tschaeikaei
Joined: 08 Apr 2013 Posts: 490 Location: Germany/Saarland
| Posted: Sun Oct 11, 2015 10:19 am Post subject: Paint C-Elements? |
Hey, does anyone have experiences on how to color a clear C-Element?
I'd need two reds, but afaik they are rare and expensive.
So what i thought is this: Mix some clear lacquer with red and spray it on the lens- side of a clear C- element.
Opinions?
Regards, Julian
_________________ Marquee 9500U edgeblend P43 | NEC 9PG
| Posted: Sun Oct 11, 2015 11:49 am Post subject: |
If you could spread the lacquer evenly -as you don't, AND keep the proper color of the filter it would be a good idea.
You'd better paint the tubeface directly.
justin_f
| Posted: Sun Oct 11, 2015 2:03 pm Post subject: |
could you apply some type of 3m film instead?
| Posted: Sun Oct 11, 2015 2:53 pm Post subject: |
| gjaky wrote: | If you could spread the lacquer evenly -as you don't, AND keep the proper color of the filter it would be a good idea.
You'd better paint the tubeface directly. |
Actually I suspect painting the c-element would be better. The tube face is right next to the focal point of the lens. Any little imperfection would be easily visible on the screen. Farther from the focal point is better. E.g. you can stick your finger in front of the lens and it's basically invisible on the screen.
I've never had an LC projector so I don't have an exact picture of the geometry, but I *think* the c-element would be far enough away that it might work? But a gel film on the front of the lens would probably be better. Once (8 years ago, good lord) I did some measurements with different gels, and they really work pretty well. See http://www.curtpalme.com/forum/viewtopic.php?p=320782
tschaeikaei
| Posted: Sun Oct 11, 2015 3:26 pm Post subject: |
I've already thought that spraying might not be the best idea- but what about thinning the paint and dip the c element
into the paint? Sure the backside (convex) should be protected with a foil or something.
I'm not sure if the paint thinner (which already is in the paint without further thinning it) will damage the acrylic.
I guess they are made of acrylic... does anyone know for sure?
The advantage of painting the lens-side would be: If i put the tube back together, fill glycol and mount it in the pj..
if the thing with painting doesn't work, i'd only have to remove the paint using a cloth and thinner.
Should be pretty much failsafe if i think right.
Regards, Julian
tschaeikaei
| Posted: Sun Oct 11, 2015 3:34 pm Post subject: |
Ok, if it is acrylic, it will solve in paint thinner. Not the right way to go.
| Posted: Sun Oct 11, 2015 4:04 pm Post subject: |
This was talked about a couple of years ago. The best option would have been new correct colored c-elements. There was a guy in San Diego that thought he could do it, but declined when someone mentioned the design was proprietary to 3M.
I haven't tried, but I would think it would be a lot harder to spray the inner curve of the element than the outer. Unfortunately, you need a paint that doesn't desolve in glycol.
Another option might be to color the lenses. It has already been done for AC. Why not LC?
| Posted: Sun Oct 11, 2015 4:10 pm Post subject: |
| Spanky Ham wrote: |
Another option might be to color the lenses. It has already been done for AC. Why not LC? |
Forum member Noos@xp37+ simply put a red colour filter in front of the red lens, he reported that he barely saw if it degraded the contrast.
| Posted: Sun Oct 11, 2015 6:27 pm Post subject: |
It does definitely affect the brightness (contrast), at least with the gels I tried. You had to recalibrate after adding the gels. But it worked really well.
I'm kicking myself now, because when I tested it, I adhered the gel to the tube face with a bit of water (just for testing). I didn't like it because it added a bit of filmy distortion to the picture. At the time I didn't think about the "tube face being at focal point" issue, duh.
I suspect a gel in front of the lens would work well, color-wise. BUT it's likely to introduce internal reflections... Now that I think of it, that's probably why I stuck it to the tube face. No (or almost no) additional reflections that way.
tschaeikaei
| Posted: Sun Oct 11, 2015 9:10 pm Post subject: |
@gjaki: do you have more info on those color filters?
@gary : what do you mean by gels? do you have an example link or sth?
Thanks, Julian
| Posted: Sun Oct 11, 2015 9:42 pm Post subject: |
| tschaeikaei wrote: | | @gary : what do you mean by gels? do you have an example link or sth? |
Gary was probably referring to lighting gels. They're used in stage production and flash photography to color the light...
https://www.rosco.com/filters/supergel.cfm
Rosco filters were all the rage back in the heyday of CRT when people were applying the filters to sets that didn't have color-corrected lenses. In fact, if you google "rosco crt film gel color corrected" or something like that, you'll probably find some old threads here or on AVS were people were talking about the exact colors to use with certain sets.
| Posted: Sun Oct 11, 2015 11:30 pm Post subject: |
I am not suggesting that you do this................BUT, I have taken HD-10's apart out of desperation. They got wet in shipping.
