MikeEby
| Posted: Sun Jun 24, 2007 3:29 am Post subject: EDID Update |
I bought a moome card probably almost a year ago for my NEC XG 1351 It has never worked really right with my Toshiba HD-DVD Player on the DVI Port. BTW it works great on componet. But I think I will soon want to try a PS3 or BR player and for those the digital path will be required. Could I send the card back to have it updated?
Thanks!
moome
| Posted: Tue Jun 26, 2007 3:02 pm Post subject: Re: EDID Update |
[quote="MikeEby"]I bought a moome card probably almost a year ago for my NEC XG 1351 It has never worked really right with my Toshiba HD-DVD Player on the DVI Port. BTW it works great on componet. But I think I will soon want to try a PS3 or BR player and for those the digital path will be required. Could I send the card back to have it updated?
Thanks!
Mike[/quote
yes! or you can send $3.9 postage to cm84006@cm.nctu.edu.tw, we will send you new EDID to update!
Bourrin
| Posted: Sat Jul 07, 2007 6:45 pm Post subject: |
I've a moome card too (on my Marquee 8500), it's 1 year too and soon I'll buy a PS3, and... what's style of problem can I've with a PS3 ?
And, what means EDID ? And what's the update ? (a new chip to put on the card?)
Thanks.
David
| Posted: Sat Jul 07, 2007 11:33 pm Post subject: |
Yes, it's a new chip - replacing the current EDID chip.
You have to be able to solder surface mount devices. Or send your card to Moome for rework.
Bourrin
| Posted: Sat Jul 07, 2007 11:49 pm Post subject: |
Ok, thank you.
And what's the "problem" (if there are) if I'm playing a Bluray with a PS3 (1080p) ?
kal Forum Administrator
Joust
TV/Projector: Marquee 8501LC
| Posted: Fri Jul 13, 2007 6:08 pm Post subject: |
keep cost down.
In our capitalist society, Money talks.
Us cheapskates learn how to solder SMT.
disking
Joined: 12 Jul 2007 Posts: 9 Location: London Ontario Canada
| Posted: Sun Sep 02, 2007 5:52 pm Post subject: |
I can reprogram all flavors of Moome cards via the HDMI or DVI port.
So there is no need to replace the chip.
I am willing to do this for $7.50 plus return postage.
Graham
kschmit2
| Posted: Mon Sep 03, 2007 6:26 am Post subject: |
| disking wrote: | I can reprogram all flavors of Moome cards via the HDMI or DVI port.
Graham |
How do you make sure the second block in the E-EDID doesn't get touched?
disking
| Posted: Mon Sep 03, 2007 3:04 pm Post subject: |
I can reprogram all of the chip or just part of it and make a new checksum.
Graham
JohnHWman
Joined: 15 May 2007 Posts: 215 Location: France - Grenoble
TV/Projector: Sony VPH-G90U (one unit for me, four others units repaired and sold)
| Posted: Mon Sep 03, 2007 5:44 pm Post subject: |
Hi Graham,
What software do you use to reprogram EDID through DVI or HDMI port ?
Could be usefull for me too...
John
_________________ Home theater enthusiast for over 20 years !
My dedicated HT room !
hunt
| Posted: Fri Sep 21, 2007 6:09 pm Post subject: |
I have the card for an xg1352. How do I know which IC needs to be replaced?
Eric
| Posted: Fri Sep 21, 2007 6:31 pm Post subject: |
| JohnHWman wrote: | Hi Graham,
John |
My buddy Arli has the software. You can do it through the video card on your computer. I've asked moome to send me an updated file to program to my ISS board but he has not done it.
I think there needs to be a solution to be able to program yourself from your computer. This way, moome could just email out an updated file to everyone to fix compatibility issues.
My 2 cents.
Cliff
JustGreg
| Posted: Fri Sep 21, 2007 6:51 pm Post subject: |
For those of you with HTPC's, you might want to grab a free copy of Monitor Asset Manager here
http://www.entechtaiwan.net/util/moninfo.shtm
I just got it here at work and played with it a little but I'm going to get it on the laptop at home, open a serial connection to the Marquee with moome v1.0, blank the laptop monitor, and see if the program can't burrow into the moome. I doubt it but we'll see.
Greg
_________________ Greg
JohnHWman
| Posted: Fri Sep 21, 2007 7:18 pm Post subject: |
As far as I know, MonInfo tool can't write EDID blocks. It just read them and translate them in a text file.
Cliff, what is the software name that you have to reprogram EDID ?
John
Clarence
| Posted: Fri Sep 21, 2007 7:29 pm Post subject: |
This is interesting:
http://www.hometheaterspot.com/fusionbb/showpost.php?post/828013/
| craigr wrote: | | I think there may be a free software program that you can use to reprogram EDID chips by plugging the Furry into a computer's DVI output. You could then set the Furry's EDID table to allow for only 1080i and the 480s. If I get a second I'll try and find the software package. |
http://hardware.mcse.ms/archive53-2004-7-48432.html
| hardware.mcse.ms wrote: | To upload your new EDID AFTER triple checking everything (I have no idea what will happen if you upload a bum EDID to your monitor, and I don't wanna find out), boot the DDCW floppy again.
Then enter:
DDCW -m 1 -f FILENAME.TXT
Where FILENAME is your modded EDID. |
http://www.viewsonic.com/support/drivers2.htm
"Firmware / EDID Update Utility" (for specific Viewsonic displays only?)
EDID.EXE
Utility program to read EDID data stream for PnP Windows® 95/98/Me/2000/XP
(4.21MB 7/11/2002)
http://www.vesa.org/public/EEDIDguideV1.pdf
| Description: |
 Download |
| Filename: |
DVI_Recover.zip |
| Filesize: |
353.78 KB |
| Downloaded: |
2605 Time(s) |
JustGreg
| Posted: Fri Sep 21, 2007 7:31 pm Post subject: |
| JohnHWman wrote: | As far as I know, MonInfo tool can't write EDID blocks. It just read them and translate them in a text file.
John |
Correct John..it can't reprogram. I didn't mean to imply that and I apologize. (Sometimes I think and write in hyroglyphics)
One interesting thing I stumbled across, which I'm sure is general knowledge to others, is that Lumagen produces and distributes regular updates to their firmware including EDID. Of course if you have additional EDID's in the chain that aren't correct, then that nulls the coolness of owning a Lumagen. I'll keep digging for EDID authoring/writing/etc. Moome must write his own custom variations of version 1.3 EDID's.
Greg
Clarence
| Posted: Fri Sep 21, 2007 7:44 pm Post subject: |
EDID Writer (attached)
from http://www.geocities.com/jgeneedid/?200721#EDID_Repository
Disclaimer: I know nothing about any of this stuff, don't go zapping your EDID. I just enjoy the thrill of the hunt and learning while googling.
| Description: |
 Download |
| Filename: |
EDID_Writer.zip |
| Filesize: |
132.51 KB |
| Downloaded: |
3311 Time(s) |
disking
| Posted: Fri Sep 21, 2007 8:20 pm Post subject: |
I use a program called pony prog to write to the EDID chip.
Graham
