Sony G70 error 36
Posted: Sat May 01, 2021 2:18 pm    Post subject:
Won't work. Disconnect the broken tube HV leads out of the splitter. Pull the boot back, push down hard on the lead, twist, and it should pull right out. DON'T FORCE IT! Try again if the lead doesn't pull out without any effort.
Posted: Sat May 01, 2021 4:51 pm    Post subject:
NuclearSnake wrote:
Should I fully disconnect the tubes? All the cables and the HV line?
Ha I was just coming back to mention this. Sorry I forgot to put that in .It came to me as I woke up.
NuclearSnake
Posted: Sun May 02, 2021 12:21 am    Post subject:
Thank you guys! It was tricky at first but I got a hang of it and got the 2 HV leads out without breaking anything. The HV error went away but the Vertical sync error 36 is back still. I’m pretty sure I pulled out the two correct leads, all the other cables are still attached to the unplugged tubes though, am I to fully disconnect?
Posted: Sun May 02, 2021 3:14 pm    Post subject:
The imploding tubes may have nuked the V board, so you may still need one of those. Getting a V error with an imploded tube failure is weird, you should get an 'HV over', error code, or whatever Sony called it. I'm guessing the HV arced to the V yoke winding, nuking one of the V chips on the V board. Someone here should have that board..