If I were getting back into CRT front projection, I would look for the correct tint of red and green film and put it inside the lens pack. Trust me when I tell you, this is not for the faint of heart. It's like brain surgery and you should have no other choice before you attempt it. Your work has to be absolutely clean and dry. The film needs to be protected but as far away from the gun side of the tubes phosphor coating as practical. The gun side of the tubes phosphor coating IS the preferred electron beam focal point, not the tube face. What do I know? I'm just a useless HVAC guy
_________________ Chip
| Posted: Mon Oct 12, 2015 3:53 am Post subject: |
| ecrabb wrote: | | tschaeikaei wrote: | | @gary : what do you mean by gels? do you have an example link or sth? |
https://www.rosco.com/filters/supergel.cfm |
Yes -- the old thread I referenced above had a link to the Rosco CalColor filters, but that link seems to be dead now. I can only find CalColor "kits" (lots of colors) on the Rosco site, but you can buy individual sheets at e.g. http://www.stagelightingstore.com/Shop-By-Brand/Rosco-CalColor-Sheets
My old post also referenced the CalColor color numbers to get the right color correction: 4490 for red, 4430 or 4460 for green.
I don't know how the Supergel filters compare.
tschaeikaei
| Posted: Mon Oct 12, 2015 3:03 pm Post subject: |
@Gary;
So you say there is two options on green.
Which one would be best for P43 fast phosphor?
Just curious, i have two dark green c elements, but i'm not absoltely sure they are the best choice for P43.
I've got one brighter green C-element, too.
And: http://www.stagelightingstore.com/4490-CalColor-90-Green
Both other numbers end up in finding green filters, too.
Maybe you could check again, please. Seems a good and cheap way to go.
I've got the tubes on the bench anyways and could decide between filtering in front of the tube face inside the glycol or in front of the lens, which is surely possible everytime.
The crazy thing about color filtering is (like i wrote in another thread before):
On my silver screen, the unfiltered colors from the M8500 looked ok, if not perfect.
I've not measured, but compared to how it looked before (white screen, same projector) it was way better.
Grayscale itself wasn't good, little pinkish shiny sh*t, but over all, watching a normal picture or movie, it was great.
Just had to say that...
| Quote: | | Farther from the focal point is better | Yes, i understand it. But what about reflections?
I've texted with Mark (noos), but not about that so far. And now he seems to be gone.
No answer on my PMs in weeks.
And thank you Gary for the Link. Very much what i want, but tell me: Did the projector have P43 or "normal" green phosphor?
Regards, Julian
| Posted: Mon Oct 12, 2015 5:55 pm Post subject: |
| tschaeikaei wrote: | So you say there is two options on green.
Which one would be best for P43 fast phosphor? |
No idea. I've never had a P43 so I don't know how it compares to a normal green.
| Quote: | | Quote: | | Farther from the focal point is better | Yes, i understand it. But what about reflections? |
I don't know how much of a problem it would be. The whole idea of a LC projector is to avoid internal reflections. Gels might add some, might have some impact on contrast ratio? I don't have an LC so I'm just guessing. You'd have to experiment and see if you like it.
tschaeikaei
| Posted: Wed Oct 14, 2015 9:32 pm Post subject: |
As i'm changing glycol in the 1209s tubes ... is it really necessary to remove the C-element for filling it?
I can't believe it... what are the fill screws for? Worst is: I've already drained and refilled two of them, but can't get the air bubbles out.
Regards, Julian
| Posted: Fri Oct 16, 2015 4:56 pm Post subject: |
I have measured clear, G90 light green celements, and dark green celements on P43. By for the best for REC709 is the dark green celement. It moves green much closer and away from yellow. That said, even with the dark green celement, the P43 is still quite under saturated while the standard green phosphor is almost perfect for REC709 with dark green.
Furthermore, the dark green celement cuts the already diminished light output from P43 phosphor by a lot. It cuts more light than on standard green phosphor because the P43 has less of the green that can pass through the dark green celement. So with the dark green celement you get the best color, but the tube gets rather dim.
If I were going to permanently install a P43 in my own system I would most likely use the G90 light green celement as a compromise. But I would always be unhappy with the color too. It's a compromise and personal preference will by the key factor here.
| Posted: Fri Oct 16, 2015 4:59 pm Post subject: |
https://www.curtpalme.com/forum_archived/viewtopic.php@t=25790.html
With my spectroradiometer (lab grade) the green was not as good as the graph, but you get the idea. The GetragMacBeth Eye-One has it's worst acuracy on green so...
| Posted: Fri Oct 23, 2015 12:51 pm Post subject: |
I have a thought about tinting a clear C element. I'd suggest picking up the small diameter C elements out of an old CRT rear projection TV set for practice before committing a useful C element to the experiment.
You've heard of water transfer/dipped finishes, by now, I'm sure.
Suppose you were to do this in transparent red or green lacquer.
It should give a uniform film thickness. Or fairly uniform, in any event.
It'd be worth experimenting but I can't guarantee satisfactory results. Tint uniformity is pretty critical.
aspec2
| Posted: Sat Oct 24, 2015 12:17 am Post subject: |
I remember the color filter threads on Avsforum..KBK said we should be using Dichroic glass filters. I bought a red and tried it. Cost me $65.00 and was worthless. Big bright spot in the middle and dim around the edges. I sent it to KBK and never heard back. I ended up with KennyG's suggested filters. It was easy to ignore the slight focus issues and enjoy the better color. I think the green was a Rosco 4460 but I forget what the red was. The green was a compromise between color and light output the 4490 was a better green the 4460 allowed more light. Wow...that was probably 13 years ago and I can't remember what I had for lunch yesterday.
Walt
