Meet/Gjaky/Marqueeboard thread!!!!!!!!!!
Goto page Previous  1, 2, 3 ... 8, 9, 10, 11, 12  Next
Posted: Wed Aug 31, 2016 6:55 pm    Post subject:
Mike has made so many different versions of his mods that you can't say exactly what's going on with his mods in any specific terms
unless you address a specific modded board.
But in general he's upgrading ampliifier stages and improving the quality of the power supply voltages to those stages, and enhancing bandwidth thru a combination of replacing amplifier ICs and related components with higher quality components.
Component values are also adjusted to increase bandwidth.
On some boards, it's obvious he's adding more DC power filtering.
That's not black paint, it's black epoxy. On some chips that he replaces, he even removes the manufacturer's markings so
you'd have to guess what chip he ended up using.
greg9518lc
Posted: Wed Aug 31, 2016 8:19 pm    Post subject:
racerxnet wrote:
cmjohnson wrote:
Please reveal what you have found regarding what versions of Marquee neck cards work best with LUG tubes,
and if possible show pictures of the version that works best.
I'm NOT asking you to reveal the new modded cards, just identify and show the "stock" type of card that is best for LUGs.
You would think with the dying CRT that information about picture improvements would be shared.
Max you want the old style boards for your 8500
I will spill the beans but the answer is not so clear.
Fact went thru 21 neckcards for lugs and was only able to match up 3 sets of 3 neckboards
Also it took 50 hours to match these neck cards sets and rate them A, B+ and B the other 12 boards are sh*t. What
are the chance your boards in your Marquee or VDC are very good? I would say no chance in hell of that happening.
So if you want a great set of boards and put the time in and you will be able to have a better picture. My A set of
boards track and focus better than any modded board I have tried and for lugs have the most output. It took 21
boards to come up with this one set.
The answer in short buy a ton of boards and test them why do you think me and kurt have so many projectors Mr. Green Mr. Green Mr. Green
Posted: Wed Aug 31, 2016 8:56 pm    Post subject:
Could you possibly just be a LITTLE bit more precise, please?
Let me cite an example:
"I have found by testing many boards that all of my best performing boards with LUG tubes came from the 50-2038-01P Issue 1 board type. Not every board of this type is that great. No top performing boards with other part numbers have been found."
Something like that. Something very clear, very specific, and tells people which boards to START looking at. Some real actual
searchable data. THAT is what is needed.
Just off the top of my head, I know that there are boards in type series 2000, 2005, 2013, 2038, 2039, and the newer 2040 and 21771 types. I'm fairly sure the OLD boards, the 2013 and below series boards with the two metal can transistors, are out of the running. But the other types are the ones most likely to be found today and we need to know which ones are most promising
and are at least candidates for repair and rebuilding if not modification.
Posted: Wed Aug 31, 2016 9:04 pm    Post subject:
I think if we talk about LUG tubes and the least intervention to get them perfect only the new VDC boards come into play, for LCP the 2039 is what you'd want.
jbltecnicspro
Posted: Wed Aug 31, 2016 9:10 pm    Post subject:
Honestly - a Spring 2017 meet I would be down for. I've never done a CRT meet before and would love to get in on it.
greg9518lc
Posted: Wed Aug 31, 2016 9:19 pm    Post subject:
Preferred lug boards stock[img][/img]
greg9518lc
Posted: Wed Aug 31, 2016 9:32 pm    Post subject:
This is what you look good luck
Posted: Wed Aug 31, 2016 10:09 pm    Post subject:
Greg, what do you mean the other boards are 'sh*t'? While I've worked on dozens of Marquee neck boards and repaired them, I haven't seen quality or performance vary between boards as radically as you say they do. I'm happy to spin this off into a different thread if you want, we're sort of off topic here.
First off, I can't see neck boards affecting focus. Do you mean sharpness? I can see some of the older Motorola transistors causing issues, in fact they were a root cause of the significant streaking in many cases, but some better precision as to the issues as CM says would really help here..
