The future of CRT looks promising
Posted: Mon Aug 15, 2016 1:23 am    Post subject:
Thanks! It certainly has!
Posted: Thu Aug 18, 2016 6:48 pm    Post subject:
So, the things are not firm still, BUT:
I am thinking on a base price around 300USD for a set of mods.
It looks like this mod will be sold in conjunction with a specially modified VIM (since a few signals need to be extracted, and the video path jumped over).
Here there are several possibilities
-For fast turnaround I'd like the VIMs to be prepared and tested in advance. The customer should send in his/her VIM regardless, since I need a VIM source for the next mod.
-If the customer does want to keep his/her VIM then I think I'd have to charge some extra, since then I need to source the VIM myself.
-I'm not sure in this, but I have a few old Marquee 9000 VIMs as well, which are not regarded as high performers, but that does not matter here since the VIM in my mod is only used for sync processing and suplementary signal generation, and the Marquee 9000 VIM could just do that, if this indeed works, this could be the bargain option (no extra costs, no VIM needed to sent in, while my stock lasts...)
I won't take responsibilty to install my mod on MP modded boards (here mostly the VNB is the concern), since I have no knowledgde what was previously made to them.
In return I might offer my own mods on the VNB itself...
lydmann
Posted: Fri Aug 19, 2016 1:46 pm    Post subject:
Will this mod come to barco too? like 1209?
Posted: Fri Aug 19, 2016 4:13 pm    Post subject:
That's the plan, obviously the main target would be 1209 and 909... For barco an auxiliary power supply needed for the VNBs, and 3 VNB is needed obviously, these will make the things more expensive.
jbltecnicspro
Posted: Fri Aug 19, 2016 9:13 pm    Post subject:
So, not to be "that guy" in this thread but. Obviously, the problem with the future of CRT is that no one is making them any more. What would it take to actually get an operation going to start rebuilding tubes again? And / or manufacturing them? Surely the patents for these tubes will expire soon-ish? Unless that happens, I'm not sure there is a future for CRT. There's basically just the last of us who still have our projectors and that's it.
Posted: Sat Aug 20, 2016 7:02 am    Post subject:
Actually manufacturing new tubes are quite expensive and ever was, not much like to pay thousands of dollars for a new tube. Also I think there are still plenty of tubes out there available, in fact more people leave the CRT camp these days, than how much tubes get used up...
greg9518lc
Posted: Sat Aug 20, 2016 2:30 pm    Post subject:
The reason CRT is so promising is there still development on perfecting
the perfect video chain. The other reason is that there is no other option
for picture quality. Sony 4k is just plain awful and JVC is a better option
but still no match for modded crt projectors. I sure I will get flamed for these
comments but I call it as I see it and sell these digital's for a living.
Screenshots can never do crt justice the camera is the weak link but is easy to
capture a digital projector because of the limitation of fixed pixel display technology.
Hence the words GOT PHOSPHOR "Hell Ya" GOT LAMP THRU A PIN HOLE "Hell No"
Now the best part is now it includes Barco guy's being able to receive let's say a clarity
mod that will take there projectors to another level.
So I am that guy that has faith in the future of crt. Doesn't hurt to have plenty of spare tubes and chasis to get me
thru the next 20 years.................
xmob135lc
Posted: Sat Aug 20, 2016 3:52 pm    Post subject:
Someone , somewhere will make a single tube projector , have faith. Especially because we are not under the constraint of signals coming out of VGA connector without even line buffers anymore (luckily I might add) .Smile
Posted: Sat Aug 20, 2016 4:06 pm    Post subject:
greg9518lc wrote:
Screenshots can never do crt justice the camera is the weak link but is easy to capture a digital projector because of the limitation of fixed pixel display technology.
I'm afraid that part in bold doesn't make any sense.
All projectors (digital or CRT) long ago were able to produce more 'stops' than any camera could capture. (Stops in photography directly translates to contrast ratio in displays). The best SLRs today can capture about 9, maybe 11 stops which is much less than even lower end digital projectors can produce in terms of contrast ratio.
The fixed pixel nature of digital projectors has nothing to with it.
