Sony G90 adventure
Posted: Tue Jan 17, 2017 2:27 pm    Post subject:
I'm running HDMI straight from a Sony blu-ray player into my Marquee, via the Moome card. I get raster ringing at 1080p.
At the same settings there is NO raster ringing in the G90. Picture is clean and clear of that issue.
Interesting.
Posted: Tue Jan 17, 2017 4:20 pm    Post subject:
Interesting.
Try some other HDMs; you might find one with slight or no ringing.
Posted: Tue Jan 17, 2017 4:25 pm    Post subject:
That's one of the things I'm going to look into. But that projector is coming down anyway, as it has serious crosstalk issues or something that gives similar symptoms.
Once it comes down I don't guarantee I'll put up another Marquee. I've got all these perfect G90s just lying around....Very Happy
Posted: Thu Jan 19, 2017 3:22 am    Post subject:
Tonight I replaced the last worn tube in any of my running G90s.
This shows you how picky I am about tube condition.
The tube on the left is being replaced due to wear. The tube on the right is new, or in new condition,
and is going into G90 no. 3.
As of now I have three G90s all with tubes that are that good. Unit 4 is a "parts unit" unless I score a YA board for it
at a good price. I'd rather put it back into service than scavenge it for parts at this time
 Filesize:  198.37 KB
 Viewed:  9523 Time(s)
Posted: Thu Jan 19, 2017 4:53 am    Post subject:
One thing I really like about the G90 is that once you've got the deflection yoke levelled, that's IT for messing with the magnetics. No fiddling with CPC rings. It's a pleasure to work with. CRT changes are also very fast and efficient. I can swap one CRT in less than 10 minutes if the spare is ready to go with magnetics. Add two minutes if I have to transfer the magnetics.
gregstv
Posted: Thu Jan 19, 2017 7:57 am    Post subject:
Hey Chris, the green tube goes in the middle😃
Just looking at your avatar and could not help myself.
jbmeyer13
Posted: Thu Jan 19, 2017 2:49 pm    Post subject:
Yes- and another reason Craig loves those PJ's. IMO, the two biggest issues with G90's is that they eat tubes and have the streaking issue (I'll put YA/Dallas further down the list). Not uncommon to have wear after 500-700 hours so if it were me I'd pick Craig's brain for any tips to dial in the drive settings (Gain on a G90?) to hopefully prolong the tube life.
There's never glycol issues with G90's, no banding to deal with, superior focus system. Definitely the best out of the box projector. On the other hand a properly modded Marquee is a bit like the Millenium Falcon; it looks like a junker, can be tempermental but has it where it counts Laughing
Posted: Thu Jan 19, 2017 4:14 pm    Post subject:
The only reason G90s eat tubes fast is because they drive them hard. Back them down and tube life increases.
I've seen tubes in projectors that were original to the build, documented, with 8000 hours on the tube, and NO visible wear
on that tube. They were run at a fairly low light output level the whole time.
What gets people to drive a G90 hard is basically the fact that they retain sharpness at higher contrast levels. Who does not
want a bright sharp image? A G90 does that better than anything else but at the expense of tube life.
I'm STILL trying to find someone to wind some custom transformers for me so that I can get back on track with my project to retrofit G90 magnetics into a Marquee. My test runs showed HUGE promise for this idea to improve a Marquee's focus
performance, to actually match that of a G90, or close to it. But without those transformers it isn't workable.
I was able to prove the concept but it would eventually kill the HDM due to high current draw.
I was rather annoyed to find that the G90's 6-pole adjustment system isn't multi-zone. Central zone only. I view this as
a waste of the considerable amount of engineering that went into developing that system. I actually suspect that the 6-pole
adjustments could be made multi-zone with a software upgrade.
Posted: Fri Jan 20, 2017 11:49 pm    Post subject:
I'm up to something....
OK, I'm painting a G90 case set.
I'm doing the bottom section in full gloss black, and I'm doing that painting job myself.
The upper section is being done in the purple you see here, and that is being done by a professional because the top
cover needed bodywork to be ready for a full gloss finish.
As of the time of these photographs being taken, I've only done the black basecoat. The gloss clearcoats go on later tonight.
Clue 2: Top color.
