Barco 708MM “HOLD DOWN EHT” fault
bluemoonhu
Posted: Sat Apr 23, 2022 2:38 am    Post subject: Barco 708MM “HOLD DOWN EHT” fault
Such the fragile tube!
 Filename:  QQ图片20220423105001.jpg
 Filesize:  435.92 KB
 Downloaded:  102 Time(s)
bluemoonhu
Posted: Sat Apr 23, 2022 2:50 am    Post subject: Barco 708MM “HOLD DOWN EHT” fault
Hulio wrote:
Are the tubes P16LNG22 ? If yes, I know a cheap set in good shape.
Are you located in Hungary ?
Yes! I am in China
Hulio
Posted: Sat Apr 23, 2022 6:47 am    Post subject:
Here, on e-bay Germany, a green tube in good shape for only 30€, shipping not included. He has 2 sets of tubes, I believe.
The guy is to be trusted, I know him (bought several items from him in the past). Send him a message.
https://www.ebay.de/itm/144339474582?hash=item219b4d9896:g:xKsAAOSwReBhvhXg
bluemoonhu
Posted: Sat Apr 23, 2022 9:44 am    Post subject:
Do you have the RGB driver board of BG 808s ?
Hulio
Posted: Sat Apr 23, 2022 6:21 pm    Post subject:
No, sorry. Myself, I use a Barco Cine 9.
bluemoonhu
Posted: Sun Apr 24, 2022 2:46 am    Post subject: Barco 708MM “HOLD DOWN EHT” fault
very rare machine! Please look at the PM。
bluemoonhu
Posted: Thu May 26, 2022 2:41 am    Post subject:
There are new problems again. In order to save this 708, I bought a faulty C7. The deflection board in this C7 is faulty. I used the deflection board in 708 to replace C7. as a result, the deflection board of 708 was burnt out。
bluemoonhu
Posted: Thu May 26, 2022 3:37 am    Post subject: Barco 708MM “HOLD DOWN EHT” fault
C7 and 708mm
 Filesize:  187.21 KB
 Viewed:  2722 Time(s)
bluemoonhu
Posted: Thu May 26, 2022 3:41 am    Post subject: Barco 708MM “HOLD DOWN EHT” fault
When I reinstalled the deflection board of 708 back to 708, there was a fault light and the machine could not run
 Filesize:  83.11 KB
 Viewed:  2720 Time(s)
bluemoonhu
Posted: Thu May 26, 2022 3:44 am    Post subject: Barco 708MM “HOLD DOWN EHT” fault
SF---deflection board fault
 Filesize:  160.96 KB
 Viewed:  2718 Time(s)
bluemoonhu
Posted: Thu May 26, 2022 3:54 am    Post subject: Barco 708MM “HOLD DOWN EHT” fault
I checked the deflection board electric resistance and found that the resistance values of the two resistors could not be measured. have they been burned?
 Filesize:  154.62 KB
 Viewed:  2716 Time(s)
bluemoonhu
Posted: Thu May 26, 2022 3:56 am    Post subject: Barco 708MM “HOLD DOWN EHT” fault
Resistance I
 Filesize:  104.77 KB
 Viewed:  2714 Time(s)
bluemoonhu
Posted: Thu May 26, 2022 3:57 am    Post subject: Barco 708MM “HOLD DOWN EHT” fault
Resistance 2
 Filesize:  97.33 KB
 Viewed:  2711 Time(s)
bluemoonhu
Posted: Thu May 26, 2022 4:00 am    Post subject:
Where is the deflection board of 708 most likely to fail? thank you!
bluemoonhu
Posted: Thu May 26, 2022 4:01 am    Post subject: Barco 708MM “HOLD DOWN EHT” fault
 Filesize:  438.65 KB
 Viewed:  2707 Time(s)
Hulio
Posted: Thu May 26, 2022 10:36 am    Post subject:
Keep in mind that not all boards from 708 can be swapped with the ones from C7.
Should your 708 be a data grade, yes. I guess yours is a vision version.
The best way to find out, is to check the part number on the module sticker (R762XXX). A C7 deflection board is R7627625, while the one from the 708 is R762447. Thus, not compatible.
I would try to revive the C7, instead of the 708 (newer components, higher bandwidth, more inputs etc).
bluemoonhu
Posted: Thu May 26, 2022 1:25 pm    Post subject: Barco 708MM “HOLD DOWN EHT” fault
The 708 is vision 708mm.
yes! I know they had a different number, but they looked almost the same, so I exchanged them. I am sorry!
Posted: Thu May 26, 2022 2:27 pm    Post subject: Re: Barco 708MM “HOLD DOWN EHT” fault
bluemoonhu wrote:
Resistance 2
That's a diode, not a resistor.
bluemoonhu
Posted: Thu May 26, 2022 3:08 pm    Post subject: Re: Barco 708MM “HOLD DOWN EHT” fault
bluemoonhu wrote:
Resistance 2
Where is the fault?
Thanks!
bluemoonhu
bluemoonhu wrote:
Resistance 2
Where is the fault?
Thanks!
Page 2 of 8