The camera is always the weak link when taking screenshots, regardless of the projector type used.
xmob135lc
Posted: Sun Aug 21, 2016 2:43 am    Post subject:
Well, I wouldn't say it's because of fixed pixels, but because panel type projectors in use have whole frame time lit , basically still pictures and crt has great motion handling with its line by line update. There is no panel projector with a light engine suitable for per pixel dimming because of this reason. On the other hand not even crt-s truly have it because of overlap. It's even difficult with lasers & low drive voltages nevermind crt-s with hundreds and slow phosphor.
jbltecnicspro
Posted: Sun Aug 21, 2016 12:10 pm    Post subject:
I agree that it's awesome that folks are continually improving CRT projectors. Don't get me wrong. I would also take a quality CRT any day over a digital - no question about it. However, the fact that only a handful of us would appreciate these upgrades (and even less of us will actually purchase them), I don't know - I just wouldn't consider CRT alive and kicking. And good for you that you still have a stash of good tubes. Very Happy I don't. By the time I decide to actually move to a 9-inch set, they may all be gone. Sad
I belong to a thread on [H]ardForum dedicated to the GDM-FW900 monitor, and while there are a few of us hold-outs still kicking, most of the world has moved on. So much so that newer video cards are no longer coming out with analog output. What our community needs is a Moome or someone similar, to help build us some HDMI interface boards so that we can continue to use these guys. But alas, no one will step up to the plate.
jbltecnicspro
Posted: Sun Aug 21, 2016 12:17 pm    Post subject:
For that to even be technically feasible, you would have to have a SUPER low dot pitch. Otherwise, you'd wind up with projectors with a 24-inch tube! Shocked
Tightest monitor Sony ever made was the GDM-F520 and GDM-F500R. At 0.22mm horizontal "stripe" pitch, they can resolve around 1800 lines. So even this monitor cannot fully resolve 1080p. The GDM-FW900 can but only on the merits of its size (it's a 16:10 widescreen monitor). If the F520 had a widescreen counterpart, then its resolving power would be probably similar to that of the G90. Still not much of an improvement.
Actually - I did the math - at 0.22 the FW900 would only resolve about 2100 lines. So still short of the G90.
Posted: Sun Aug 21, 2016 2:46 pm    Post subject:
Screenshots can't do justice to the original image, not ever, as long as the screenshot ends up being displayed on your PC at a lower resolution and bit depth than the original image. Between being cropped, resized, and compressed at various stages, no screenshot you are likely to make or post or see is going to measure up to the original image.
xmob135lc
Posted: Sun Aug 21, 2016 3:33 pm    Post subject:
That's too obvious and no solution (quixotism), cause you loose size/weight advantage of single tube. For a while I also thought two tubes (one patterned) is the min for R+G+B projection but alas no, there are in fact multiple ways to do it.
greg9518lc
Posted: Sun Aug 21, 2016 3:47 pm    Post subject:
I agree 100% but they can show a lot of what's on screen. That's why I switched to the Oppo 103D screenshots are a lot
Closer to what's on screen but of course way better in person hence the meet and showdown vs digital 😀
greg9518lc
Posted: Fri Aug 26, 2016 1:48 pm    Post subject:
Let the Beta testing begin looks like the boards have arrived are starting to be installed so we should
have some feedback soon. Look forward to some updates from Gjaky and his beta tester real soon.
Posted: Sun Sep 18, 2016 8:10 am    Post subject:
I built a daughterboard again. And did some performance measurements.
On the first picture you can see the input "pulse", it equals one pixel at 1080P 72Hz. It does not look really square, but in fact my pulse generator has bandwidth well over 500Mhz, and my 275MHz oscilloscope is also much faster than any CRT amplifier can ever be.
The pulse fills 6 divisions vertically:
This is the output signal shape of the daughterboard, it fills 5.8 divisions vertically which equals to -0.3dB rolloff at 1080P 72Hz.
Of course in the end the whole signal chain have to be tuned together for the best bandwidth, these shots are for only demonstrating the raw power of this preamplifier.
Posted: Sun Sep 18, 2016 5:45 pm    Post subject:
Good points here, and great results for a near flat response.
How are you loading and what are you using to test the final out of the preamp?
Posted: Sun Sep 18, 2016 6:02 pm    Post subject:
The output of the preamp is loaded with a simple 75Ohm SMD resistor (as normally it would connect to VNB's input)
On the bench I use an EMG 12563 pulse generator (It's Hungarian made instrument up to 300MHz, with <750ps rise time) or either a PC video card, the output is probed with a HP1120A 500MHz FET probe (with the appropriate divider used according it is a CRT out or preamp out stage).
With the projector it's motsly SMPTE resolution pattern and Ecrabb's multistep resolution pattern, and some standard materials like Baraka and Oblivion and so on.
Posted: Mon Sep 19, 2016 12:02 am    Post subject:
Guys
Waveforms on test gear are not what matters. The image quality on the screen is what matters. Good luck in your endeavor.
Page 2 of 7
