Goto page Previous  1, 2, 3 ... 97, 98, 99 ... 126, 127, 128  Next
thewolfman
Posted: Fri Jul 08, 2016 8:54 pm    Post subject:
greg9518lc wrote:
thewolfman wrote:
greg9518lc wrote:
I felt it was important to have some recent LCP shots as I am
mesmerized by the clarity of these shots by a crt projector. Owning a lug machine it is a different
picture than the LCP and to be honest I prefer lugs over lcp and these are the shots my projector
must beat before the Meet in October vs the JVC so to me these shots are relevent and the smpte
shots and pixel because if you can beat those you have one heck of an image. Oh and a lcp machine
is on my wishlist!!!!!!!!!!!!!!!!!!!!!!
Ok, I understand your motives better now. You should reveal what your intentions are and not leve the reader clueless. Hence my question.
Good luck with the meet.
Getting there slowly but we will be ready on our end for sure....
"Our end" will be ready for you too.
Posted: Fri Jul 08, 2016 9:08 pm    Post subject:
I also prefer LUG's, but that was not my choice most of last year.
The LCP is a good CRT for general sharpness and over all brightness. The LUG produces a more fluid image, while at the same time being much better with background and overall image detail.
I would call the LUG to CRT for the best in 2D (depth, transparency) image performance. So it would be the absolute best CRT for native 1920X1080P image performance. But the LUG performs best at a lower drive level.
It'll be hard for me to go back to LCP's after experiencing the better virtues of the LUG CRT.
My setup at the time has a green LCP, with RED and BLUE being LUG. That allowed me to learn even more about the two tube sets, to include to see in direct comparison where the LCP falls short in comparison.
We've been tailoring a set of neck boards as being a perfect match for the LUG tube, and I'll try and demonstrate how well this combination would be different later this evening and do so even using that LCP tube on green. I plan to take a few fine resolution shots from a few Blu Rays, in hopes of showing in the shots something that's hard to see without this setup.
I got to focus the green LCP first. So for anyone wanting to show how good your setup is, these shots (2) would make a perfect reference and even a cheap camera can capture. It's really that good.
Posted: Sat Jul 09, 2016 11:51 am    Post subject:
Below is a few quick shots, taking with everything as-is. The Green CRT has still not had anything done to it's magnetics, with only center focus done on both lens and static. Color balance is also way off, but I chose to take these shots to show what it looks like before I do a little something to it later and get back with a few more shots using only my Iphone as camera.
That would be a good time to post shots, but let me tell you up front, they will all be HIGH DEF shots (no closeups) that will be showing great clarity in the background of the image. And still I will not have the finer tuning done to the projector.
greg9518lc
Posted: Sat Jul 23, 2016 12:24 am    Post subject:
moved
greg9518lc
Posted: Sat Jul 23, 2016 12:49 am    Post subject:
moved
Posted: Fri Aug 05, 2016 11:01 am    Post subject:
I still post shots to see what they look like on a forum. These shots are from my Simulator Video chain Mods that I've been working on. A lot of things are different about them, considering they have to be able maintain reasonable spot size at higher gain levels, to include not loose low level detail because of their higher refresh rate (104) where both bandwidth and Stereoscopic imaging (layers) will diminish low end detail. Projector far from being setup, but it still allows me to see what I need to see. These are not for - for commercial use only
Posted: Fri Aug 05, 2016 2:43 pm    Post subject:
Convergence! Blue is way off to the left. Everyone has halos and look like angels. Wink
Posted: Fri Aug 05, 2016 5:39 pm    Post subject:
Yeah, that camera sucks and the contrast is high. I'll redo a few later
ElTopo
Posted: Fri Aug 05, 2016 5:40 pm    Post subject:
Concussion
 Filesize:  130.59 KB
 Viewed:  6795 Time(s)
Barco Cine 9 the one and only
Posted: Fri Aug 05, 2016 5:58 pm    Post subject:
Good shot there..Thumbs Up
ElTopo
Posted: Sat Aug 06, 2016 4:11 pm    Post subject:
Concussion
 Filesize:  366.01 KB
 Viewed:  6733 Time(s)
 Filesize:  334.4 KB
greg9518lc
Posted: Sun Aug 07, 2016 10:18 pm    Post subject:
moved
Posted: Tue Aug 09, 2016 12:22 am    Post subject:
Okay Ladies.......
This thread is boring me to death. Some of you need to take a photography class.
If you don't Blend then you Suck!!!!!!
Oh, and the sports stuff is from my $30 Ebay terrestrial tuner.
Any questions?
Posted: Tue Aug 09, 2016 1:37 am    Post subject:
It's not the camera. The blue convergence is way off to the right.
greg9518lc
Posted: Tue Aug 09, 2016 2:20 am    Post subject:
Tim no questions here but I will stick with my 110" screen sitting 10ft back😀
I in no way have a room that big sorry my new boards bore you guess I need
to kick it up a notch👀
ElTopo
Posted: Tue Aug 09, 2016 7:47 am    Post subject:
What resolution to each Tim ?
Posted: Tue Aug 09, 2016 3:05 pm    Post subject:
Look at the display on the processor. 1080P/60 for each.
jbltecnicspro
Posted: Tue Aug 09, 2016 5:19 pm    Post subject:
What size is that screen? Looks beautiful
Posted: Wed Aug 10, 2016 3:03 am    Post subject:
Guys
107" wide, nine feet. Stewart Snowmatte 1.0 surface.
The most gorgeous CRT projected image on the planet.
These are Marquee 9500s I retubed in 2005, and have logged maybe 5000 hours since.
Contrast is 53, and I go snow-blind on any advert that is white background.
Any questions?
Posted: Wed Aug 10, 2016 3:10 am    Post subject:
Hello
1280 x 1024p to each projector.
Page 98 of 128
