(help) barco 808s not starting
Posted: Tue Dec 21, 2021 5:24 pm    Post subject:
What Curt meant was that it could be one or more of the boards mentioned.
If the unit was in continuously in use when the issue happened it would likely be one board as failures across multiple boards at the same time would be rare. Given that the unit sat for a long time unused (years?) there's a higher probability that it could be multiple boards as parts like electrolytic caps dry out/stop working/etc.
lolkalberer
Posted: Tue Dec 21, 2021 6:04 pm    Post subject:
At this point you have to do board swaps, as this is a problem I've never seen before. I will have some of the boards if you need them, but I am almost out of 808s parts.
wait, would you send the boards to me or would i send them to you for testing?
Posted: Wed Dec 22, 2021 2:01 am    Post subject:
I no longer have an 808 here to test boards in. I do have some boards left that worked when I put them on the shelf. Where are you located?
Posted: Wed Dec 22, 2021 5:51 am    Post subject:
Are you able to be a little more precise as to where the squealing is coming from? Barco quads and or splitters will squeal before they fail. The squealing in this case is high voltage going to ground. If it is this then locate the quadrupler which is at the back of the unit. Use this link to find that http://www.curtpalme.com/Barco808_Layout1.shtm
The splitter is between the green and blue tubes inside the set. You will see a number of large HV red cables running into that.
When its squealing see if you can determine if its coming from one or both of those.
DON'T TOUCH either of them though as they are responsible for 34KV.
lolkalberer
Posted: Wed Dec 22, 2021 10:28 am    Post subject:
I checked and the sound is coming from the switch mode power supply which i presume is normal. The thing is it just that is sounds weird. It kinda sounds like a crt tv receiving an unstable video signal.
lolkalberer
Posted: Wed Dec 22, 2021 10:31 am    Post subject:
im in switzerland. it would be really awsome you could send those over! though shipping stuff here can be a pain.
Posted: Wed Dec 22, 2021 2:56 pm    Post subject:
I can, can you send me an email to curt at reeltoreeltech dot com with your address? I also need to know if it's a BD808s or a BG808s. I'll put together what parts I have left, although with a few boards, shipping likely will be $150USD or so.
Thanks!
Posted: Thu Dec 23, 2021 12:25 am    Post subject:
There should not be any sound coming from the SMPS. At least I have not ever heard any sound from a properly working SMPS. I would say you need to take a closer look at that. Check the caps they can squeal. There are loads of them on this board.
lolkalberer
Posted: Fri Dec 24, 2021 6:55 pm    Post subject:
i checked the smp board but i don’t see anything obvious. isn’t it normal for CRT projectors to sound like a CRT television?
Photo of board: https://1drv.ms/u/s!AszjmP5e2jJigYBWXQXxUKf5rnRGMA?e=edSbTV
however, i checked the front part of the Projector and there i saw this: https://1drv.ms/u/s!AszjmP5e2jJigYBR4vfN2OgIU72T7g?e=f2v7Zg
could this be causing any problems?
Posted: Fri Dec 24, 2021 9:43 pm    Post subject:
You can get some HV crackle on start but that's about it.
lolkalberer
Posted: Mon Dec 27, 2021 2:42 pm    Post subject:
I looked at everything again with a friend and he noticed that on the Sync+Vertical Deflection Module there are these weird wirings.
Picture: https://1drv.ms/u/s!AszjmP5e2jJigYBd4JqSbyZHyLj3Gg?e=VoEWDs
They don’t match up with the service manual, so I guess the previous owner did something here?
We will try to rewire it back to normal according to the service manual.
Another thing is on the back there’s this led which isn’t connected to anything
Picture: https://1drv.ms/u/s!AszjmP5e2jJigYBfr4EAM3RzIdPEjQ?e=KPBDv9
Posted: Mon Dec 27, 2021 3:04 pm    Post subject:
That LED is not stock, so ignore it. The big problem you have now is that the set has been modified to a point that you don't know what is going on.
If someone had brought me that 808s a few years ago when I was still doing CRT projectors, I likely would have turned it down simply due to the fact that it was modified. Since you haven't seen the projector running, you don't know if the modder caused the set to be defective, or whether the set simply failed on its own.
At this point though, I wouldn't un-mod anything, as you may end up causing more problems, making the set impossible to diagnose.
I'll check into what spare 808s boards I have today or tomorrow, and will let you know.
lolkalberer
Posted: Mon Dec 27, 2021 4:11 pm    Post subject:
ok i will leave it allone. thanks for helping out!
Posted: Wed Dec 29, 2021 3:52 am    Post subject:
What do you see as the issue here??
Posted: Wed Dec 29, 2021 4:03 am    Post subject:
If you really want this to work as well as it could I would dump that vertical deflection board anyway in favour of R7628085
Here is an image from this site
https://www.curtpalme.com/forum_archived/viewtopic.php@t=16437.html
You don't need the small daughter board.
lolkalberer
Posted: Wed Dec 29, 2021 4:14 pm    Post subject:
Well i just thought i looked weird due to the gunk on it and i wasn’t sure if that crack was supposed to be there, so i thought I’d just ask. But why are you bringing this up again? i asked, you said:
and the question was answered.
Posted: Wed Dec 29, 2021 10:42 pm    Post subject:
I didn't look at your images before answering. When I did I wondered what you saw as a problem.
As far as the vertical deflection board is concerned I would change it. I have a few of the one you have and everyone has an issue. Age probably getting the better of those boards considering the amount of components.
Boet
Posted: Fri Dec 31, 2021 4:15 pm    Post subject:
Those are usually factory revisions of the circuit, without changing the circuit board.
So I wouldn't worry about those, they look like factory modifications.
lolkalberer
Posted: Fri Feb 04, 2022 7:28 pm    Post subject:
So, I finally received the replacement parts from Curt and tried it out… with the exact same results. Crying or Very sad I replaced the H shift board, the switch mode PSU and the G2 diagnostic board. So, I guess it must be the Vertical Board or the Horizontal board, but I have no clue where to get a replacement for that. If anybody knew where I could get one of those, I’d be very thankful. But until then I’ll have to put this project on hold.
