Barco C7 image jitter
bluemoonhu
Posted: Wed Jun 14, 2023 2:55 am    Post subject: Barco C7 image jitter
pic2
 Filesize:  91.56 KB
 Viewed:  7391 Time(s)
bluemoonhu
Posted: Wed Jun 14, 2023 2:57 am    Post subject: Barco C7 image jitter
pic3
 Filesize:  91.88 KB
 Viewed:  7389 Time(s)
bluemoonhu
Posted: Wed Jun 14, 2023 2:58 am    Post subject: Barco C7 image jitter
pic4
 Filesize:  90.73 KB
 Viewed:  7388 Time(s)
Hulio
Posted: Thu Jun 15, 2023 7:53 am    Post subject:
Any I2C error ? Look at I2C diagnostics in the service menu.
bluemoonhu
Posted: Thu Jun 15, 2023 12:11 pm    Post subject:
Ok
Which board in the cine7 is used to control the grille and geometric adjustments?
bluemoonhu
Posted: Thu Jun 15, 2023 1:19 pm    Post subject: Barco C7 image jitter
pic5
 Filesize:  77.42 KB
 Viewed:  7335 Time(s)
bluemoonhu
Posted: Thu Jun 15, 2023 1:20 pm    Post subject: Barco C7 image jitter
pic6
 Filesize:  71.6 KB
 Viewed:  7334 Time(s)
bluemoonhu
Posted: Thu Jun 15, 2023 1:24 pm    Post subject:
Now, the geometric grid cannot be adjusted
Hulio
Posted: Thu Jun 15, 2023 9:27 pm    Post subject:
Ok, no I2C errors thus.
The convergence driver board R762454 generates the horizontal and vertical waveforms. Try to replace it and give it a try.
bluemoonhu
Posted: Fri Jun 16, 2023 2:04 am    Post subject:
OK!Thanks!
bluemoonhu
Posted: Fri Jun 16, 2023 11:31 am    Post subject:
I observed the driver board and found a pile of black layers on it. I don't know what it is? Will it affect functionality?
bluemoonhu
Posted: Fri Jun 16, 2023 11:32 am    Post subject: Barco C7 image jitter
pic7
 Filesize:  224.62 KB
 Viewed:  7258 Time(s)
bluemoonhu
Posted: Fri Jun 16, 2023 11:42 am    Post subject: Barco C7 image jitter
pic8
 Filesize:  175.22 KB
 Viewed:  7250 Time(s)
bluemoonhu
Posted: Fri Jun 16, 2023 12:10 pm    Post subject: Barco C7 image jitter
After cleaning, was the above line corroded and disconnected?
pic9
 Filesize:  150.65 KB
 Viewed:  7249 Time(s)
bluemoonhu
Posted: Fri Jun 16, 2023 12:53 pm    Post subject: Barco C7 image jitter
Be sure this line is broken
pic10
 Filesize:  110.46 KB
 Viewed:  7246 Time(s)
Hulio
Posted: Fri Jun 16, 2023 2:38 pm    Post subject:
Could be, just replace it to be sure.
bluemoonhu
Posted: Fri Jun 16, 2023 3:35 pm    Post subject:
It is obvious that the driver board is faulty. I tried to connect the disconnected wire, but it took a long time and failed. I had to replace it with another driver board.
Hulio
Posted: Fri Jun 16, 2023 5:41 pm    Post subject:
Yes, that was the advice too. So what's the outcome after replacing de conv. driver board ? Are the grid lines still distorted ?
bluemoonhu
Posted: Sat Jun 17, 2023 12:14 am    Post subject:
Yes, the grid lines are normal, and the geometric adjustments are normal
Thanks!
bluemoonhu
Posted: Sat Jun 17, 2023 12:22 am    Post subject:
Every time I turn on the cine7, the image will roll. The P676 Potentiometer may soon fail. I'm going to replace it.
Page 3 of 4
