HaydnG90
| Posted: Mon Jun 17, 2019 2:39 am Post subject: |
Maybe try different source and/or cable just eliminate the problem being something other than the G90. Is it on all tubes?
rjnsales
Joined: 27 May 2006 Posts: 19 Location: Lee's Summit, Missouri
| Posted: Mon Jun 17, 2019 11:15 am Post subject: |
HaydnG90
Just checked to make sure but left hand bar image is on all tubes. I am going to try a new cable direct from the Blu ray player to moome card and see if it clears the problem. If no problem there I will do the same with my cable box direct to the moome card. Then if it is clear of the problem it would be something in my B&K reference 70 A/V controller. Curt tested the set with the moome card I had him install before he shipped to me and had no issues. Plus I sent the moome card back to him and checked it again with no issues. Hope its something besides the G90.
Regards Bob, and once again thanks for your help and support
rjnsales
| Posted: Wed Jun 26, 2019 5:11 am Post subject: |
HaydnG90
I am still addressing 2 problems on the G90. The Green tube Flicker has gotten worse and the Black bars on left side of all tubes on startup which I explained earlier I just keep un plugging and replugging the HDMI cable to the moome card till it is a clear picture. For now the green tube is flickering more as the set is left on and I cannot figure this out as this is the tube I replaced 2 years ago. Have I done something wrong on the retube and is just now showing up. Or is it a neck board with bad connection??? I can deal with the replugging of the moome card issue for now but the Green tube flicker is very disruptive. I think you mentioned a Phosphorous burning off occaisionally?? Any thoughts would be appreciated.
Regards Bob
