Barco C7 image jitter
bluemoonhu
Posted: Sat Jun 17, 2023 12:42 am    Post subject: Barco C7 image jitter
P11
P676
 Filesize:  296.41 KB
 Viewed:  4461 Time(s)
bluemoonhu
Posted: Sat Jun 17, 2023 12:44 am    Post subject: Barco C7 image jitter
P12
New P676 Potentiometer
 Filesize:  151.75 KB
 Viewed:  4460 Time(s)
bluemoonhu
Posted: Sat Jun 17, 2023 3:45 am    Post subject: Barco C7 image jitter
After replacing the P676 Potentiometer, the image looks normal
 Filesize:  148.41 KB
 Viewed:  4451 Time(s)
Hulio
Posted: Sat Jun 17, 2023 9:15 am    Post subject:
Well done. Yeah, those trimpots loose impedance over time. Because of age, or that red sealing varnish they put on.
bluemoonhu
Posted: Sat Jun 17, 2023 9:23 am    Post subject:
Unfortunately, the problem of image rolling was not solved after the P676 Potentiometer was replaced. I need to repeatedly adjust the P676 Potentiometer every time to obtain a stable image. It seems that there are other problems in the deflection board.
Hulio
Posted: Sat Jun 17, 2023 11:56 am    Post subject:
If the new pot is not stable neither, replace elco C716 (10uF 35V).
bluemoonhu
Posted: Sat Jun 17, 2023 2:24 pm    Post subject: Barco C7 image jitter
[quote="Hulio"]If the new pot is not stable neither, replace elco C716 (10uF 35V).[/quot
before, I replaced all the capacitors on the deflection board!
bluemoonhu
Posted: Sat Jun 17, 2023 2:29 pm    Post subject:
C716 has been replaced by a new capacitor(10uf 50v)too
bluemoonhu
Posted: Sat Jun 17, 2023 2:42 pm    Post subject:
I replaced the Electrolytic capacitor on the deflection board.
Hulio
Posted: Sat Jun 17, 2023 2:50 pm    Post subject:
Ok. I see in the schematics that C715 can affect the V hold too (blue rectangular cap, closer to the trimpot). The value is 0,1uF 63V.
bluemoonhu
Posted: Sat Jun 17, 2023 3:04 pm    Post subject:
Okay, there's a high possibility of this
bluemoonhu
Posted: Sun Jun 18, 2023 2:58 am    Post subject: Barco C7 image jitter
pic13
 Filesize:  106.17 KB
 Viewed:  4396 Time(s)
bluemoonhu
Posted: Sun Jun 18, 2023 3:02 am    Post subject:
The C715 has been replaced, and the problem seems to have been resolved.
Thanks!
Hulio
Posted: Sun Jun 18, 2023 7:50 am    Post subject:
Alright, well done.
bluemoonhu
Posted: Sun Jun 18, 2023 10:48 am    Post subject:
The image did not roll when turned on, but there was a slight vertical misalignment when changing the signal source. This should not be a problem, everything else is very good。
Page 4 of 4
