barcodude
Joined: 14 Jun 2014 Posts: 169 Location: The Netherlands
| Posted: Sun Jan 24, 2016 3:11 pm Post subject: |
| Curt Palme wrote: |
You will need to do a modification to the V board, this is a common issue with many Barco chassis. |
how? v size is not adjustable on the v board with pods only red and blue or isn't that what you mean?
how about to set the yokes then? just turn the yokes when the pj is on and play with it for corner focus?
_________________ Epson EMP TW700 - Projecta HomeScreen Deluxe- Denon a/v receiver - Mission highrisers -klipsch subwoofer - Samsung Bluray player
barcodude
| Posted: Tue Jan 26, 2016 7:38 am Post subject: |
question:
how do i best adjust the g2 settings without a volt meter, because their are green indicators on my neck boards saying: lights should be off in g2 mode. should i check the g2 settings menu and tweak until light is off or should i pull out a gray scale picture and tweak until 0 IRE is just visible (refrence: Basic Grayscale Adjustment for ES Tube Projectors)
gregstv
| Posted: Tue Jan 26, 2016 9:57 am Post subject: |
Maybe cheaper to buy a modified vertical board from Curt. It need to have components changed to reduce the vertical height.
As for the G2 follow the guide in the service manual. Its under setup Tips & Manuals/downloads.
barcodude
| Posted: Tue Jan 26, 2016 4:06 pm Post subject: |
| gregstv wrote: | | Maybe cheaper to buy a modified vertical board from Curt. It need to have components changed to reduce the vertical height. |
i need to increase vertical heigt, i'm on '0' now, or is that what you ment?
| gregstv wrote: |
As for the G2 follow the guide in the service manual. Its under setup Tips & Manuals/downloads. |
nope, no g2 service in the manual
barcodude
| Posted: Tue Jan 26, 2016 5:33 pm Post subject: |
| Curt Palme wrote: |
There are no LEDs on the 801. You need a calibration DVD, with a stepped gray scale: |
weird i defenetly got g2 indicator leds on the neck of the tubes, i got a perfect grayscale but the problem is the led's are not consistant only the green tube's led is lit when playing movies and somtimes black scenes look a little bit greenish but i red in a old post of somebody saying something about drifting quote: "Amps have adjustment pots for leds and these could be drifted. Resetting these you need scope." so their not realy accurate being that they were set 15 years ago.
so a unsure g2 won't damage my projector?
