| Posted: Tue Dec 06, 2016 6:54 pm Post subject: |
OK, let me see if I have one. Will be a few days, as they are stored away.
LBSmidtfyn
| Posted: Tue Dec 06, 2016 6:58 pm Post subject: |
I'll wait Right here:)
| Posted: Tue Dec 06, 2016 11:36 pm Post subject: |
| LBSmidtfyn wrote: | | I'll wait Right here:) |
(cues up elevator music) Hmmmm hhmmmmm hmmmmm daaa da doooooo...
LBSmidtfyn
| Posted: Sat Dec 10, 2016 10:59 am Post subject: |
Maybe someone has the schematics to this hpvs? I could try to fix it then....
| Posted: Sat Dec 10, 2016 3:55 pm Post subject: |
They were never released. Open it up and look for bad solder joints or burned resistors.
| Posted: Sat Dec 10, 2016 6:20 pm Post subject: |
| Curt Palme wrote: | | They were never released. Open it up and look for bad solder joints or burned resistors. |
Also check the heat sink compound at the transistors. I redid mind on the 4000
LBSmidtfyn
| Posted: Sat Dec 10, 2016 11:02 pm Post subject: |
I'm on it😊. Curt, did you check your storage for a replacement?
| Posted: Sun Dec 11, 2016 12:41 am Post subject: |
If you need the schematics, you might give VDC Display Systems a call and ask nicely if they might be willing to release a copy to you. They have all the old AmPro documentation and it's been so long since this stuff had any value to them that they MIGHT
consider giving you those docs. It isn't like there's any commercial value left in them at this point.
| Posted: Sun Dec 11, 2016 8:03 am Post subject: |
| cmjohnson wrote: | If you need the schematics, you might give VDC Display Systems a call and ask nicely if they might be willing to release a copy to you. They have all the old AmPro documentation and it's been so long since this stuff had any value to them that they MIGHT
consider giving you those docs. It isn't like there's any commercial value left in them at this point. |
Just like the Marquee's, the AmPro HVPS was made by Spellman Inc. who notoriously don't give out documentation, there is no documentation on the Marquee HVPS either...
LBSmidtfyn
| Posted: Sun Dec 11, 2016 10:00 am Post subject: |
I've sent a mail to Spellman Inc a couple of days ago, but so far they have not replyed. Weekend you know....
