ElTopo
| Posted: Sat May 14, 2016 6:48 pm Post subject: |
Are there still guys out there which tweak a Cine9 for perfection ?
tschaeikaei
Joined: 08 Apr 2013 Posts: 490 Location: Germany/Saarland
| Posted: Sat May 14, 2016 8:25 pm Post subject: |
So how many fans does a 909 /cine 9 have in total?
_________________ Marquee 9500U edgeblend P43 | NEC 9PG
Hulio
| Posted: Sat May 14, 2016 8:42 pm Post subject: |
| ElTopo wrote: | | Are there still guys out there which tweak a Cine9 for perfection ? |
There are but they won't do it anymore. The former Barco UK installer will only help me because we are good friends.
Hulio
| Posted: Sat May 14, 2016 8:46 pm Post subject: |
| tschaeikaei wrote: | | So how many fans does a 909 /cine 9 have in total? |
Seven, in fact. Three big ones on the rear, two smaller in front and a tiny one mounted on the PFC board.
tschaeikaei
| Posted: Sun May 15, 2016 1:06 am Post subject: |
I was thinking about if it was worth modding the cooling system of the 909 with the fan controller i develloped.
The fully digital individual temperature controlled linear thing i wrote about in the other thread.
It has 6 channels, but you could connect two fans two one channel.
If there is interest, let me know.
Regards, Julian
| Posted: Sun May 15, 2016 4:52 am Post subject: |
| huggy wrote: | | km987654 wrote: | | huggy wrote: | | This is my only gripe with the 909s, bloody fan noise, I have mine sealed in a huge hush box which diminishes the noise but man its a pain in the ass to get to them when the quads go. I'd jump on a couple of cine 9's in a heart beat if they came up to replace these. |
Isn't fan speed determined by firmware? There have been a few discussions on this matter and I believe the consensus is that fan speed doesn't require any new hardware just the right firmware.
So this should be just a matter of flashing with the right firmware.  |
Thanks Keith
Hows your conversion going with those chassis?
Dave |
I have built one 809 and I am using that set. I really don't like the barco LC lens flapping though, its not as precise as the G90. I am thinking of putting the G90 LC setup in the 809 but thats a cut and paste exercise.
huggy
Joined: 02 Aug 2008 Posts: 927 Location: Melbourne,Australia
| Posted: Sun May 15, 2016 5:58 am Post subject: |
Yes I agree, The lens flapping is terrible, still havent got mine right but I just cant be bothered anymore.
_________________ Proud owner of stacked 909's on a 12 ft wide 16:9 screen.
ElTopo
| Posted: Sun Sep 18, 2016 4:46 pm Post subject: |
anyone out there tried to flush the Firmware in a BR909 split pack Version 3.11 to a Cine9 Version 2.21 or 2.2 ?
Should work ?
cheers
ElTopo
ElTopo
| Posted: Mon Sep 19, 2016 3:26 pm Post subject: |
I ask because the SEMU board is still mounted in the 909 tray.
Has anyone seen a Cine9 with a SEMU board running ?
gregstv
| Posted: Mon Sep 19, 2016 7:41 pm Post subject: |
I removed the SEMU board and flashed the 919 with Cine 9 firmware. Not sure if the firmware supports SEMU or not.
Francisco
Joined: 05 Apr 2007 Posts: 305 Location: The Netherlands
| Posted: Thu Sep 22, 2016 9:20 pm Post subject: |
I did and it's good, no need to modify anymore. This week I've seen a 2.5 hundred thousand home cinema with a awfull looking digital Sony pj so I'm fine as is. Just take all semu sh*t out no need for that. It runs with your current software version. Why risk distroying your controller with cine9 sw. Plus with your current sw you can go higher resolution.
_________________ Philips vacuum cleaner | Trystar double toaster | Car radio with orange plastic memory arrows | Class A Fridge
ElTopo
| Posted: Tue Sep 27, 2016 5:19 pm Post subject: |
@Francisco: Thanks. You are running the Barco 909 firmware ?
Anyone tried a Cine9 controller (controller only and not the whole tray) in a BR909 or BR909
split pack?
cheers
ElTopo
ElTopo
| Posted: Wed Sep 28, 2016 3:48 pm Post subject: |
It must be the missing fan controller boards because the controller runs in a Cine9 chassis/tray.
ElTopo
| Posted: Thu Sep 29, 2016 5:45 pm Post subject: |
A short update.
I put the controller back into a BR909 chassis but this time i connected also the SEMU board which was connected before i flushed it.
Guess what !
Projector starts and the middle fan in the back is offline (like it should on a Cine9). Also access to the menu
