what can i do to boost picture quality on a barco 701?
barcodude
Posted: Tue Dec 01, 2015 2:03 pm    Post subject:
draganm wrote:
are you referring to the stripes, AKA "Scan lines" , as noise or is there a different noise your talking about?
If it's just scan lines, that's normal. When resolution is lower the retrace lines get bigger and more visible.
yes my noise is indeed scan lines, so that's normal ok nice! but i never had it with a standard dvd player on scart weird Confused
Epson EMP TW700 - Projecta HomeScreen Deluxe- Denon a/v receiver - Mission highrisers -klipsch subwoofer - Samsung Bluray player
barcodude
Posted: Wed Dec 02, 2015 8:04 pm    Post subject:
question:
will a gamma x work on my projector because it has a rgb input?
i'm looking for a way to boost gamma in dark scene's i looked at the crescendo systems for some stuff but it's all
discontinued
somebody Crying or Very sad
Hulio
Posted: Wed Dec 02, 2015 10:35 pm    Post subject:
Still have a X-vue box 1020. Send me a PM if you are interested.
http://www.curtpalme.com/Box1020.shtm
barcodude
Posted: Wed Dec 09, 2015 8:26 am    Post subject:
i have the option to test a box 1020 only question what will work (check the link)
barcodude
Posted: Sat Dec 12, 2015 10:32 pm    Post subject:
i have a question:
i noticed a faint after glow for a minute or two on my green tube after shutting down is that normal?
Posted: Sat Dec 12, 2015 10:56 pm    Post subject:
barcodude wrote:
i have a question:
Phosphor persistence. Fluorescence lights do that too
barcodude
Posted: Mon Dec 14, 2015 11:37 am    Post subject:
again another question:
why do projectors in my case a '7', prefer negative synq Confused
barcodude
Posted: Tue Dec 15, 2015 1:04 pm    Post subject:
yes!!! everthing is working as it should with my box and pj setup no black crush and perfect gamma!! Thumbs Up
no more tweaking for me Cool
Posted: Tue Dec 15, 2015 9:17 pm    Post subject:
only Barco's, no idea why.
Glad you got it all dialed in.
barcodude
Posted: Mon Dec 21, 2015 11:11 am    Post subject:
after watching a standard dvd movie called 'burried' i got pritty pissed off! because it's a dark movie i noticed scan lines on 1080i. After all good settings on 1080i i had to abandon it Crying or Very sad
with much greef i tried 720p and voilá the scan lines where no longer there Thumbs Up
but still i prefered 1080i's spacial resolution. 720p on blurays is ok but not as good as 1080i, but dvd's look great!
redfox001
Posted: Mon Dec 21, 2015 11:28 am    Post subject:
You have to scale the dvd to 1080i. What player do you have?
barcodude
Posted: Mon Dec 21, 2015 3:03 pm    Post subject:
samsung with no option to set resolution when scaling helaas Crying or Very sad
the only way to help my problem is to set blurays on 1080i and dvd's on 720p (switching between resolutions)
barcodude
Posted: Tue Dec 22, 2015 2:31 pm    Post subject:
after some tweaking (again Mad ) i'm still not confinced why 1080i is favoret above 720p i see no diffrence.
I'm outputing 1280x720p@60hz for blurays and dvd's 1280x720p@50hz. Even the dvd's look better!
only thing i guess is the straighn on the pj is maybe a little bit more Confused
barcodude
Posted: Wed Dec 23, 2015 2:30 pm    Post subject:
question:
can i use a harmony (universal) remote on my barco? i got the harmony 525 with software and put a barco remote into the brain of my harmony but if i use the power toggle button nothing happens?
and i found out some crystals growing between my lenses? Question
Hulio
Posted: Wed Dec 23, 2015 3:56 pm    Post subject:
No, you can't use the harmony remote. Most likely, your Barco has the old style remote control. Those works with PPL protocol, wich use high frequency band. Somewhere mid. 2000 Barco switched to RC5 protocol, wich is the common IR system for all electronics devices, nowdays.
Post a pic. of your remote.
barcodude
Posted: Wed Dec 23, 2015 6:10 pm    Post subject:
bummer Confused no wurry's everthing but my barco has put into my remote so i'm happy, and got no camera to make a pic sorry
i've got a old block of a remote that's back lit with a 9v battery
Hulio
Posted: Wed Dec 23, 2015 8:20 pm    Post subject:
Yeah, that's the old style one. But if you find a broken BV708MM or Cine 7 you can make your 701 compatible with the new remote. All you need is to change the RWI chip on the controller and the IR receivers. Plus, ofcourse, a new style remote.
barcodude
Posted: Wed Dec 23, 2015 9:17 pm    Post subject:
you read my mind Thumbs Up that's what i also thougt i'm getting a BV708MM broken and i'm thinking of swoping my lenses
and the remote because my lenses have some kind of cristals growing between the lenses (not on the tubes), and my remote is not always responding to my commands
thank's for the tip Smile
gregstv
Posted: Thu Dec 24, 2015 12:42 am    Post subject:
Curt has replacement remotes for the Barco's
barcodude
Posted: Thu Dec 24, 2015 10:11 am    Post subject:
i can buy a whole barco with remote for only 35 euros ($20) near to my home so i rather go with that one,
sorry greg but thank's for the head's up Thumbs Up
Page 4 of 5
