Barco C7 image jitter
Goto page 1, 2, 3, 4  Next
bluemoonhu
Posted: Tue May 16, 2023 1:04 am    Post subject: Barco C7 image jitter
I got a C7 produced in 2002, but after turning it on, the image jittered and I don't know why. I think some potentiometer needs to be adjusted, but I don't know how to do it. Thank you all!
Posted: Tue May 16, 2023 1:32 pm    Post subject:
I've never heard of a Barco C7. Do you have a link or more details?
Closest I can find are these Barco LED tiles: https://www.barco.com/en/support/c7
bluemoonhu
Posted: Tue May 16, 2023 1:38 pm    Post subject:
Sorry!Barco cine7--http://www.curtpalme.com/Barco701.shtm
Posted: Tue May 16, 2023 1:56 pm    Post subject:
Ah, ok, so a Barco Cine 7 CRT projector.
Does it jitter when showing a signal? If there's no signal then (if I remember correctly) the image can / will jitter as it's trying to lock on to a signal.
bluemoonhu
Posted: Tue May 16, 2023 2:11 pm    Post subject:
Regardless of whether the signal is input or not, the image will jitter. I have a short video, but I can't upload it
Posted: Tue May 16, 2023 2:14 pm    Post subject:
Upload the video to one of the various free image/video hosting services (imgur, youtube, etc) and link to it.
Posted: Tue May 16, 2023 3:09 pm    Post subject:
What source are you feeding it and which input are you using?
bluemoonhu
Posted: Tue May 16, 2023 3:31 pm    Post subject:
S-video
Posted: Wed May 17, 2023 2:07 am    Post subject:
Link to a video please? Jitter can mean about 10 different things..
bluemoonhu
Posted: Wed May 17, 2023 4:50 am    Post subject: Barco cine 7 issue
Hi Curt ,I can only upload the video through email, Please check your email。Thanks!
Hulio
Posted: Wed May 17, 2023 10:28 am    Post subject:
Since we know very little about the video path you are using, here some easy things to check first, before you start tweaking pots or swapping boards:
Firstly, on a Cine 7, you have to configure port 2 to use S-video signals. With the video active, press ADJ on your IR remote, service menus, random access, selected source, picture tuning, port 2. Now, pressing enter each time, will let you toggle between Video an S-video. Make sure you choose S-video, and press ADJ again to go out of the menu. See if your image is jitter free now...
Secondly, maybe your line multiplier should be active. Press ADJ, random access, picture tuning (here you might set the sync to slow), line multiplier. Pressing enter will toggle between ON and OFF. Give it a try.
Posted: Wed May 17, 2023 12:18 pm    Post subject: Re: Barco cine 7 issue
Why can’t you use any of the free video or file hosting services available on the internet? There are literally hundreds if not thousands available. Examples: YouTube, Imgur, Instagram, Vimeo, Twitch, Google Drive, Facebook, Twitter, etc. To name a few. If you have access to the internet as you do to be able to post here, you would have access to at least one of these free services.
bluemoonhu
Posted: Wed May 17, 2023 12:35 pm    Post subject: Re: Barco cine 7 issue
Sorry! I cannot obtain the websites you mentioned.
bluemoonhu
Posted: Wed May 17, 2023 9:43 pm    Post subject: Re: Barco cine 7 issue
https://youtu.be/ghFN64wpliU
Can you see the video?
Posted: Wed May 17, 2023 10:39 pm    Post subject: Re: Barco cine 7 issue
Yup. I don't have anything to add however as to what the issue may be.
Posted: Wed May 17, 2023 11:56 pm    Post subject:
I've never seen that either. It looks like the H sync is temporarily failing, which could be a problem on the RGB input board or the deflection board.
I was hoping the picture would jump up and down, indicating a vertical problem, but that's not the case here.
bluemoonhu
Posted: Thu May 18, 2023 12:58 am    Post subject:
If there is no signal input, the displayed image will show such jitter after starting up,
If the image is adjusted to a grid state, the picture would jump up and down。
bluemoonhu
Posted: Thu May 18, 2023 1:09 am    Post subject:
When selecting a signal source on the remote (between key 2 and 4,with the input signal corresponding to 1080i for key 4), the machine hangs up and displays "SF" fault, deflection board issue, then there will be no any images
bluemoonhu
Posted: Thu May 18, 2023 1:11 am    Post subject: Barco C7 image jitter
The deflection board
 Filesize:  162.35 KB
 Viewed:  11894 Time(s)
bluemoonhu
Posted: Thu May 18, 2023 1:12 am    Post subject: Barco C7 image jitter
 Filesize:  120.49 KB
 Viewed:  11893 Time(s)
Page 1 of 4
