What would YOU do with a Barco Cine 9 ?
Posted: Mon Dec 05, 2016 8:19 pm    Post subject:
ElTopo wrote:
It's a Sony VW365 not a VW350.
This is capable of HDR.
Any other input which pushes ne back to the Cine 9 ?
It seems like you are already made a decision, you just fear to admit yourself? Besides, this question pretty much sounds like debate over whether you should hang on to your classic Lamborghini or to your newer Ferrari? They are not the same, both have advantages or disadvanages over the other, but also both are pretty much better what an average person would appreciate. I think you are the only one who can decide this (based your emotions and not by specifications).
ElTopo
Posted: Tue Dec 06, 2016 7:32 am    Post subject:
It's not easy.
At the monent the Sony hangs on the ceiling.
The Sony has some advantages but also negatives.
A Cine9 throws a beautiful image with superb blacks.
Barco Cine 9 the one and only
ElTopo
Posted: Wed Dec 07, 2016 10:04 pm    Post subject:
Maybe i should do a battle between the two Wink
greg9518lc
Posted: Wed Dec 07, 2016 10:58 pm    Post subject:
[quote="gjaky"][quote="ElTopo"]It's a Sony VW365 not a VW350.
Any other input which pushes ne back to the Cine 9 ?[/quote]
It seems like you are already made a decision, you just fear to admit yourself? Besides, this question pretty much sounds like debate over whether you should hang on to your classic Lamborghini or to your newer Ferrari? They are not the same, both have advantages or disadvanages over the other, but also both are pretty much better what an average person would appreciate. I think you are the only one who can decide this (based your emotions and not by specifications).[/quote]
I sell the Es365 and it's a far cry from a good 9" crt but what do I know :mrgreen:
Posted: Thu Dec 08, 2016 3:56 pm    Post subject:
A 909/Cine 9 is one of the true top gun CRT projectors ever made. If you have one, you should definitely give it a trial in your home theater and determine for yourself what you think of it.
It should not even be difficult to install the Sony projector right below it (it's a lot lighter, you know) so you can A/B compare both projectors on the same scren. Then you will KNOW.
And then you make your decision. Sell the loser, keep the winner.
You can do the comparison even if you end up putting the 909 on a table below the installed Sony unit. For comparative purposes this is quick and easy.
ElTopo
Posted: Fri Dec 09, 2016 5:13 pm    Post subject:
Cine9 back online.
Sony on the ceiling Barco on the floor.
ElTopo
Posted: Tue Dec 13, 2016 2:44 pm    Post subject:
Some shots of the Cine9
 Filesize:  87.24 KB
 Viewed:  13170 Time(s)
 Filesize:  148.06 KB
 Filesize:  78.95 KB
 Filesize:  103.08 KB
 Filesize:  115.67 KB
 Filesize:  111.65 KB
ElTopo
Posted: Mon Jan 02, 2017 7:45 am    Post subject:
2017 and CRT is still here Thumbs Up
The build quality of the entry digitals up to 10K $ is bad.
Sony VW365 -> ceiling mounted does not focus 100% because of the chassis. you have to put it in a table/front config
Epson UB6040 -> projector shutted down 2 x times yesterday. lamp blinks. This has about 250 hours on the counter from new
cheers
ElTopo
ElTopo
Posted: Mon Jan 30, 2017 9:39 pm    Post subject:
I have the upper and lower plates of the CM100 now.
What do you think ?!
Time to put the Cine9 onto the ceiling ?
cheers
Posted: Mon Jan 30, 2017 10:37 pm    Post subject:
Nice screenshots!
Mr Jaeger
Posted: Tue Jan 31, 2017 10:11 am    Post subject:
ElTopo wrote:
True Thumbs Up
Question is going with both or let the Sony go.
Are you serious? Let the Sony go, or changed your mind?
Not that your Cine9 is bad, that's a great CRT but, its 2017 not 2000.
You don't get the same black like your Cine9, If you wanted that you should have picket a JVC with double iris. But also depends on what you favor in a picture.
Posted: Tue Jan 31, 2017 11:16 am    Post subject:
HANG THE 909.
Mount the flashlight under it.
Best of both worlds.
Yes, even in 2017, a 909 looks more real than any flashlight and flashlights are looking quite good these days.
Mr Jaeger
Posted: Tue Jan 31, 2017 12:12 pm    Post subject:
I would have kept both as well ElTopo
the Cine9 look good. And the Sony look good.
I calibrated a Cine9 some time ago and it looked very nice. But like someone said here do a side by side instant switch.
Then you see differences.
I want perfection, with calibrating and picture, no CRT can compete with that.
But if you have open eye to both technologies, you find positive and negative sides with both.
And if we speak about "look more real in 2017" that is that persons own opinion not mine.