Posted: Wed Aug 31, 2016 11:15 pm    Post subject:
See what I'm talking about, regarding a lack of information?
So there's an unlabelled photograph of PART of a circuit board to look at. Who here knows what they're seeing?
I just so happen to have ONE matching board, a VDC made 50-270340-01 board here, also identified by VDC's part number 65518-01, so I can tell that's what it is, but my board doesn't have that added resistor. Since the photo isn't even of the WHOLE board, I can't TELL if there are any other changes made referenced to my board.
Now, the idea that a Tse (Scott Edwards) designed 0340 type neck board has superior video bandwidth to a 2038/2039 card
is absolutely ludicrous, and that's what Scott himself has said, both here on this forum and to me personally. These "new" cards were made strictly because the Motorola MRF548 and MRF549 power transistors became UNAVIALABLE. They are NOT better bandwidth video amp cards, in fact as per Scott's own comments he says they're "good enough for our simulation customers" but in no way are they better, or even equal to, the 2038 and 2039 type cards. The power transistors used on these newer cards do not have the bandwidth or power delivery capacity and Scott told me that at high IRE levels (much above 60 contrast in a normal setting) you can expect them to stop tracking correctly.
I'm going to go with the considered opinion of a very experienced professional electronic engineer who DESIGNS CRT video projector circuits including these cards.
Now, Curt, please do note, focus potential is very much affected by how all the electron gun elements are connected and controlled, and as is evident, they ALL are connected thru the neck card, so it IS possible that in fact these newer cards could be accidentally very sharp in terms of being able to resolve a small spot size and scan line as they may simply have support circuitry connecting to all electron gun elements including G1, G2, and G3 in the case of LUG tubes, which, whether by accident or design, is more optimal for best focus than what is present on the older cards.
That being POSSIBLE, I also specifically asked Scott if he made any design change to tailor the "new" (remember, these were designed about 10 years ago) cards for more optimal control of the grids. He replied to me that he did not have any such intent in mind when he designed these cards. He pretty much just copied the existing circuitry as it pertains to control of G1, G2, and G3 for LUGs.
IF these are in fact sharper in terms of focus, then the two most likely reasons for that is (A) these cards are not less than 10 years newer and thus have that much less component ageing and drifting to work against them, and (B), it's just a happy accident of the design. Something in the layout of the card may optimize circuit constants, as a supposition.
So let us establish, for certain, that there is a difference between sharpness of focus (electron beam spot size) and resolution capacity (ability of the electron beam to be modulated at a high rate and achieve a target MTF value over a time constant, expressed as a length of scan line on the screen.) and one is NOT the same as the other.
Breaking it down to the essentials, ultimately there are just THREE essential factors at play: Intrinsic sharpness/focus of the system, video system bandwidth, and modulation. (Greyscale tracking.) Intrinsic sharpness is a SEPARATE issue of its own,
while bandwidth and greyscale tracking are inseparably related.
To properly evaluate any video card, you must independently evaluate focus apart from bandwidth and greyscale tracking. They are completely different, and UNRELATED, systems, aside from the fact that they can all be affected by different portions of the same video neck board.
So, YES, it is possible that the newer cards may yield a sharper beam spot. But that does not mean they'll RESOLVE better.
And in fact, it may simply be that your older 2038/2039 cards are the victims of component ageing and can be refreshed if the aged components can be identified and replaced.
In fact I have a pretty good idea of how to do that. Replace all the yellow surface mounted tantalum capacitors with fresh ones of the same values, and replace the reservoir electrolytics, which everybody sort of knows about, but don't go crazy on making them bigger or raising their rated voltage. They only run on 85 volt rails and if you use 105c rated capacitors rated for 100 volts at the original 22 µF values then the caps will last for their rated lifespan. While going to a 150 or 160 volt rating is considered desirable by some people, no responsible electrical engineer will tell you that this is necessary or that it is by itself going to improve performance of the circuit.
Tantalum capacitors do age. Their value changes as they age. Same applies, of course, to aluminum electrolytics. But while changing the electrolytics is commonplace, who bothers to change out the tants? Do it, and I predict the circuit will run a bit better. And of course, check for ring cracks and evidence of overheating at the solder connections of the two big power resistors.
