Helpppppp zap sound but imagen on my cinemax!!!!!!
Sakharov
Posted: Thu Apr 20, 2017 8:56 am    Post subject:
Once more thank you the valuable imput, I'll check as soon as I arrive home. Meanwhile I think I'm also lacking green color. While doing the adjustment with the menus and grids the green is there but if I try to do the adjustment on the green when source is selected the green image is barely visible. What could be the reason?
Posted: Thu Apr 20, 2017 3:25 pm    Post subject:
Make sure you're on the right input of the projector, and not in component mode. It would seem that from what you say above, that it's a source problem, not necessarily a problem in the projector.
Sakharov
Posted: Thu Apr 20, 2017 8:32 pm    Post subject:
Indeed wise suggestion port 3 solved the issue. Than you so much for all your help.
You are CRT Guru:)
Sakharov
Posted: Thu Apr 20, 2017 10:03 pm    Post subject:
Although I still struggling with the focus on the blue for the perfect picture
Sakharov
Posted: Thu Apr 20, 2017 10:04 pm    Post subject:
It's focused on the tube grid but not in the screen
Posted: Fri Apr 21, 2017 12:37 am    Post subject:
OK, so this is a lens issue, and has nothing to do with the projector. The lens adjustment closest to the tube is the coarse focus, that's the one to adjust to get the picture sharp. If that doesn't work, it sounds like the lens is bad. Maybe something came loose or moved in transit?
Sakharov
Posted: Mon Apr 24, 2017 10:51 am    Post subject:
Hi Curt
Lens have been cleaned and the imaged improved significantly.
During my initial test I've notice when displaying 1080p signal on blu ray there is a band on the left side. Currently I'm using a fury 3. Strange is that on upscale dvd the band doesn't appear.
