Electrohome Marquee 8500 convergence drift
Martin86
Posted: Fri Dec 25, 2015 11:58 pm    Post subject:
First step buy a USB to Rs232 Converter Smile mein pc have no rs232 Port
Electrohome Marquee 8500 ( work's Fine )
Electrohome Marquee 9000 ( work's but bellows are leaking )
Barco 801s Graphics ( searching a blue tube without mask )
Barco 808s Graphics
Martin86
Posted: Wed Dec 30, 2015 10:00 pm    Post subject:
Today I have the re-initialization (50-2036-03p) made easy steps entered (without image and without RS323) after the restart, I had an image ...
stigmator are now also available Very Happy
i found the hv shut down problem on the M9000 ... the G2 lead was connected to the wrong pin ... on all 3 tubes ?!
I hope the tubes nothing happened ... Curt writes in his FAQ if the G2 line is incorrectly connected to get a spot burn ... this it not so i hope the tubes are ok
 Filesize:  83.83 KB
 Viewed:  3301 Time(s)
 Filesize:  191.76 KB
 Filesize:  156.81 KB
 Filesize:  204.38 KB
 Filesize:  202.12 KB
Barco 808s Graphics
Posted: Thu Dec 31, 2015 2:48 am    Post subject:
your just zooming right along Thumbs Up
Yes, wrong pin = spot burn but sounds like you got lucky. The HV will shut itself down if it senses and over-load, and with all 3 tubes running full blast it would definitely have over-loaded the G2 circuit.
Consider yourself lucky, wrong pin = spot burn almost every time. Anyway, you will knows as soon as you fire it up. If there is a black dot in the center of each tube then that is not repairable.
Martin86
Posted: Fri Jan 01, 2016 3:12 pm    Post subject:
Happy new year Smile
Today i Chek the m9000 put the g2 wire on the right pin an put all the old Boards from the 8500 in it
And we got a picture . No burn on the tubes Smile
Next Stepp buy new bellows Smile
 Filesize:  89.11 KB
 Viewed:  3222 Time(s)
Barco 808s Graphics
Posted: Fri Jan 01, 2016 11:13 pm    Post subject:
your lucky, you basically have a 9500LC now. The new bellows is money well spent, we're all lucky Nash got those made or these machines would be boat anchors now.
For coolant, skip the toxic Glycol and see if you can get 1 gallon of Ice Clear non-toxic Glycerin formula.
Martin86
Posted: Sat Jan 02, 2016 11:15 pm    Post subject:
Can you tell me that with the non-toxic glycerin more specific?
Mixture as above 70% ethylene glycol and 30% glycerin? Or only glycerin?
Barco 808s Graphics
Posted: Sun Jan 03, 2016 10:15 pm    Post subject:
i use this stuff straight up, no mixing with anything else
http://www.orisonmarketing.com/IceclearAF.html
not sure about shipping to Europe. there was another guy trying to get some to Europe too recently. I would check with him and see if he found any solutions to the problem of shipping over seas
http://www.avsforum.com/forum/16-crt-projectors/2254546-iceclear-af-sweden.html
Page 4 of 4
