Getting back into CRT :) Barco 909
Goto page 1, 2, 3, 4  Next
JayAllan
Posted: Fri Aug 10, 2018 11:38 pm    Post subject: Getting back into CRT :) Barco 909
Thanks to a good purchase from Curt Palme I am getting back into CRT finally! I picked up one of his new split packs today and I am going to put it up in my theater. Will be interesting to see how this looks compared to my dated JVS RS2 that I have been running.
Very Happy
JayAllan
Posted: Fri Aug 10, 2018 11:43 pm    Post subject:
Here are a couple shots.
 Filesize:  261.6 KB
 Viewed:  11034 Time(s)
 Filesize:  254.11 KB
JayAllan
I am sure it will look a whole hell of a lot better. I am currently using my 100" 1.1 gain screen. I have never owned a Barco before (mostly Sonys and NEC and early on DWIN) so this should be pretty cool. I dragged the PJ into my place today and I am starting to comb though the manuals.
Posted: Sat Aug 11, 2018 6:02 am    Post subject:
Great to see someone getting into CRT again.
Meemil
Posted: Sat Aug 11, 2018 11:00 am    Post subject:
Beautiful! Digital can look good, but the effrotlessness leaves you dissatisfied Wink
JayAllan
Posted: Sat Aug 11, 2018 6:34 pm    Post subject:
Thanks. Yes I am getting excited to dive back in.
Agreed! I "got used to" my JVC but it was never as satisfying as my old CRT.
JayAllan
Posted: Sat Aug 11, 2018 6:37 pm    Post subject:
I plugged it all together and powered it up to test it. It all seems fine but the tubes are not projecting anything. Not sure if it is because I have no signal going in yet (have to dig up my DVDO in storage) but I expected it to project the warm-up menu or something. Tubes are glowing along the bottom but that's it. No weird sounds or pops so that's good at least.
jbltecnicspro
Posted: Sat Aug 11, 2018 7:25 pm    Post subject:
Cool to see someone getting back into the tubes. Smile Unfortunately for me, even if I wanted to, new living situation will not allow for it as we have no room for one. Sad
barclay66
Posted: Sat Aug 11, 2018 10:04 pm    Post subject:
Make sure You get those red and green C elements for Your tubes. Unless You want something else than those natural flesh tones we all like so well Wink
Kind Regards,
barclay66
gregstv
Posted: Sat Aug 11, 2018 10:39 pm    Post subject:
Running my 919 with a DVDO VP50. Some people don't like them but it's been great.
Try selecting inputs. I found some sometimes the scree will stay black if no sync is applied. It could be just different firmware that does it. Also try turning up the brightness. I have had a couple that drop back to zero if you change from floor to ceiling. Not sure why but they caught me out and I spent a bit of time looking for a problem that wasn't there.
Can you hear the EHT come up?
Posted: Sun Aug 12, 2018 1:22 am    Post subject:
Guys
The most feared words in Home Theater......... "Some assembly required!" LOL
JayAllan
Posted: Sun Aug 12, 2018 5:59 am    Post subject:
The beauty of these split packs is they are easier to put up in smaller spaces.
It seems there is some activity in the tubes along the edges so they are definitely getting some juice. I pressed 6 on the remote to change to the RGBHV input but it seemed to have no effect. I will have to hook up my DVDO next and send it a real signal.
JayAllan
Posted: Sun Aug 12, 2018 6:01 am    Post subject:
Kind Regards,
barclay66
Yeah! Curt mentioned I could pull the red/green C elements out of my NEC PG10. I am going to part that projector out so I think I will do that! Smile
Posted: Sun Aug 12, 2018 7:11 am    Post subject:
I haven't taken a good look at the 909 but I would think you need to select 5 on the remote for port 5 or 3 for port 3 if you have that port plugged in.
ElTopo
Posted: Sun Aug 12, 2018 10:38 am    Post subject:
Please make sure you have connected the cables 100%
I had this once on a Split Pack so in the end it was the cable connection.
And yes, Port5 for RGBHV
cheers
Barco Cine 9 the one and only
ziani67
Posted: Sun Aug 12, 2018 11:41 am    Post subject:
Hello
check that the cover on the back where the cable arrives is well closed
on the 909SP there is a security that prevents any demarage if lid not in place.
a ++
JayAllan
Posted: Sun Aug 12, 2018 9:47 pm    Post subject:
Thanks guys! Tonight I will double check and try #5 I will also hopefully have my DVDO by then to test. I have been using an Extron cvc100 to send the signal but it has a blinking power light so it too may be wonky.
Posted: Sun Aug 12, 2018 10:05 pm    Post subject:
Go right out of your computer via VGA to 5 BNC. I think you know someone that has a sh*t-ton of those cables. Very Happy
Usually yellow is vertical sync, but not always.. Definitely input 5 though.
Also the 909 is quirky, it can take up to 30 seconds for the set to lock to an input. that's thrown me a few times, thinking that something was wrong with the set, when it was simply 'thinking' about locking to an input.
Start with a low resolution, 640 X 480 (the 909 won't lock to lower than that), and then work up..
JayAllan
Posted: Mon Aug 13, 2018 12:49 am    Post subject:
That's good to know about the startup time! I will have to look and see where my VGA to BNC breakout cables are. That would be a good test. I think I have enough 5BNC to set up my DVDO a block away LOL. In the meantime I did find my DVDO and I just found the remote for it but no power supply (yet).
 Filesize:  344.97 KB
 Viewed:  10771 Time(s)
JayAllan
Posted: Thu Aug 16, 2018 7:02 am    Post subject:
Well... I found my DVDO VP50 and my VP30. Found both remotes and both power cords. Neither works. Sad They both power up but the VP30 screen flashes on and off and the VP50 shows "serious Error 16". Ugh.
Page 1 of 4