 Filesize:  94.02 KB
 Viewed:  9371 Time(s)
Clue 1:
 Filesize:  467.11 KB
Posted: Sat Jan 21, 2017 2:25 pm    Post subject:
Having a center only CPC adjustment is only a matter of DC voltage control, having multizone CPC needs a variable ramp in both axes which result in a parabola at scan rate frequency. I can also imagine they left out this oportunity because of banal (but crucial) things like they ran out of firmware space, or there was no other control bus left on the CPU board, so that would have meant serious redesign of the digital part of the machine. Again, I don't know but, this would be a good reason.
Posted: Sat Jan 21, 2017 3:00 pm    Post subject:
Actually, 6 pole is supposed to work in every zone that 4 pole adjustments work in.
Oddly, I've followed the directions, gone into service and expert modes, and I still can't select the outer zones in 6-pole adjustments.
There's no reason to have electronic CPC adjustments using such a complex series of circuits only to replicate what can be done with passive magnets. Or coils run off DC voltages.
The 6 pole adjustment system is essentially identical to the 4 pole adjustment system.
I know I'm doing something wrong. Craig says it works, I believe him.
Posted: Sun Jan 22, 2017 6:23 am    Post subject:
I'm investing in painting a G90 case, so obviously I've decided to keep one for myself and install it.
The problematic Marquee Ultra is coming down shortly and then I re-work the ceiling mount to accept a G90.
Fortunately I do have the G90 PSS-90 mounting bracket. (Three of them, actually.)
This should be one very sharp looking projector in its gloss black/purple metallic paintjob. I've been polishing the lower cover pieces
now that I've shot them in black automotive acrylic urethane and they're going to have a show car grade finish. I should get
the upper cover back from the body and paint man who's doing that part for me on Tuesday.
The G90 top cover warps due to the welding of parts to the inside of the shell, (it's all aluminum) so for it to be good enough for
a full gloss finish, bodywork is required and that's what I'm paying for.
jbltecnicspro
Posted: Sun Jan 22, 2017 7:52 pm    Post subject:
Wow, sounds like a good paint scheme. Be sure to take lots of pics. Smile I have been debating painting my G70 as well.
thewolfman
Posted: Sun Jan 22, 2017 8:13 pm    Post subject:
I'm think I will redo my vinyl-wrap, from smurf to mean black. I'm not quite happy how it turned out so will buy some sort of glossy black. Flat is out I think. But some other kind of glossy black, to separate myself from the stock paint, and any vinyl would do really, because just by having the scratches gone makes it so nice to look at. Cool to see someone else going thru the ordeal to pimp your pj!
Posted: Sun Jan 22, 2017 8:29 pm    Post subject:
Be aware that the top cover of a G90 is not smooth enough to pull off a high gloss finish
without getting some bodywork done on it. But I do expect it to be worth it.
I've almost completed polishing out all the lower case parts. SHINY BLACK. Real "piano black" look, VERY NICE.
Of course I'll post pics.
Posted: Sun Jan 22, 2017 11:36 pm    Post subject:
Stage 1 of the repaint is complete. The repainted top cover should be back in my hands about Tuesday.
So here's a photo of the chosen recipient of the newly repainted cover set, as it stands right now.
I'm rather pleased with the work so far. I'm doing all the prep and paint work for the lower case parts, including the flat sanding, compounding, and polishing. But the top I'm leaving to a pro due to the fact that the top needed a level of bodywork that I'm not confident I can deliver. When you can't do it right, hire someone who can.
 Filesize:  324.98 KB
 Viewed:  9163 Time(s)
Posted: Sun Jan 22, 2017 11:38 pm    Post subject:
Yes, I will be blackening the gap between the lower front cover and the sides. I may do something about those grey handles, too.
jbmeyer13
Posted: Mon Jan 23, 2017 2:46 pm    Post subject:
cmjohnson wrote:
Yes, I will be blackeing the gap between the lower front cover and the sides. I may do something about those grey handles, too.
Give black RIT dye a try
Posted: Mon Jan 23, 2017 4:11 pm    Post subject:
Black sharpie marker worked fine. If I do any "real" touch-ups they'll be done with an airbrush.
I will probably paint the handles black. They're attached with two screws per handle.
justin_f
Posted: Mon Jan 23, 2017 6:14 pm    Post subject:
i second the rit dye. works great on motorbike plastics. easy to do.
looks great chris. did you spray the plastic with a can or off a gun?
Page 7 of 9
