Barco 708MM “HOLD DOWN EHT” fault
Posted: Thu May 26, 2022 4:06 pm    Post subject:
I have no idea, sorry!
Hulio
Posted: Sat May 28, 2022 6:02 pm    Post subject:
Hu, let's try to reanimate the C7 (it is a bit better then a Vision 708).
Firstly, what makes you think his deflection board was broken ? Does the projector came without deflection board, the previous owner told you so, or you suspect that ?
bluemoonhu
Posted: Sun May 29, 2022 12:18 am    Post subject:
Last week, I bought the C7, which is a faulty machine,I hope I can repair it。
Next, I started C7. as a result, three tubes could not be light up ,and the LED fault light in front of the machine flashed repeatedly,after a few seconds, the machine automatically stopped.
The red fault LED points to SF, which means that the deflection board is faulty. in order to reanimate the C7,
I removed the deflection board from my 708 and installed it in the C7,previously, the 708 could run normally.。。。 Unfortunately, the fault remains the same。
When I removed the deflection board from the C7 and reinstalled it in the 708, the red fault LED points to SF too, so, I think the deflection board in 708 was broken .
Thanks!
bluemoonhu
Posted: Sun May 29, 2022 12:24 am    Post subject: Barco 708MM “HOLD DOWN EHT” fault
after starting up C7,the red LED fault light flashes repeatedly
 Filesize:  46.82 KB
 Viewed:  2712 Time(s)
bluemoonhu
Posted: Sun May 29, 2022 12:36 am    Post subject: Barco 708MM “HOLD DOWN EHT” fault
 Filesize:  46.16 KB
 Viewed:  2710 Time(s)
Hulio
Posted: Sun May 29, 2022 3:06 pm    Post subject:
Alright, it doesn't necessarily means that the deflection board is broken, I rather blame the power supply.
If we look at the diagnostics leds, they tell us that the 17V rail is too low (green led nr. 3). Because of that, to protect the tubes, the safety circuit is triggered. High tension hold down is activated (green led nr. 8) and projector goes in scan-fail modus (red led nr. 12).
So firstly, you have to check few things on the power supply (the tray that slides out right under the lenses). Shut the projector off and pull the power cord out of the mains.
You won't be able to take it completely out, the cables connections don't allows that, but slide the tray towards you as much as possible. Take out the plastic cover so the components on the PCB are visible. Now solder a long wire to the top of the coil L14.
Take your digital multimeter, turn the dial to VDC, connect the positive probe (red) to that wire from coil L14 and the negative probe (black) to the metal chassis of the projector. Locate potentiometer P3 (blue square with white adjustable pot in the middle) and start the projector. Watch the reading on the multimeter and adjust P3 if needed for a reading of 17VDC.
If no improvement, you'll have to check some fuses and safety resistors on the same power supply. But first, make sure the 17V rail is ok. Than we look further.
bluemoonhu
Posted: Mon May 30, 2022 2:40 am    Post subject: Barco 708MM “HOLD DOWN EHT” fault
Find P3. Where is L14?
 Filesize:  141.84 KB
 Viewed:  2677 Time(s)
bluemoonhu
Posted: Mon May 30, 2022 4:20 am    Post subject:
I only found P3 but not L14. Where is L14?
Thanks!
Hulio
Posted: Mon May 30, 2022 4:50 am    Post subject:
Tell me first which power supply you have.
R7627675, R7627676 or 764202
bluemoonhu
Posted: Mon May 30, 2022 5:30 am    Post subject: Barco 708MM “HOLD DOWN EHT” fault
R7627675
bluemoonhu
Posted: Mon May 30, 2022 5:34 am    Post subject: Barco 708MM “HOLD DOWN EHT” fault
R7627675
 Filesize:  87.88 KB
 Viewed:  2659 Time(s)
bluemoonhu
Posted: Mon May 30, 2022 5:38 am    Post subject:
I seem to have found L14。sorry!
bluemoonhu
Posted: Mon May 30, 2022 5:42 am    Post subject: Barco 708MM “HOLD DOWN EHT” fault
L14?
 Filesize:  91.71 KB
 Viewed:  2655 Time(s)
Hulio
Posted: Mon May 30, 2022 5:44 am    Post subject:
Alright, you have it. If you have a steady hand, you don't have to solder a wire. Just don't touch something else.
Hulio
Posted: Mon May 30, 2022 5:45 am    Post subject:
Keep in mind that the test poin is on the upper side of L14, not the one in your marking.
bluemoonhu
Posted: Mon May 30, 2022 5:51 am    Post subject: Barco 708MM “HOLD DOWN EHT” fault
OK!
bluemoonhu
Posted: Mon May 30, 2022 7:42 am    Post subject: Barco 708MM “HOLD DOWN EHT” fault
I forgot the connection of these six lines. Are the colored circles on the white square of these lines facing up or down?
 Filesize:  141.19 KB
 Viewed:  2636 Time(s)
bluemoonhu
Posted: Mon May 30, 2022 7:47 am    Post subject:
bluemoonhu
Posted: Mon May 30, 2022 8:09 am    Post subject: Barco 708MM “HOLD DOWN EHT” fault
Is this connection correct?
 Filesize:  256.52 KB
 Viewed:  2628 Time(s)
Hulio
Posted: Mon May 30, 2022 8:12 am    Post subject:
Look at the jumpers of those connectors (grey small wire). For front-table configuration:
-Horizontal scan (upper 3 connectors) = jumper on the right side
-Vertical scan (lower 3 connectors) = jumper on the left side
Don't do that while projector is on !
Page 3 of 8