I like to keep all my statements as true as possible not false or fantasy. Smile
ElTopo
Posted: Tue Jan 31, 2017 12:27 pm    Post subject:
The fade to black is still awesome on a CRT Thumbs Up
Posted: Tue Jan 31, 2017 1:45 pm    Post subject:
cmjohnson wrote:
It should not even be difficult to install the Sony projector right below it (it's a lot lighter, you know) so you can A/B compare both projectors on the same scren. Then you will KNOW. And then you make your decision. Sell the loser, keep the winner. You can do the comparison even if you end up putting the 909 on a table below the installed Sony unit. For comparative purposes this is quick and easy.
Not to sound like broken record, but anyone who wants to A/B compare a digital with a CRT should not be doing what Chris recommends. Install the digital CORRECTLY: Not directly below the CRT projector. It'll be WAAAY too close and will compromise contrast ratio which digital really needs to help when comparing the CRT projectors.
Nobody would expect to be able to do a proper A/B comparison if the CRT projector was installed twice as far back as it should and is only using 1/2 the phosphor area. Why do people recommend just installing digitals haphazardly for comparison? Do it right.
Mr Jaeger
Posted: Tue Jan 31, 2017 5:46 pm    Post subject:
Kal have a point here. Must be important,Do it right.
Both must be calibrated up to its best. If you don't calibrate ask for the correct settings on your digital. The Sony's are quit good out of the boks with the right adjustment and settings.
Light output must be putt around reference.14-16FL on the Sony or higher, you get a descent contrast.
And use what you can on the Cine9.
If you brightness match to a CRT its like killing the dynamic in your Sony Completely. Then if you are under 14-16FL.
Remember: Brightness match as good as possible 14-16FL
Gamma: same target power gamma on both. 2.4. 2.3 or what you prefer.
Check different material bright, medium, dark scenes.
Look at dynamics,sharpness, debth, naturalness, "real feeling" resolution
Your Crt will be visible better in near dark scenes, and for shore fade to black. The rest I don't need to tell you, you will experience that yourselves. for shore. If this 4K Sony have auto iris use that on auto high.
Have fun Smile
napos
Posted: Tue Jan 31, 2017 6:23 pm    Post subject:
Having experienced the panel degradation problem first hand, my advice to you is to get rid of the Sony while you still can. You really don't want to end up with a 7.000 Euro paper weight. I have completely lost trust in Sony, and no matter what they say, all SXRD panels are affected. I had the same issue with a VW-10HT, a friend of mine experienced it with a Ruby, and another friend with the VW-95ES. The projector ends up being unusable with a washed out image, and the only option is to replace the optical block or buy a new projector (which in some cases ends up being cheaper than replacing the optical block!). Have a look at the corresponding thread over at AVS Forum.
Definitely keep the Cine 9, and if you also want a digital, go with one of the latest JVC models. Since you are in Europe, the models that DO NOT have lamp issues are all those following the x35, x55, x75, x95 series (The X35 series also does not have lamp issues). Hope that helps you out!
Marquee 9500LC Ultra with MP mods, Moome HDMI 1.3 card, Lumagen Radiance XS, Oppo 83 BluRay, Toshiba XE-1 HD-DVD, HTPC with Media Player Classic.
Mr Jaeger
Posted: Wed Feb 01, 2017 6:45 am    Post subject:
Its really bad that Sony have not fixed this panel degradation problem. I've had a VW500ES and measured around 3000:1 after around 1000 hours. My Sony got more and more gray, and we don't like that much. Sad
napos
Posted: Thu Feb 02, 2017 3:26 am    Post subject:
Yes, it's really a shame, since the SXRD projectors throw a really nice image. The only viable digital alternative to a CRT projector is a JVC projector, provided it doesn't fall into the units that had lamp issues (2010-2012 models: X3 and X30 series). I currently have a JVC HD750 (RS20 in the US), which I am using in another home where I don't have a CRT installed. Very pleased with it, even if it is an older model.
pj-toso
Posted: Thu Feb 02, 2017 6:27 am    Post subject:
True. I have had a x3 since early 2011. It had some problems with the lamps in the start. Some flickering, and I had a lamp that died after 1400hrs.
I have used this projector probably over 10k hrs. When I ordered lamp number 3, things changed it was defintitve a change plenty more light output, 100% stable and very litle drift in color temp and little drop in light output.
I am quite confident that they use the same lamp has in the new projectors, but just put in the x3 lamp housing. The first lamp I had of this type I used for 4500hrs before I changed it, and I could have used it even longer.
After 10k hours, it still have good gamma tracking and contrast 35000:1 in mid-throw.
Shame about the Sony SXRD, very good projectors, especially the 1100, but how fast the degrade, it is disaster, and cant understand that people still are buying new Sony SXRD projectors.
Disclaimer: My postings are subjective and not facts.
Page 2 of 4
