Issue with Barco, OPPO and Netflix...
Corleone88
Posted: Sun Jan 31, 2021 9:18 am    Post subject: Issue with Barco, OPPO and Netflix...
Hello,
I have a strange behaviour when I watch a Netflix movie through my OPPO 103 on my BG 1209s. The picture looks fine until some red flashes appear every 30 sec. Then the flashes come more often and finally I have a green dotted picture and some black screens (loosing sync ?).
My setup is a OPPO103-Radiance 2041-Cambridge Amp-Barco 1209s.
There is no problem watching Blurays or mkv HD movies from my OPPO. Why this is different with a Netflix movie?
Thanks for your help
Posted: Sun Jan 31, 2021 2:42 pm    Post subject:
Well that certainly is strange and I have no idea Question
Corleone88
Posted: Wed Feb 03, 2021 2:58 pm    Post subject:
Any idea Smile?
ElTopo
Posted: Wed Feb 03, 2021 3:33 pm    Post subject:
Maybe it's a refresh issue ?
Barco Cine 9 the one and only
Corleone88
Posted: Wed Feb 03, 2021 4:26 pm    Post subject:
That is possible indeed. I have a refresh rate of 72Hz on my Lumagen/Barco so if Netflix is 50Hz, it could be an issue.
I will try 75Hz.
Posted: Thu Feb 04, 2021 12:10 am    Post subject:
I would try 50Hz first. The 20xx series are not as good at 72Hz, 75Hz, and other higher clock settings. The XS, EX, and 21xx are much better suited to that I am afraid.
Corleone88
Posted: Thu Feb 04, 2021 7:13 am    Post subject:
What do you mean by "better suited"? I am not expert, but at 72Hz, the picture looks great to me with the 2041.
ElTopo
Posted: Thu Feb 04, 2021 10:59 am    Post subject:
Is Netflix played directly from the Oppo app or from an external device into the Oppo ?
Corleone88
Posted: Thu Feb 04, 2021 11:50 am    Post subject:
Directly from the OPPO
Posted: Thu Feb 04, 2021 3:00 pm    Post subject:
The output chips on the 20xx series had some issues being clocked above 145 MHz at times. 1080p 72/75 is well above their threshold. 1080p 60/50 is inline with their specification. I would not use 72/75 until you figure out what the problem is because it's possible that is the actual problem.
Corleone88
Posted: Sat Feb 06, 2021 7:49 pm    Post subject:
I set it to 1080p60 (Netflix through OPPO is at 60Hz) and the issue is still there...
Could be related to HDCP ?
Posted: Sat Feb 06, 2021 11:24 pm    Post subject:
HDCP is usually snow or no image.
It's really very odd. Would you post a photo?
Corleone88
Posted: Mon Feb 08, 2021 10:37 pm    Post subject:
It has been worse and worse...
Now it is not only Netflix but mkv files and Blurays. The issue also appears sooner. After 1 hour.
It started with red flashes, then black flashes, green dotted pictures and then more black flashes (but longer). I even saw (a few times) the picture (size reduced by 10) and displayed in the left corner of the screen for a split second.
I tried to turn off the Barco, the Lumagen, the Cambridge Amp, it is ok during 2-3 minutes and then it started again. I change the bluray player, same issue. I tried to unplug the Lumagen for 2 minutes. No effect.
I have absolutely no idea what is going on. Is the issue with Netflix (first time I tried it on my HT system) at the start a coincidence or the cause of the issue?
I will try to record a short video to show you the issue.
Posted: Mon Feb 08, 2021 11:03 pm    Post subject:
If you post a photo we can at least determine if this is taking place in the digital versus the analog domain. A photo, or multiple photos are required. A short video may also be helpful.
ElTopo
Posted: Wed Feb 10, 2021 7:52 pm    Post subject:
Cable issue ?
Posted: Thu Feb 11, 2021 12:04 am    Post subject:
Can you swap your main HDMI cable end to end?
Corleone88
Posted: Sun Feb 14, 2021 2:25 pm    Post subject:
I did few other tests and it seems that 50Hz videos (MKV or Netflix) show the issue. The Barco has been set to 1080p50hz.
If I find a 60Hz video, I will also try.
No issue for BR and MKV at 24Hz.
"Cable issue ?"
Well It should also be a problem at 72Hz I think.
"Can you swap your main HDMI cable end to end?"
Possible, but as it is very long and inside the wall, I will also need a spare that I do not have unfortunately
Here is a video showing the problem: https://www.youtube.com/watch?v=A5JW-Swa5Qc&feature=youtu.be
Posted: Sun Feb 14, 2021 4:05 pm    Post subject:
"Cable issue ?"
The video tells all. I am 100% sure that the problem is HDCP losing it's lock.
Most likely the info frame is not consistently making it all the way through your signal chain. That flash of "dots" is called "snow" and it is what a source sends when HDCP is dropped. Either get a better cable or get an HDCP stripper. I would suggest getting a better cable because this will improve your HDMI signal lock and also speed up sync times as well. The black screen is happening because the entire HDMI signal is resyncing. This could squarely indicate the cable is on the edge of stability.
I think the Ruipro cables are the best right now and reasonably priced (assuming the problem is the long cable to the projector). Amazon is the only authorized reseller in much of the world.
Posted: Sun Feb 14, 2021 4:12 pm    Post subject: Re: Issue with Barco, OPPO and Netflix...
Corleone88 wrote:
Hello,
Based on this, the problem might be the HDMI cable connecting the Oppo to the Lumagen. My favorite HDMI interconnects right now are the Metra "Ethereal MHY" cables or the Monoprice "4K Certified Premium High Speed HDMI Cables." Both are inexpensive and work almost every time.
https://metrahometheater.com/hdmi-cables/mhy-cables/mhy-lhdme1.html
https://www.monoprice.com/product?p_id=15427
Corleone88
Posted: Sun Feb 14, 2021 4:15 pm    Post subject:
Thanks Craig,
1m or more for the length?