Techno-diatribe completed.
greg9518lc
Posted: Thu Sep 01, 2016 4:57 am    Post subject:
Insults on poor quality control in the fact these boards were designed to work for
lugs not be used in Hometheater and any type of picture quality. So when it takes
many lug neck boards to make 1 good set am I hurting VDC feelings?
Posted: Thu Sep 01, 2016 1:37 pm    Post subject:
See Greg, you're throwing insults again, both at VDC and myself.
jbmeyer13
Posted: Thu Sep 01, 2016 1:56 pm    Post subject:
This is why I personally never bothered chasing down a set of these VNB's. Scott told me the same thing via email some time back and being that he designed them that was enough for me. Nash has like 50 blank cards sitting in his workshop and never bothered procuring the remaining parts to complete them.
To Greg's point, I know that Kurt went through countless neckboards to find a uniform set. There's other people (like HK Steve) who used to test the values of EVERY part to assemble uniform components. I have no doubt that this will produce the best possble PJ but it also takes the right diagnostic tools, excellent skill at soldering tiny SMD's and of yeah TONS OF TIME. All comes down to how far do you want to go?
Seeing this thread reminds me of one of my first posts on this forum where I asked what the ultimate marquee would be and CJ responded by saying he'd start with Chris Stephens mods, then MP's video chain and frankenyokes. 6-yrs later that is pretty much what I have (all though I didn't stuff wet tants on everything and susbstituted poly film caps in certain circumstances). The combination of all of these really work together to produce a nice overall product.
Having said all of this, I'm always interested to see a new development/improvement for the Marquee. Hopefully everything pans out with Gabor's mods.
greg9518lc
Posted: Thu Sep 01, 2016 3:03 pm    Post subject:
Voldermort who can't be mentioned has around 75 neckcards and I have 36 and have been matching sets up
for Gijaky's mods so they are uniform and the same every time everytime. Here is a pic of a few more.[img][/img]So we believe the sets must match and have excellent focus and
linearity before the boards are modded. I think Voldermort has a pretty good idea to fine tune a set of neck cards.
Curt sorry if I ranted and a little sore but still waiting on my refund and parts from MP and sparking interest that
there are other options out there hence this new title change.
Posted: Thu Sep 01, 2016 3:17 pm    Post subject:
Incidentally, I think that anyone who cares to investigate deeply will find that the largest variance between neck cards of the same type
will be due to the fact that the power transistors were NEVER matched to each other. So there is a significant variance from one card to the next.
I'm sure several people have seen this. If you replace a neck card you almost always will have a noticeable color imbalance and will have to recalibrate because of it.
Now, if this was 1997, you could buy trays full of new transistors and match up sets of them and when you have nine matched pairs that all are matched to the same values, you could be assured of having the best base to start from. But that is impractical and even if you have boxes full
of spare cards with good transistors, it'd be a huge amount of work and there's always a chance of breaking the leads off the transistors during
removal. They are rather delicate.
Posted: Thu Sep 01, 2016 5:36 pm    Post subject:
cmjohnson wrote:
In fact I have a pretty good idea of how to do that. Replace all the yellow surface mounted tantalum capacitors with fresh ones of the same values, .
there's much better choices today than those little yellow tants from the 90's. The new Panasonic SMD ALum. electrolytics will fit the trace, are much more durable, have a much lower ESR, and most importantly have a much, much flatter impedance curve than Tantalum. Careful though, the polarity markings are the opposite of tantalum (tants striped on positive, AL on negative).
Also, the small yellow Tantalum that couples the video , there's some really nice SMD oscons or even Hybrid Tantalum/Organic Polymer that are super stable at higher frequencies you can put here.
actually, the circuit schematic calls for a 160 Volt rated cap here and the 100v appears to be a manufacturing defect. There's lot of the ripple on the 85 volt rails.
