CRT in 2018
Posted: Thu Jan 11, 2018 6:50 am    Post subject:
The Frankenyoke experiment has ended. I've tossed out all that stuff. Nobody asked about it, nobody wanted it, I'm not spending any more time on it.
The last of my Frankenyoke project yokes are in the dumpster tomorrow morning.
I doubt anybody will care.
I'm keeping all G90 magnetics because I believe it takes only a very simple mod to make them run in a Marquee. I hope to finish that experiment that I started, very soon.
ElTopo
Posted: Thu Jan 11, 2018 7:37 am    Post subject:
I will setup my Barco Cine 9 with new LUG's and colored C-Elements now.
Colored C-Elements of course.
Ratio/Refresh will be 817p@72Hz through a Lumagen XS.
Brightness is set to 40, contrast to 75
Very bright in my batcave Thumbs Up
Barco Cine 9 the one and only
ElTopo
Posted: Fri Jan 12, 2018 7:34 am    Post subject:
Some pics of my Cine 9
Oblivian UHD played with Oppo 203 into a Lumagen XS and out with 817p@72Hz to a Moome Barco card (internal)
 Filesize:  88.86 KB
 Viewed:  3911 Time(s)
 Filesize:  66.46 KB
 Filesize:  62.21 KB
 Filesize:  58.42 KB
 Filesize:  88.13 KB
 Filesize:  82.54 KB
 Filesize:  87.17 KB
ElTopo
Posted: Fri Jan 12, 2018 10:12 am    Post subject:
Passengers UHD with Oppo 203 into Lumagen like before
 Filesize:  75.49 KB
 Viewed:  3888 Time(s)
 Filesize:  80.95 KB
 Filesize:  52.62 KB
 Filesize:  60.12 KB
Posted: Fri Jan 12, 2018 8:46 pm    Post subject:
No reason for a change with those images Thumbs Up
Pzyked
Posted: Sun Jan 14, 2018 8:11 pm    Post subject:
Look great ElTopo
Hard to see how good the actual picture is by a photo. Also because its so small. If you have done everything correct you get a very fine picture.
My 909 has around 14 Fl and look great, but swap was done when I saw the Sony 4K.
I wont sell the 909 yet might build a retro cinema for all my dvd's and laser discs.
Posted: Mon Jan 15, 2018 3:21 am    Post subject:
Pzyked wrote:
Look great ElTopo
Ultimately it comes down to the same old discussion we have had many times. If you like what you are watching then thats all that matters.
Pzyked
Posted: Mon Jan 15, 2018 6:30 pm    Post subject:
km987654 wrote:
Pzyked wrote:
Look great ElTopo
Correct
