| Posted: Thu Dec 07, 2017 8:39 pm Post subject: |
| Barry wrote: | | CIR Engineering wrote: | As soon as I saw the images you posted I was going to suggest GAME MODE to test the Gennum chip. There is a known issue where these are failing. It typically only applies to interlaced sources.
Game mode is actually a good fix as long as you don't intend to us the video filter enhancements in the Lumagen as these are disabled. It's also still a good VP if you primarily intend to use it with progressive sources like BD and DVD.
I have an XE unit sitting here with the same problem. Trying to decide what to do with it...
craigr |
I thought about that and so directly connected my MacBook Pro to the Lumagen since I could go between 1080i and 1080p. 1080p produced a much better result but still very noisy. Not usable. |
| AnalogRocks wrote: | | I guess the re-sale market for these will be limited eh? |
If the problem didn't go away entirely with game mode and progressive sources than it's not the known problem I was referring to.
Yes, it is a known problem, but not a very common one. It is not likely that many will be effected.
Barry
Joined: 01 Feb 2007 Posts: 186 Location: Los Gatos , Ca.
| Posted: Thu Dec 07, 2017 8:48 pm Post subject: |
| CIR Engineering wrote: | | Barry wrote: | | CIR Engineering wrote: | As soon as I saw the images you posted I was going to suggest GAME MODE to test the Gennum chip. There is a known issue where these are failing. It typically only applies to interlaced sources.
craigr |
craigr |
The problem went away for game mode but not progressive sources. It was significantly reduced for progressive sources.
Just got another XD and it projects with a shifted picture to the left by about 30% even after setting to factory defaults. I can see no adjust meant to change size or position horizontally in menus or manual. Posted the issue earlier today.
_________________ Addicted to buying cool used expensive toys...(especially CRT projectors) Barco 1209, 1208 and Elektra Espresso Maxi2 most recent additions.....
