Leaving the dark side
Goto page 1, 2, 3, 4, 5  Next
opv
Posted: Tue Aug 18, 2020 8:35 am    Post subject: Leaving the dark side
After 16 years of CRT love, including Barco graphics 808S and 1209S I have decided to leave the dark side and go digital.
The decision wasn't easy, as I still love the picture my 1209s throws and it has its cinematic magic look to the picture.
So, what drove me to do it?
1) I have much less free time and the CRT needs TLC
2) I have some issues with the picture, 16:9 tube burn, uneven focus, left geometry etc.
3) Reliability issues, that was actually the last straw . Every few months, I would get a new problem and while trying to solve it, my theater is down for the entire family. also, replacement boards availability is much lower.
I decided to go with JVC RS540, the JVCs are the closest thing you can find to CRT picture.
The JVC is sharper, brighter, quiet, better colors and more. it also requires much less devices in the video chain.
But the picture in BD SDR is very similar to what I had with the Barco. not something that will drive me to watch my movie collection again.
HDR, however, is really something else. once I watched content in HDR, I do want to watch my movie collection again, but in BD UHD.
I had wonderful hours with CRT and I think that the fact that the picture in SDR still compares with the JVC, is amazing.
I will always be a fan of CRT and it will always have a place in my heart.
I also love the CRT community here and I want to thank for for excellent advice through the years.
Thanks for reading,
Or
 Filesize:  89.34 KB
 Viewed:  8985 Time(s)
Posted: Tue Aug 18, 2020 2:05 pm    Post subject:
Enjoy the JVC! I did the same way back in 2013 and had similar results.
opv
Posted: Thu Aug 20, 2020 5:57 am    Post subject:
Hi Kal,
I'm curious, how many lamps did you replace since 2013?
Or
Posted: Thu Aug 20, 2020 1:45 pm    Post subject:
I'm about 2000 hours into my 3rd bulb. I swap them out at 2900 hours when the projector tells me to even though you could go longer. Light output's usually down by that point anyway. They say you can run them for 4000 hours if you only use low lamp mode but about half way to 2900 is when light output for me (for my screen gain/size and throw distance) drops below 14 ftL so I go to high lamp mode.
Posted: Fri Aug 21, 2020 1:52 am    Post subject:
The JVC 540 is really a very nice projector. Of course it does not have a true 4k panel, but I find that less concerning because it makes up for that in spades with its outstanding native contrast ratio of over 60,000:1. None of the 4k panel JVC's can do that yet.
UHD's most outstanding feature is that of the larger color gamut in DCI-P3. I have to say my G90 looks better than my NX9 for HD, but the DCI-Pe gamut and HDR on UHD with the NX9 looks better than anything my G90 can do. So, not as much content at UHD, but what there is is awesome and only a small hit to performance on HD material.
Best and enjoy,
General BB
Posted: Fri Aug 21, 2020 6:06 am    Post subject:
Best and enjoy,
Both the N7 and the NX9 can do way over 60000:1 have calibrated several, but can differ from unit to unit. To get the most accurate measurements measure off-screen. My NX9 is calibrated to 50Nit with almost 80000:1 native but iris on -10. Autoiris off. 1.0 gain 109inch
But with big screens, you need iris more open and the native contrast will drop. Fully open high lamp 25000:1-38000:1 on the RS3000.
But for shore G90 or other CRT will have better black for shore even compared to any JVC.
Here a very good sample of an NX9 with 55Nit 2,4 gamma manuel iris -12. Measured on screen.
 Filesize:  320.89 KB
 Viewed:  8851 Time(s)
Posted: Fri Aug 21, 2020 6:09 am    Post subject:
Best and enjoy,
What meter are you using to obtain these measurements? I promise you the 540 has a better contrast ratio than the NX7 or NX9 and it was not 100,000:1 in the real world.
Kind regards,
General BB
Posted: Fri Aug 21, 2020 6:25 am    Post subject:
Klein K10-A L Colorimeter
JETI S 1501 Spectroradiometer
Calman Pro 2020
I also owned the X7900 I will say about the same as my NX9, The X9000 had some better.
But like I said can be different from unit to unit sample vs sample.
Also calibrated an RS3000 with poor contrast but still over 60000:1, but not fully open iris.
I calibrate different projectors all the time professionally.
I don't doubt your measurements just say that it depends on the unit.
 Filesize:  472.2 KB
 Viewed:  8832 Time(s)
General BB
Posted: Fri Aug 21, 2020 9:20 am    Post subject:
Here 2 newly calibrated JVC N5 after 100 hours of runtime. Both iris -12 on a 110-inch screen, they don't manage over 60000:1 55nits, On HDR calibration Iris fully open of course.
SDR D65 Both around 20000-30000:1 fully open iris both around 40000-50000:1 calibrated iris -12. Measured on-screen, also verified with KleinK10A with diffusor measuring against the projector lens.
The N7 some higher around 60000-80000:1 fully closed iris, calibrated around 60000:1, but here also have had one unit of JVC N7 that had 51000:1 with fully open iris and over 90000:1 fully closed. Also verified with KleinK10A with diffusor measuring against the projector lens. But have not calibrated more than 14. N5, 5. different N7 units and 2. RS2000/Nx9.
