 3:08 am Post subject: |
Z or Curt my Retro is on the way from Curt and I have all the parts needed for the conversion but I might be able to mount it without doing the switch and installing the HD215 and be done. My question is that the Retro comes with the contrast modulation board. Do I just pull out the port 3 board on the G808S and install it or is it morE complicated than that
_________________ https://www.avforums.com/threads/worldwide-crt-projector-shootout.2000957/page-87
Z-Photo
| Posted: Thu Nov 01, 2007 1:33 pm Post subject: |
I have never messed with Barco Contrast modulation board. MadMrH would be your best bet for infor on that.
My Portfolio
Moose
| Posted: Thu Nov 01, 2007 2:58 pm Post subject: |
I have a set of instructions on how to install the contrast modulation board written by MadMrH, if I could only find them. Look for the instructions posted by MadMrH on AVS - I got them there.
_________________ In the real world, I am alan halvorson, King of the Wild Frontier and Swell Guy.
GREG1292
GREG1292
| Posted: Wed Nov 07, 2007 6:17 am Post subject: Recieved Retro |
I just got the retro from curt and the tubes are pristine. I have a setup that would allow me to use the whole retro unit but I am having trouble moving the red up or down. Anyone know a trick to do this
I have figured out by removing the convergence tray that I can move left to right but am stump by up and down.
I have all the parts to do the conversion on my 808s but would like to avoid if possible.
Thanks Greg
Z-Photo
| Posted: Wed Nov 07, 2007 2:17 pm Post subject: |
On the retro units the tubes are fixed (some toe in adjustment).
To move the Red/Blue vertical use the pots.
My Portfolio
