BR909 discussion thread / 909 jumper for fan control ?
ElTopo
Posted: Sat May 14, 2016 6:09 am    Post subject: BR909 discussion thread / 909 jumper for fan control ?
Guys,
is there a jumper in the 909 which forces full fan speed from the beginning ?
So maybe i can put that jumper out for 'normal' operation.
thanks
ElTopo
Barco Cine 9 the one and only
huggy
Posted: Sat May 14, 2016 7:10 am    Post subject:
Oh youre talking about that airplane mode fan Very Happy
The 909 sound is tolerable until that kicks in.
Proud owner of stacked 909's on a 12 ft wide 16:9 screen.
ElTopo
Posted: Sat May 14, 2016 7:34 am    Post subject:
Not in the other one's i got.
These run full speed from a cold start !?!
huggy
Posted: Sat May 14, 2016 7:46 am    Post subject:
Mine start off very silent then they kick in after a few minutes
ElTopo
Posted: Sat May 14, 2016 7:54 am    Post subject:
Soft version 3.11
I'll have to pull out the front tray and check the jumper locations.
For example there is a jumper location to force the SMPS at startup so there might be one for the fans.
As you said the normal behaviour is more or less silent at startup and then when temp rises the fans are spinning faster.
huggy
Posted: Sat May 14, 2016 8:01 am    Post subject:
This is my only gripe with the 909s, bloody fan noise, I have mine sealed in a huge hush box which diminishes the noise but man its a pain in the ass to get to them when the quads go. I'd jump on a couple of cine 9's in a heart beat if they came up to replace these.
Posted: Sat May 14, 2016 9:12 am    Post subject:
Isn't fan speed determined by firmware? There have been a few discussions on this matter and I believe the consensus is that fan speed doesn't require any new hardware just the right firmware.
So this should be just a matter of flashing with the right firmware. Thumbs Up
Hulio
Posted: Sat May 14, 2016 9:27 am    Post subject:
The jumper S1 on the focus board R7631395 should be set to +FAN instead of +12vFAN (this jumper is to be found close to the front fans-connectors).
However, if your focus board is the older style R7631391, you won't find any jumper there. This will take care that the front fans won't spin at constant full speed.
On the rear, only the outer fans should spin at startup. The middle one (horizontal board fan) is SMPS driven and will start spinning when the temperature is increasing.
Hulio
Posted: Sat May 14, 2016 9:32 am    Post subject:
[quote="km987654"]
True, but only with older firmware. Version 3.11 will be ok.
ElTopo
Posted: Sat May 14, 2016 10:39 am    Post subject:
Thanks Hulio will check that Mr. Green
ElTopo
Posted: Sat May 14, 2016 11:07 am    Post subject:
BTW these two 909's are equipped with SEMU boards and with HD10R5M lens.
Anyone interested in the lens sets ? I don't have a dome config Very Happy
Will post in the sell section.
huggy
Posted: Sat May 14, 2016 11:49 am    Post subject:
Thanks Keith
Hows your conversion going with those chassis?
huggy
Posted: Sat May 14, 2016 11:56 am    Post subject:
BTW Eltopo
You going to stack or blend these puppies? What size screen you thinking if so?
ElTopo
Posted: Sat May 14, 2016 12:05 pm    Post subject:
Well i had the plan to blend but never realized it.
Now i got these two Cool
Screen is 3,32m in width in 2.40 aspect ratio.
Maybe i should do it ????
huggy
Posted: Sat May 14, 2016 12:09 pm    Post subject:
sh*t yeah dude, on that size screen a stack is a must. The pop that comes from it is ridiculous, I run both at 85 contrast and its brilliant.
ElTopo
Posted: Sat May 14, 2016 1:25 pm    Post subject:
On 2.40 i should blend otherwise i'm loosing light output.
This will heat up the room for sure Embarassed Laughing
ElTopo
Posted: Sat May 14, 2016 3:08 pm    Post subject:
Switched the jumper S1 and guess what the Barco is silent Thumbs Up
Hulio
Posted: Sat May 14, 2016 4:24 pm    Post subject:
Well done.
ElTopo
Posted: Sat May 14, 2016 5:18 pm    Post subject:
@Hulio: What setup are you running ? Single Barco ?
Hulio
Posted: Sat May 14, 2016 6:11 pm    Post subject:
Yepp, single Cine 9 configuration on 210cm wide screen (lot of punch in total darkness). At the moment it is not set up to the best of his abilities. I changed the tubes with new ones and waiting for a professional setup and gray-scale in the next months.
