Barco 1209s - No Picture
Hulio
Posted: Fri Jun 28, 2024 8:39 pm    Post subject:
Yes, while projector is off, disconnect one tube HV cable from the splitter and start the projector with two tubes only. Disconnect one by one each tube, and if the machine is starting it means the disconnected tube is bad.
Rittberg
Posted: Fri Jun 28, 2024 11:03 pm    Post subject:
Thanks Hulio,
I just checked the tubes according to you instructions - no picture .
Thanks , Any other ideas ?
bluemoonhu
Posted: Sat Jun 29, 2024 3:28 am    Post subject:
If two tubes are disconnected at the same time to check the other tube, it will be easier to find the problem
Rittberg
Posted: Sat Jun 29, 2024 8:14 am    Post subject:
Dear Friends,
After all the trials in the last days with the help of the forum members and with the endless spare parts purchased and received, I was not able to overcome the problem, so I decided to go ahead and switch to a new digital projector.
Thanks for the great forum.
