Leaving the dark side
Posted: Sat Aug 22, 2020 11:58 pm    Post subject:
Assuming you mean NX9, not N9 -- JVC says 100k:1 native, 1,000,000:1 dynamic. And with digitals that's normally the ANSI number.
General BB
Posted: Sun Aug 23, 2020 7:22 am    Post subject:
Don't know what you actually trying to explain here to ElTopo? JVC says 100k:1 native, 1,000,000:1 dynamic. And with digitals, that's normally the ANSI number.
This is the NX9 specifications you talk about. JVC claims 100000:1 native, 1,000,000:1 dynamic. 350:1 in Ansi contrast.
My NX9 unit measure over 100.000:1 in native Contrast iris fully closed then high lamp mode, but much under 1000.000:1 dynamic iris set to auto.
opv
Posted: Sun Aug 23, 2020 11:34 am    Post subject:
ElTopo wrote:
Here a Cine9 with infinity contrast and real black.
Without background ‚glowing‘ or iris pumping.
I was on the same page several years ago.
On one hand, I wanted the perfect fade to black
On the other hand I wanted perfect shadow detailed
I tried many combinations on the Lumagen 21 point Gamma, trying to push the very low IRE points up.
I was never satisfied and eventually, I gave up the perfect fade to black to get perfect shadow details and I was happy with the results.
Once I made this choice, the black levels of the Barco and the JVC look very similar to me.
Posted: Sun Aug 23, 2020 1:50 pm    Post subject:
ElTopo wrote:
I still like fade to black until it’s completely dark. Always a wow effect.
But how often do you actually get that effect? I ask seriously as it's an often touted benefit of CRT (or was back when digitals had poor/elevated black levels) but having probably watched over 5000 movies in my HT I can remember those sorts of fades only a handful of times when the fade holds on black long enough for your eyes to adjust and notice. I don't think I'm giving away any spoilers here given the age of the movie, but the black scenes in Cast Away are one of the few where it matters. They hold black longer than normal to give you a sense of what it felt like being lost in the ocean. That's only until the first lightning flash as after that your retinas close right down again.
IMHO ANSI contrast ratio is more important as it's not something that only shows up 0.001% of the time. I'd rather have the slightly elevated black levels of a good digital in order to get good ANSI than the washed out ANSI you get with CRT with slightly lower black levels for those rare fade to black scenes.
My 2 cents of course.
Posted: Sun Aug 23, 2020 3:07 pm    Post subject:
I agree 100%. My CRTs were never professionally calibrated, but I tweaked with them a lot to try to get the best picture. I found that when I set them "right," with gamma of 2.2 or so and fade-to-black at IRE0, I did indeed get great blacks. BUT I lost a tremendous amount of shadow detail. Since, as Kal said, real fade-to-black is pretty rare, I chose to sacrifice perfect blacks so I wasn't straining to see what was happening in the much-more-frequent dark scenes.
And yes, ANSI contrast is huge. Many scenes get much better depth and realism when you don't have light bleeding from bright areas into dark areas. My JVC RS45 has 50k:1 native contrast but I don't know the ANSI contrast. I know it's significantly better than my (mostly air-coupled) CRTs.
ElTopo
Posted: Sun Aug 23, 2020 3:55 pm    Post subject:
I don't miss any shadow details at all.
With brand new tubes and a batcave CRT is amazing !
Most important of all is the filmlike look and motion with CRT witout any tricks like field interpolation.
@Kal: You ever had a 9 inch CRT in action in your cinema ? A 9 inch is another level.
ElTopo
Barco Cine 9 the one and only
Posted: Sun Aug 23, 2020 4:31 pm    Post subject:
You’re detracting from my original question. A 9” LC machine doesn’t somehow break the laws of physics and allow for ANSI contrast ratios that are on par with the best digitals. To each their own but I’d rather have better ANSI contrast (apparent all the time) than better fade to black (rarely apparent). That was my point.
pureaudio
Posted: Sun Aug 23, 2020 6:04 pm    Post subject:
The best CRT LC machines will struggle to get 100:1 ansi contrast, on top of that they scatter much more light into the room, so you need significantly better room treatment to get anywhere near that on screen.
The worse JVC samples start off around 100:1 and up to around 250:1, ill guess the RS56 have around 170:1, that is a visible improvement to the perceived image contrast.
Only CRT running 72hz have a motion benefit, but loos some resolution capability with that high pixel clock.
A perfect CRT with a perfect 2.4 gamma displaying all the low levels 17-18-19-20 and so on, where they also follow the gamma curve will look better in a few scenes / movies, like the dark Harry Potter scenes, most CRT will however loos a lot of low level information as they clip black to preserve the high contrast, in most cases CRT will not have higher contrast than a good JVC when having to display the low levels right.
JVC improved motion with the RS4910 and forward, if you dont use the eshift, and specially that generation had very nice on off contrast, not unlikely to get around 50000:1 on a 100" screen, which is around the max size for CRT with a neutral gain screen.
I have seen good G90 Barco 909 and Marquee 9500, and a lot of ones that was worse than bad, same can be said about JVC projectors, there is horrible samples that should have been returned, and just as many horrible pro calibrations that should never have been done.
Point is if you really want to compare, you will need to be completely in control of both setup, dont judge a CRT or a Digital you have no clue how is setup and running.
Posted: Sun Aug 23, 2020 6:16 pm    Post subject:
I've certainly very much enjoyed both (CRT and digital) and have always been careful to set up and calibrate both to get the most out of the units. Everyone has different likes/needs so in both cases I always purchased units that met those needs. Someone else's needs may be different.