Speccing the cap voltage rating at double the actual rail voltage is fairly typical in circuit design, although as power supplies get better this becomes less necessary
Posted: Thu Sep 01, 2016 7:03 pm    Post subject:
Dang, my latest emails with you indicate and I have package a set of neck boards to send to you, but since your latest revelations with the various neck boards being different and out of the bunch you have found a miracle set. Let's get you your refund and send your power supply back and VIM back to you. When the wife gets back we'll get on this, and you should have it in the next few days.
Now, concerning these neck boards, for which most of you know I know what;s going on with them, but have kelp things under my hat. Don't forget my trip to VDC some years back and that I've also had some boards sent to me.
Anyway, those VDC boards are all the same. The only real difference between them is minor (I'll speak on that in a few), with the big difference being the set they made that had the specially manufactured replacement for the Motorola transistors. All of the other VDC boards are near exact with the exception of the final diode (before CRT) section.
The resistors on the top of the boards is only a board revision, because some of the other boards also have the same resistors, but they are on the other side of the boards.
Some have a single diode on the final (G1), with the others having a diode before G1 and Cathode (both).
If there is any noticeable difference it would be the difference because of the change over time in what they used for the diodes, or if it's one or both.
The rest of the VDC boards with the exception of a few board designs because of the diode differences are technically the same.
And as CJ pointed out, these VDC boards are replacements for the original Electrohome design, and according to to VDC (Scott) and as CJ also pointed out they are not better than the Electrohomes by any means, to also point out that there are other problems with these boards with the original design. So thinking you're going to find a good matching pair among them, that would get around a few of the other problems they ALL have is simply wishful thinking. And I'm just like CJ, basing this on what VDC said about them, and the fact I was there at one point and knew about what was going on with them. There are things I've never spoke about concerning my visit to VDC, but most of you already know these boards have issues. And the type of issues the manufacturer claimed they have cannot be solved by finding the best in the barrel as if you're looking for the best apple.
Of course I could be wrong, but just like what CJ and some others already have read and know about these boards. The were reported to NOT be better than the Electohomes. And that's according to Scott.
my .02
Posted: Thu Sep 01, 2016 7:07 pm    Post subject:
Oh, I forgot to mention that they changed the small electrolytics on them. Some boards have the shorter size (mini0 caps. with the others having the more standard taller caps
Posted: Thu Sep 01, 2016 8:07 pm    Post subject:
I just want to add here that I am always willing to purchase ANY....ANY....surplus Marquee neck boards as long as they have usable Motorola power transistors on them. If it has even ONE of the MRF 548 transistors on it and it's not apparently damaged, I can use it.
I have a pile of 2038 and 2039 neck cards that are perfect working cards other than the fact that some of them were previously robbed of those transistors before I got them.
So if you have spare Marquee neck cards, I'm buying. ANY version that has the Motorola transistors.
greg9518lc
Posted: Fri Sep 02, 2016 2:26 pm    Post subject:
How much per board?
Posted: Fri Sep 02, 2016 6:30 pm    Post subject:
CurtPalme wrote:
I don't really think that's it. There's been more hostility between CRT owners, bashing each other and digital guys in the last 2 years or so than there has ever been in the 18 years that I've been involved with CRT online.. I think that's affected who would show up at a communal meet.
That wasn't the case when Cliff was hosting the meets, at least that's my perception.
I think you may be getting old and losing your memory, Curt. ;)Cheers,
yeah no kidding, I can't believe anyone could forget some the really nasty arguments about stupid stuff , like home theater for instance, over at AVS. All the closed threads, all the people banned and kicked off,
Remember Kaiser Sauce? or the "former CRT experts sell out to Digital thread" that turned into an 80 page sh*t-show before they shut it down?
At least here we keep all our dirty laundry in the OT forum where it belongs and everyone gets along pretty well in every other section of the forum. There was one exception in the CRT forum that resulted in the 2 of the only 5 bans (ever), but it's an anomaly.
I think overall people here are very well behaved and this forum is probably the only reason anyone is using CRT anymore.
Proud of you guys Wink
Page 9 of 12
