Budget CRT therater build thread
HaydnG90
Posted: Thu May 10, 2018 3:04 am    Post subject:
Colored 144's are a better option.
winny
Posted: Thu May 10, 2018 1:10 pm    Post subject:
Suppose I don’t move the projector, how much difference in focal length between HD8 and HD144? Can I compromise the tube screen size or is it zooming instead of out?
Melifluonze wrote:
HaydnG90
Posted: Thu May 10, 2018 1:43 pm    Post subject:
The HD144's will make the image larger at the same throw distance. If I remember correctly on my 106" screen the 144's brought the pj about 6-8" closer to the screen to fill the screen
Posted: Thu May 10, 2018 8:13 pm    Post subject:
winny wrote:
HaydnG90 wrote:
winny wrote:
Due to different focal length?
Precisely
Oh! We have the projector stand screwed to the floor and the back curtain close up to the lenses with holes cut out for them so different focal length is undesirable. Sad
Yep and on the SONY's you can mask off the AKB line.
As in Sony tubes? I have Panasonics in mine. Or as in an equivalent Sony projector?
SONY projectors.
winny
Posted: Mon Jul 16, 2018 8:38 pm    Post subject:
Update to the project:
We where never really satisfied with the glare from the black but flat and shiny fabric in the ceiling and I have been looking out for sound absorbers for a long time. Found 100 of them for 1.5 USD each and in 60x60 cm size. Unfortunately they are from the 80s and I’ve noticed newer ones are thicker but fluffier which I assume would dampen more midrange. These are far more solid but the HF damping is very good if you hold one up and speak against it and listen. Next issue to tackle is the color since they where of course matte white. Got a quote of 22 USD each to get them painted despite no prep work needed. For that money I could buy paint, hardener, thinner and a spray gun with plenty of cash to spare. Never wet painted except for can spray paint but this should be a forgiving project.
First attempt was with a spray can just to see if this was viable. Result was ok but the cost would have been tremendous.
Next up was to order two-component paint and buy a paint gun. It took forever to get started and by the end I concluded that my time was more valuable than paint so I laied it thick and from several angles to get into the grooves/dimples of the surface. They are still drying so tomorrow I will see how they turned out and hopefully install them.
Stay tuned for more to come!
Unfavorable angle and not dried yet.
 Filesize:  116.1 KB
 Viewed:  2872 Time(s)
Second attempt. Spray gun and thinner.
 Filesize:  129.89 KB
 Viewed:  2873 Time(s)
Ran out of paint quickly
 Filesize:  196.05 KB
 Viewed:  2874 Time(s)
First attempt at painting
 Filesize:  171.65 KB
 Viewed:  2875 Time(s)
Melifluonze wrote:
Posted: Tue Jul 17, 2018 1:18 am    Post subject:
Nice score! Not sure you have it there but a flat black ceiling paint does wonders for the room
winny
Posted: Tue Jul 17, 2018 6:39 pm    Post subject:
Today was build and jigsaw day. The material was fairly easy to cut to shape with a carpenters knife, but some misalignments accumulated and there were compromises around the existing fluorescent fixtures. We discussed removing them but they stay for the moment. The LED replacements are 180 spread versus 360 for real fluorescents so painting the fixtures black would have faily low impact on their function. Let’s see.
It’s 32 degrees here and the ceiling of the warehouse is certainly not any lower, so enough for today.
Jigsaw
 Filesize:  76.62 KB
 Viewed:  2821 Time(s)
Compromises
 Filesize:  50.25 KB
Three rows finished, almost
 Filesize:  51.49 KB
Melifluonze wrote:
