UHD Blu Ray on CRT
Goto page Previous  1, 2, 3, 4, 5, 6, 7, 8, 9, 10  Next
redfox001
Posted: Sun Feb 14, 2016 3:54 pm    Post subject:
Mind the bandwidth pictures where made with the potting material just as I received them.
Posted: Sun Feb 14, 2016 4:12 pm    Post subject:
Guys, can we keep it civil, please? Insulting one another isn't going to solve anything. If you want to question the performance of mods by anyone, do so nicely and post pix of proof. Simply going on the attack and posting name calling is pointless.. and has gotten members banned from this and other forums.
tschaeikaei
Posted: Sun Feb 14, 2016 4:31 pm    Post subject:
If the goal of this COMMUNITY is to get the best possible result in PQ and resulution out of a CRT projector,
my vote is that everyone should work together. It is far too complex for a single person alone and
far too much work. Share your results and observations, not complaints.
So if we want to succeed, there is no point in posting offendings against a single person.
If i had a problem with anyone i would write a pm or email. Where is the point in this?
If the solderjoints are bad, resolder them. Ask the person to get some % of your money back if it's his fault.
Send the parts back if you don't like them. But don't flame in an open forum everyone in the world can read.
Regards, Julian
Posted: Sun Feb 14, 2016 4:57 pm    Post subject:
Exactly. It seems the less CRTers there are left in the world, the more nasty the community has become. Not cool frankly.
Posted: Sun Feb 14, 2016 5:05 pm    Post subject:
I agree, this personal fighting is getting out of hand. You two, please keep your dispute private. You know who you are.
Anyway, any time you're talking about reproducing true square waves, you're automatically talking about theoretical infinite bandwidth, and since the electron beam has a Gaussian polar power distribution profile, there isn't any way to achieve a perfect sharp edged, 100 percent MTF value, pattern on a CRT. Thus knowing that you can't achieve an MTF of 100 percent, this greatly relieves us of any NEED to try to get the kind of bandwidth required to obtain the theoretical but optimal 100 percent MTF.
Instead, identify an MTF value that is functionally useful to a discriminating viewer. (Assuming that only a discriminating viewer would even still be playing with a CRT projector instead of a digital viewing solution.)
At what MTF value does the one on, one off pattern achieve the level of resolved contrast that all viewers are likely to be satisfied?
When you identify that specific goal and are able to measure the MTF values of boards under test and correlate them to bandwidth requirements, then you will be able to establish the bandwidth goal that achieves it.
But this is predicated on the idea that your electron beam spot size and profile is adequately small and sharp shouldered enough to even theoretically achieve your goal.
Enginering a 1 GHz, totally linear and gamma corrected signal path is wasted effort if you don't have the spot size and profile to resolve more than a 250 MHz worst case test pattern.
You DO have the capacity to measure MTF values, do you not? It's not difficult. It essentially takes a video camera with a video output on a BNC or phono type connector, , a grid test pattern, and an oscilloscope. And you do it with a standard definition camera, not an HD camera, and the video output is plain composite video.
Ask Tse for details about his MTF measurement setup. He can tell you exactly what's needed.
redfox001
Posted: Sun Feb 14, 2016 5:07 pm    Post subject:
I objected to Mikes clame that he can modify neckboards to very much higher bandwidth than they are standard and I provided pictures for that and arguments (there are only two high bandwidth parts modified). I am leaving it with this.
Posted: Sun Feb 14, 2016 5:59 pm    Post subject:
I don't have a problem with challenging someone's claims with facts and images. I have an issue with people calling out someone else's morals and then the mudslinging starts....
Keep it technical and civil. That applies to everyone on this forum.
Posted: Sun Feb 14, 2016 8:14 pm    Post subject:
Can I get anyone near by to come by my house so that I can for maybe the 10th time in the past year, show proof TECHNICALLY and on my screen that I can modify a Marquee neck board to not only do 300mhz (using an industry standard), but can also go beyond this.
I have posted these pictures many time in the past year, to include mentioned when other forum members were here and had also witnessed this. I've also posted shots showing the actual bandwidth (the generator puts it on the pattern) based on what was shown on the test pattern. Kurt (Strids) has also witnessed this and have also mentioned it here on this forum, to include some others.
And I would like to go one further to show what is actually done on the boards that are very capable of 100% resolving that resolution.
I would like for someone to come by so that I won't have to go through this every 30 days or so for the next year here.
The neck boards in my Marquee right now, can do well with the SMPTE pattern close to 270mhz, but I rate them at 250mhz. For higher bandwidth at or beyond 300mhz, I'll be making up another set for that purpose. I prefer the 250mhz boards because they have a lower noise floor and since I'm now were near needing 300mhz, it only make sense to not go that high.
Posted: Sun Feb 14, 2016 8:23 pm    Post subject:
gjaky wrote:
That's something for the HDMI card to handle, when it comes to analog video chain bandwidth we DO NOT CARE about the pixel clock rate.
We do not, but Mike Parker does. If he can display a test pattern with 297MHz pixel clock he claims 297MHz analog bandwidth this is what bothers me how this comes?
Start from the begining, imagine a video signal that was recorded by an actual camera at 1080P 24Hz that is about 55MHz pixel clock, even frame tripled the pixel clock will be 165MHz, now because of the Nyquist theorem the signal really can't contain signals higher frequency than 165/2 (when frame tripled), and in fact they were really filtered at the time when it was shooted by the camera.
But then let's talk about square waves. square wave at frequency f0 has spectral components only at odd harmonics (f0*1, 3, 5, 7 etc.) Reproducing a square wave at f0=148MHz (pixel clock= 297MHz) have the first harmonic at 445MHz, second harmonic at 742MHz and so on... so I am still curious how did he come to the conclusion of his bandwidth is 300MHz, also really curious how one can tell by eye if the displayed pattern is in fact a sine or a square at 1 on 1 off.
Again, and since you were the one to bring this up and you did so to challenge what I posted. So in all fairness, can you respond to my request that you post here using your bandwidth formula what is the bandwidth of 1600X1200 /60hz????
Let's discuss this..
Posted: Sun Feb 14, 2016 8:35 pm    Post subject:
It is about 130MHz pixel clock, so about 65MHz pure sine bandwidth, of course your system should have a higher bandwidth than this to resolve this without loss.
Posted: Sun Feb 14, 2016 9:04 pm    Post subject:
What confuses me is that I never mentioned what bandwidth rule I was using, but I will now state that I'm using Pixel Clock for bandwidth. This is important because the standard is only a standard depending on which RULE you're using.
So I'm going by my generator and what's on the display, which is Pixel Clock. So that is how I arrived at the 300mhz for 1920X1440 75/hz. Now the Pixel clock could be more precise at 311mhz, or 297mhz as shown on my generator. But either of those numbers are very close to each other opposed to the 130 and 65 you mentioned.
And to be honest with you, I have no idea what you mean by Sine Wave bandwidth - first time ever hearing of it. Badnwidth in my mind has always been square wave related.
Here you go on the 1600X1200 60/hz - that would be simply 172mhz pixel clock period. There is no sine wave bandwidth STANDARD.
And since 1600X1200 60/hz is very close to 1920X1080P it would have a bandwidth of 186mhz
You would have to reference a standard when you mention bandwidth, and to better help you, that's why the industrial/commercial grade generators have the bandwidth on their display, which is almost always pixel clock and follows the industries standard. The more precise standard used by Chroma (my generator) is "ANALOG PIXEL RATE"
Posted: Sun Feb 14, 2016 9:16 pm    Post subject:
I am going to suggest to all of you really large-brained technical types who are involved in actual circuit modifications to settle on a measurement standard.
I suggest the most functional measurement standard: Not pixel clock, but resolution, refresh rate, and scan rate, for a defined test pattern, and give measured objective MTF values.
If you use the same measurement conditions and methodology, there will be no basis for an argument which has started primarily over a differing interpretation of signal conditions.
Incidentally, the pattern generator that Mike uses can be had for only a few hundred dollars. I just checked. There's one on ebay and it's cheap enough that I'd snap it up right now if I had much interest in doing my own research and experimentation.
Use the same generators and the same patterns and the same measurement methods and you won't have anything to argue about.
Posted: Sun Feb 14, 2016 9:19 pm    Post subject:
Thumbs Up Thumbs Up
redfox001
Posted: Sun Feb 14, 2016 9:32 pm    Post subject:
Yes correct. I think we are facing an education problem here. Lot of respect for practise people but they just do not understand what you learn at a higher education.
redfox001
Posted: Sun Feb 14, 2016 9:34 pm    Post subject:
I think you could get a 250MHz pixel clock from the neckboards. Perhaps if you are lucky you find one tuned perfect to do 300MHz perhaps a little overcompensating. But that would be standard your mods do not change that much.
Posted: Sun Feb 14, 2016 9:37 pm    Post subject:
[quote="redfox001]I think you could get a 250MHz pixel clock from the neckboards. Perhaps if you are lucky you find one tuned perfect to do 300MHz perhaps a little overcompensating. But that would be standard your mods do not change that much.[/quote]
Did you understand what Curt was saying?
redfox001
Posted: Sun Feb 14, 2016 9:38 pm    Post subject:
mp20748 wrote:
[quote="redfox001I think you could get a 250MHz pixel clock from the neckboards. Perhaps if you are lucky you find one tuned perfect to do 300MHz perhaps a little overcompensating. But that would be standard your mods do not change that much.
Did you understand what Curt was saying?[/quote]
Did you get what Gjaky was saying? Very Happy
redfox001
Posted: Sun Feb 14, 2016 9:47 pm    Post subject:
What Gjaky says is the BW number on your scope. Now if we use multiburst patterns to judge bandwidth or more general scopes I say use the sine wave number 1/2 pixelclock.
Posted: Sun Feb 14, 2016 9:48 pm    Post subject:
Did you get what Gjaky was saying? Very Happy[/quote]
Sure, he has developed his own standard
Posted: Sun Feb 14, 2016 9:51 pm    Post subject:
Page 6 of 10