Also, a JVC N7 with max 45000:1 fully closed. So what I try to state here is that units are different.
 Filesize:  81.27 KB
 Viewed:  8816 Time(s)
 Filesize:  99.17 KB
ElTopo
Posted: Fri Aug 21, 2020 11:38 am    Post subject:
Here a Cine9 with infinity contrast and real black.
Without background ‚glowing‘ or iris pumping.
 Filesize:  100.45 KB
 Viewed:  8802 Time(s)
Barco Cine 9 the one and only
pureaudio
Posted: Fri Aug 21, 2020 12:05 pm    Post subject:
No CRT have infinite contrast, without clipping black, some have very high contrast, which makes them excellent for low light scenes.
On the other side they are not very good at mixed content with bright highlights, due to the not so good ansi contrast.
The question about the JVC projectors is not so much what is the contrast measured in the center, but whats the average contrast/ uniformity.
JVC can also have as low ansi contrast as a JVC depending the sample, however its rare. Personally i find that above 50000:1 on off and above 200:1 ansi, the contrast is no longer something you can complain about, as long as its fairly uniform across the screen.
General BB
Posted: Fri Aug 21, 2020 12:06 pm    Post subject:
No iris pumping on the NX9/RS3000 that you will see at all. On the N5 and N7, I don't remember. Because I always calibrate with auto iris off.
I'm sure its a nice picture with perfect black.
@ElTopo I don't know what scene, film, or photo you use here, and how its meant to be seen.
On a CRT it looks like this and looks good. I have owned several CRT projectors and still like the performance on them. But I moved on.
General BB
Posted: Fri Aug 21, 2020 12:21 pm    Post subject:
Reasonable.
ElTopo
Posted: Fri Aug 21, 2020 12:31 pm    Post subject:
I still like fade to black until it’s completely dark.
Always a wow effect.
I‘ve seen the N5 and it was very disappointing. Black Level was much much under that what i would expect for such a high dollar projector. Besides that the FI looks like a video game Rolling Eyes
pureaudio
Posted: Fri Aug 21, 2020 1:01 pm    Post subject:
I think most of us have seen bad samples and badly calibrated JVC projectors, same can be said about CRT, whats you measured gamma of the 2% IRE?
ElTopo
Posted: Fri Aug 21, 2020 1:34 pm    Post subject:
Here you go:
https://www.curtpalme.com/forum_archived/viewtopic.php@t=23746.html
pureaudio
Posted: Fri Aug 21, 2020 2:03 pm    Post subject:
ElTopo wrote:
Here you go:
That is a very rough calibration report, that kind of reports gives no indication of performance, there is so much going on between the measurement points.
Try measure your out of black pr level, or at least with 1% divisions then you will get a much better understanding of what goes on out of black, and if your maintaining a decent bit resolution.
That goes both for Digital and CRT, specially if you apply digital correction to a CRT.
General BB
Posted: Sat Aug 22, 2020 2:56 pm    Post subject:
Tested my Nx9 yesterday with settings: iris at -10 (17FL) to recalibrate my unit after 200 hours of use, also to check my unit.
The setting with 17 FL is the setting that I will use for film. This is without the Colour filter engaged so BT709. If Filter is used I will get even some more contrast.
Calibration is done manually with JVC software gamma editor. Results on ON/OFF confirmed turning KleinK10A with diffusor about 1 meter from the lens. It was some less than 88813:1, measured 81117:1. So not so accurate on-screen but close.
Fully closed Iris in low lamp mode 94893:1 against the lens with super stable measurements with variations only between 1-3:1 difference. This is the 100% accurate contrast on my NX9 in my B-cave. With Fully open Iris High lamp mode I would guess Over 100000:1 easy with fully closed iris. But my unit is on specifications and the only acceptable thing.
I will clearly say an NX9 with 60000:1 or less fully closed iris would be delivered back to my seller the same day, and no deal.
Sad that there are many bad samples out there that don't get returned for a fix.
If I think back I have delivered back and got a new JVC with 1 or 2 units as DOA. But that was the X/RS series, so far none N series. But know some in other countries that got a bad sample of the N series and returned it to the seller.
 Filesize:  79.62 KB
 Viewed:  8685 Time(s)
ElTopo
Posted: Sat Aug 22, 2020 6:57 pm    Post subject:
Looking good.
What i read the N9 does ‚only‘ have about 249:1 ANSI contrast. Is that correct ?
General BB
Posted: Sat Aug 22, 2020 8:09 pm    Post subject:
ElTopo wrote:
Looking good.
What I read the N9 does ‚only‘ have about 249:1 ANSI contrast. Is that correct ?
Only 249:1? Are you joking?
I guess fact somewhere between 200-400:1, also here will variate from unit to unit. Strey light in the engine of the machine is a factor here, also bright corners that a lot of the JVC have.
Sony has no bright visible corner, but under 10000:1 in native contrast, you don't see it.
200:1 in Ansi contrast average calibrated is really good on a JVC. For shore will look great.
Ansi contrast is also really hard to measure correctly, with a big error factor. JVC factory claims around 350:1 normally.
It's just to measure see what you get.
Page 1 of 5
