Barco RGB Output Amp R7621195
Posted: Sun Feb 28, 2016 6:53 am    Post subject: Barco RGB Output Amp R7621195
These are the big black RGB output amps from the 1209 series projectors. Does anyone have the schematics for these.
Thanks Thumbs Up
Posted: Sun Feb 28, 2016 8:49 am    Post subject:
Can you share a photo how it looks closer? I always looked for the schematics of these -without success...
All I knew these use a push-pull output stage, perhaps VPA13s in them, if so these should outperform every other Barco neckboard...
Posted: Sun Feb 28, 2016 9:31 am    Post subject:
Thumbs Up
redfox001
Posted: Sun Feb 28, 2016 9:58 am    Post subject:
Vpj08b on the cine8 809 and version vph06 on the earlier I am afraid 75MHz or so
image by Radio Head, on Flickr
redfox001
Posted: Sun Feb 28, 2016 10:16 am    Post subject:
This guy could mod the vph06 or vph08 itself to 2SA1406 2SC3600
http://www.curtpalme.com/forum/viewtopic.php?p=390438
redfox001
Posted: Sun Feb 28, 2016 10:44 am    Post subject:
Both on ebay and how difficult can it be to make a small print that fits the heatsinc with the right parts?
redfox001
Posted: Sun Feb 28, 2016 10:52 am    Post subject:
There are schematics of 1208 with vph08 I think neckboards are the same.
Posted: Sun Feb 28, 2016 11:01 am    Post subject:
I have some of these. I will take some pics when I can. Someone must have a service manual for the BG1209.
Posted: Sun Feb 28, 2016 11:03 am    Post subject:
They are nothing like the above. See attached picture below.
R7621195
 Filesize:  116.58 KB
 Viewed:  13912 Time(s)
tschaeikaei
Posted: Sun Feb 28, 2016 11:35 am    Post subject:
the 1209s uses the VPJ08B, too. Had them here, but yes, they're long gone.
Regards, Julian
Posted: Sun Feb 28, 2016 1:46 pm    Post subject:
I think the BG1200 had similar "neck boxes" which other I don't know... Greg Eisemann probably would know Smile
Posted: Mon Feb 29, 2016 6:06 am    Post subject:
Ok that neckboard is in the BG1200 from 1992, this is indeed a dual VPA configuration, we just don't know which. Would be interesting if it would turn out that a Barco neckboard from 1992 beats everything they made eversince Smile
http://www.curtpalme.com/forum/viewtopic.php?p=335186#335186
EDIT: also in plain 1209?
http://www.curtpalme.com/forum/viewtopic.php?p=392377
Posted: Mon Feb 29, 2016 6:58 am    Post subject:
I believe the same neck board was used for the 1200 and 1209 the only variation was for Sony or MEC Tubes.
This is a shot from Greg Eisemann where he has changed the VPA13 for a VPA18. There are two of these in this amp type.
Greg Eisemann
 Filesize:  37.13 KB
 Viewed:  13818 Time(s)
Posted: Mon Feb 29, 2016 8:08 am    Post subject:
Here is what I have. The part number is R7621191.
 Filesize:  227.65 KB
 Viewed:  13806 Time(s)
 Filesize:  236.26 KB
redfox001
Posted: Mon Feb 29, 2016 9:30 am    Post subject:
The faq tips manual section says
1209 Upgraded convergence tray, newly designed double sided circuit boards and dynamic astigmatism adjustment. New RGB end-stages.
redfox001
Posted: Mon Feb 29, 2016 9:54 am    Post subject:
It syas these where to noisy that sounds like the ad834 design for Marquee.
Posted: Mon Feb 29, 2016 11:18 am    Post subject:
How does any of this help with the schematics?
redfox001
Posted: Mon Feb 29, 2016 11:51 am    Post subject:
Send them to someone for reverse enginering. Clearly there are no schematics.
redfox001
Posted: Mon Feb 29, 2016 2:41 pm    Post subject:
I am seriously available. I could find out what the connector connect to and what voltages you need.
Posted: Mon Feb 29, 2016 8:34 pm    Post subject:
Ok if there are no schematics then that might be an option
