Goto page Previous  1, 2, 3 ... 116, 117, 118 ... 126, 127, 128  Next
Posted: Sun May 28, 2017 12:15 am    Post subject:
May need to be brighter
gregstv
Posted: Sun May 28, 2017 1:05 am    Post subject:
A few more from planet earth 2 4K version
 Filesize:  371.9 KB
 Viewed:  9487 Time(s)
 Filesize:  447.92 KB
 Filesize:  429.07 KB
gregstv
Posted: Sun May 28, 2017 1:10 am    Post subject:
mp20748 wrote:
gregstv wrote:
Also these are from Blu-ray. I will do the same shots using the 4K version on the Barco tonight.
Oh, can you say if you notice an improvement when using 4K disk over the 1080P Blu Rays?
I'm playing with this Oblivion Blu Ray and may take a few more when it gets darker out. Right now there's too much light in the room. These are really quick shots and of course NO enhancements from me
I think the 4K has better edge detail. It seems to be finer making the edges look a little sharper.
These 2 shots of Oblivion look really good.
Posted: Sun May 28, 2017 1:24 am    Post subject:
I was told something like those results would happen when using a good 4K source down scaled to 1080P.
And on those two shots. That disk is loaded with various ranges of finer detail material. I did touch up on center focus this time, but when I get back to that disk, it will be when I've really dialed things in better. Right now my setup is still far from being where it should be. But I think it's a perfect performance disk, it has a ton of really defined low light and otherwise great image detail. My video chain sucks it all up very well.. Mr. Green .. I just need to get the display to compliment and that will happen.
Posted: Sun May 28, 2017 7:48 pm    Post subject:
Can someone post the screencap of the two frames I have posted here?
El Duderino
Posted: Sun May 28, 2017 10:43 pm    Post subject:
Posted: Sun May 28, 2017 10:52 pm    Post subject:
Thanks Dude, I'll get my better camera on them tomorrow.
Posted: Thu Jun 01, 2017 2:44 am    Post subject:
thewolfman
Posted: Thu Jun 01, 2017 10:40 am    Post subject:
Envisioning your images right now as you made a good series of pix and wonder if any special boards have been used?
Anyway, number six, counted from the bottom, and the close up of one of the masters in command looks almost 3D. Must be good to see irl.
Keep up the good work. I'll join some day too.
Posted: Thu Jun 01, 2017 11:17 am    Post subject:
It's board level work only, with me not doing anything to the projector at all. Just pop in a change and then noticed a difference in the image, and the need to finish the zone and outer focus on the setup. The center though not really dialed in either, really reveals a lot on the screen.
The shots look good, but what's on the screen is beyond expectations. And I'm only half way there, considering the setup has not been touched, only a quick eye-ball color balance after the board changes.
The 3D look I believe is the result of a more optimized video chain. What I see on the screen is amazing depth. I just think I'm seeing the Two Dimensional effect of properly resolving 1080P.
Anyway, I still have to wrap this up on the boards and then dial things in better. It's then I'm going to release the beast on the ceiling.
We'll talk..Wink
Posted: Thu Jun 01, 2017 11:45 pm    Post subject:
I'll work on the focus/stig this weekend, with hopes of the probe being accurate enough to get me a good color balance.
Posted: Fri Jun 02, 2017 10:25 am    Post subject:
Posted: Fri Jun 02, 2017 2:59 pm    Post subject:
Hmmm
I guess I have to remind you guys...........if you don't Blend, you Suck! LOL
imgurl
image url
image share
print screen windows 7
Amazing detail and effortless light output with contrast in the low 50's. And 160 degrees viewing angle on Snowmatte 1.0 fabric.
Two Unmodded Marquee 9500s will blow the t*ts off of any single CRT projector on earth, or Mars!
Posted: Sat Jun 03, 2017 12:16 am    Post subject:
Those are wow images.
gregstv
Posted: Sat Jun 03, 2017 6:47 am    Post subject:
Did some work on the 1292 today. Everyone seems to have this movie some I did some shot.
 Filesize:  212.08 KB
 Viewed:  9135 Time(s)
 Filesize:  204.8 KB
 Filesize:  246.99 KB
 Filesize:  224.52 KB
 Filesize:  281.33 KB
 Filesize:  243.09 KB
 Filesize:  223.22 KB
 Filesize:  341.92 KB
 Filesize:  430.84 KB
gregstv
Posted: Sat Jun 03, 2017 6:57 am    Post subject:
A few more
 Filesize:  233.16 KB
 Viewed:  9132 Time(s)
 Filesize:  208.09 KB
 Filesize:  210.84 KB
 Filesize:  192.02 KB
 Filesize:  198.87 KB
 Filesize:  313.33 KB
Posted: Sat Jun 03, 2017 8:26 am    Post subject:
They look great. What resolution?
gregstv
Posted: Sat Jun 03, 2017 8:33 am    Post subject:
1080p@48
Posted: Sat Jun 03, 2017 9:15 am    Post subject:
You certainly have that working well. When you compare the 1292 to the 919 whats the difference.
gregstv
Posted: Sat Jun 03, 2017 10:54 am    Post subject:
The 919 is sharper and has better depth. Its very3D. Its at the stage that I cant see anywhere I need to make more improvements. Very happy with it.
I haven't touched the VNB or driver board on the tubes of the 1292 yet. Also need to do a full ASTIG on green and blue.into. It has a lot of potential and is much better than when I started.
All the switching circuits has been bypassed. I now have semi ridged coax running to each neck board. The picture has very little noise in it now. Its a fun project.
Page 117 of 128