That said, I find the comparisons of digital to CRT a bit curious or odd as it's not like CRT is even available anymore. Obviously they haven't been manufactured for years so buying new is impossible. Some NOS units may be available but they're going to have been sitting unused for many years. Someone who wants a high end 9" unit is going to have a very difficult time finding a used one in good shape, and given the age of the units there could also be issues with drift (recapping is an option).
Some 'classic' electronics like tube amps and vinyl never quite went away or died, and both have actually been seeing a comeback as of late in terms of sales of new models. I don't think the same will ever be true of CRT given the high cost to build units. A manufacturer would have to spend millions in capital if they wanted to bring forward a new CRT projector model these days as I don't think there are any tube manufacturers left? It's too bad as I think there may be a small but niche market for them (as long as they don't carry a $50K asking price).
General BB
Posted: Mon Aug 24, 2020 8:48 am    Post subject:
Agree here with kal and pureaudio. Well written pure audio then your last post and stick to the fact and the reality.
Leaving the dark side happened for 98% of all the CRT users around the world many years ago maybe in 2006.
The last 2% still use the heart starter every day on ann already more or less super dead technology.
Today maybe 0,2% in 2020
I will for sure enjoy a good CRT, but time has gone really fast forward in development.
So differences have been for shore in favor digitals today. Here we talk "almost" everything even FI. But fade 2 black you need laser technology or CRT.
I think there is only a very small amount of people in the whole world that still stick to CRT, and knowledgeable and really understand CRT.
You can easily see that even here.
pj-toso
Posted: Mon Aug 24, 2020 8:01 pm    Post subject:
Sorry to say the Cine9 do not have infinity contrast. The real "in picture contrast" are pretty low, much lower than Sony and JVC digital projectors.
I have and have had numerous 909s and Cine9s, and I have tweaked the hell out of them. I got my first crt projector back in 1989, and I have had almost any crt imagineable in my hometheater. The only brand I have not owned is Ampro. From Sony(all I think), Barco (all but 812, 908), Nec (all but 10PG), Electrohome (all but some pretty old stuff).
Crt was pretty much my life from 1989 to 2006. In 2007 the JVC HD1 came and the game changed - it was what sent the crt into the retirement home facility.
But JVC do not automatically look good, you have to know them and how to use the controls properly to get to look good. Do you not know how, then they can look quite poorly.
I do not use automatic iris, it do not look good, and you do not need it.
They have great black. And for 2.35:1 movies you have to use black screen masking, or at least shift the picture down so the start of the active picture start at the bottom of the 16:9 screen.
I have tested instant switch between G90 and Cine9 against JVC many times for extensive periosds. Do not come here and say that I do not know how to set up a crt properly - because I do know how to do that. I have done things with black detail with both the G90 and Cine9 that people have said to be impossible, just to invite them and prove them wrong.
And just for the records, I understand that some will use and prefer CRT. I still myself can enjoy the picture, but most for nostalgia.
To say that crt have better black is purely wrong. Yes, in fade to black it is, but that is only true if you can maintain picture level 17, 18, 19 and so on as well. But you have to count in black scenes with ACTUAL picture content also, and the crt looses against a properly set up modern JVC.
We have had gatherings here in Norway to show this, crt people saying the opposite have had their chance to prove the opposite, but everytime they have failed, and said that something is wrong, and the shall prove it the next time. (This was many years ago, and the digitals have only getting better, and they have not proved their point).
I know what a top notch crt can do, and I enjoy it. I also know what a good digital can do and I enjoy it.
Disclaimer: My postings are subjective and not facts.
Posted: Tue Aug 25, 2020 9:55 am    Post subject:
Even after the poor thing (CRT) is dead for 98% of people there are still some who want to compare. Shows what an impact CRT technology has had or is that is still having Laughing
ElTopo
Posted: Tue Aug 25, 2020 5:33 pm    Post subject:
Only a laser projector could change the game for me.
pureaudio
Posted: Tue Aug 25, 2020 5:57 pm    Post subject:
What specific laser projector have you seen ?
ElTopo
Posted: Tue Aug 25, 2020 9:32 pm    Post subject:
Epson and Sony but i want to see the upcoming ones in 2021.
HaydnG90
Posted: Tue Aug 25, 2020 10:50 pm    Post subject:
This is where I'm heading when I move back to Europe next year
ElTopo
Posted: Wed Aug 26, 2020 9:34 am    Post subject:
No Sony bulb projector for me of course as i had my negatives on those.
The Sony laser costs too much $$$ vs the hopefully upcoming Epson.
opv
Posted: Wed Aug 26, 2020 9:58 am    Post subject:
I'm curious, what exactly do you expect to get from a laser projector?
Better fade to black due to lamp dimming? this will probably have similar behavior to dynamic Iris
10000+ hours lamp life? that is nice but not an image quality feature
Better light output?
General BB
Posted: Wed Aug 26, 2020 10:42 am    Post subject:
10000+ hours lamp life? that is nice but not and image quality feature
I agree with you here 100%
pureaudio
Posted: Wed Aug 26, 2020 12:17 pm    Post subject:
Both Sony and Epson have low native contrast, the difference with laser is they can turn the lamp off, compares a bit to dynamic iris.
If you can live with a Epson laser then your Barco must be quite bad, i get the idea that you just have this principle that you want black, and there is other solutions for that, just as the laser projectors the JVC can also go completely black: infinite contrast just install a shutter, or flip the power switch when measuring the black level.
How do you like the extreme low level scenes on laser projectors, do you mind the gamma distortion/ limited dynamic?
Page 2 of 5
