P19LCP tubes in a new marquee9500 with new type neckboards
koldby
TV/Projector: GJAKY modded VDC marquee 9500lc ultra
Posted: Thu Jul 23, 2015 6:24 pm    Post subject:
barclay66 wrote:
Using reference measurements could be a suitable way indeed. What could be used too is testing with different video input levels in order to see how the I-sense output on the neck boards behaves and when the over-I signal kicks in.
I'm quite convinced that the different beam current control circuit is responsible for the lower contrast and brightness level...
Regards,
barclay66
In other words - no need to change the spotkill circuit...?
Why, do you think, did they change the beam current control?
The main circuit is more or less the same as the old one , except they had to change the Motorola transistors, as they were no longer available.
What is home theater without good sound?
Posted: Thu Jul 23, 2015 7:15 pm    Post subject:
There IS information on over-I and I-sense signals, but strange enough they are listed in the VIM's section.
As I am tayloring the VNB in to my NEC, I'm quite up to date in the construction of the VNB Smile
Generally the brightness of the circuit can be set with the ofset of either Q12, Q19 (it driven through Q12 here), ideally the over-I or I-sense should not affect brightness, a different bias/gain setting of the brightness circuit probably would solve that part of the problem.
 Filesize:  147.67 KB
 Viewed:  6545 Time(s)
barclay66
Posted: Thu Jul 23, 2015 8:35 pm    Post subject:
Thanks!
This data will help. Interesting to see that there is indeed a different setting of the potentiometer between the 8" and the 9" neck boards although they share exactly the same schematic...
Regards,
barclay66
koldby
Posted: Thu Jul 23, 2015 10:40 pm    Post subject:
Maybe also a difference between the i-max for LUG tubes and LCP tubes?
koldby
Posted: Fri Jul 24, 2015 10:05 am    Post subject:
barclay66 wrote:
koldby wrote:
By the way what is your opinion of the new NB. Better or worse than the old style?
I have the ones that have 81771-01/02 as part number.
Regarding bandwith they seem to be OK, maybe slightly better than the original ones. But the change they made on the spotkill circuit seems to have a negative effect. The picture is darker and maximum contrast is reduced too. I'm in the process of modifying this to using the schematic of the 02-270340-01 variant where this section is equivalent to the older circuit. Still not finished...
Regards,
barclay66
Why do you think 02-270340-01 is much different from 81771?
As I see it the main difference is not in the i-sense over-i circuit. Both are almost indentical to the old VNB. Perhaps a matter of different settings of the over-i but the way it works is the same, as far as I can see.
There are much bigger differences in the brightness control circuit between the new and old VNB. The new VNBīs are identical (save for the spotkill transistor) here but there are lots of differences in the old VNB. Could that make a difference?
barclay66
Posted: Fri Jul 24, 2015 11:07 am    Post subject:
You might want to look up this thread: http://www.avsforum.com/t/1127826/vdc-8-highres-projector#post_16022468
Here Scott explains the following:
"The schematic. 81771-01 is part number. This card is not compatible with original Electrohome style cards. P/N 02-270340-01 is new version but can be mixed with E-home cards."
And later:
"The 81771 cards won't work with the originals because when spotkill is enabled the transistors on the original cards will not allow the voltage to go higher than about +0.7 or 0.8V. That will not go high enough to kick in spotkill on the 81771 cards.
Spotkill has been a problem with different configurations because of the small difference between enabled and not. The 81771 takes more than +1V to kick in spotkill which allows more noise and crap without false enabling.
The 02-270340-01 card has the same thresholds as original Electrohome cards so spotkill works."
This is where my idea of functional similarity between an old style card and a 02-270340-01 comes from...
Regards,
barclay66
koldby
Posted: Fri Jul 24, 2015 1:00 pm    Post subject:
I remember now that I actually read that thread.
But if I read Scott correct he is saying that with the new VNB the spotkill will no have so many false trigering as the old, so if you have the new versions in the rest of the PJ, you will only benefit from this.
Problem is with older PJīs that the spotkill will not work at all...!
But I cannot see it would have any influence on brightnes and contrast???
koldby
Posted: Fri Jul 24, 2015 1:28 pm    Post subject:
By the way have you noticed that VDC placed a footprint for a better connection to VIM?
About time... Mini jacks for HighEnd Video signals is not a good idea IMHO!
barclay66
Posted: Fri Jul 24, 2015 1:55 pm    Post subject:
Well,
This were only my observations. Maybe YOu will get a different result when trying out Yours...
barclay66
Posted: Fri Jul 24, 2015 2:09 pm    Post subject:
Yep,
They prepared the neck boards for using SMB-Connectors. The part that would go there is like the one visible in the picture. Unfortunately they didn't get around redesigning the VIM too...
Regards,
barclay66
 Filesize:  10.06 KB
 Viewed:  6471 Time(s)
koldby
Posted: Fri Jul 24, 2015 3:06 pm    Post subject:
No but I am about to change the VIM to a MCX 75 Ohm.
I think it is the same footprint as SMB connector.
Posted: Fri Jul 24, 2015 5:46 pm    Post subject:
The input circuit is also different from the old style, that circuit have influence both on contrast (=gain of opamp) and brightness (=bias of opamp).
koldby
Posted: Fri Jul 24, 2015 8:55 pm    Post subject:
So what would you suggest?
Posted: Sat Jul 25, 2015 6:27 am    Post subject:
This is also just a theory, needs verification.
For example you should do these test steps attached below on the new style neckboards for comparison.
EDIT:
As I see the new board will give quite different readings... U5 in the new design isn't biased in either way, so with gorunded input it will have 0V on its output. Assuming there no voltage drop across R6, Q2's base is at 0V as well, Q2 being PNP its emitter is 0.6V above it's base, so with 0V input on J3, Q19's base is at roughly +0.6V. While with the old style neckboard it was at -0.8V, that is quite a difference and this have to be canceled out from the Q12's side to get the same output bias levels.
 Filesize:  66.27 KB
 Viewed:  6420 Time(s)
koldby
Posted: Sat Jul 25, 2015 12:47 pm    Post subject:
EDIT:
I think I have to make a test jig for the VNB.
I have a Sqwave generator with adjustable chrest factor. And i have couple of LVPS to power it.
What I need to know is what is the Voltage @"brite" input with normal brightness?
Other suggestions?
Posted: Sat Jul 25, 2015 1:14 pm    Post subject:
Other suggestions?
The manual suggest to apply -2V at U1 pin7 for testing (for old style VNB). With this and with 0V input the output K and G1 should rest around +/-78V *EDIT* respectively.
koldby
Posted: Sat Jul 25, 2015 1:45 pm    Post subject:
koldby
Posted: Sat Jul 25, 2015 1:53 pm    Post subject:
Unfortunately it is not directly traslateable to the new VNB
Posted: Sat Jul 25, 2015 2:08 pm    Post subject:
Yes, I know Razz
-2V at U1 pin 7 roughly means -1.4V at Q12's base, what you can translate then.
In fact the brightness has little impartance, I just pointed out that after changing from old style VNB to new style the G2/Drive settings have to be re set.
koldby
Posted: Sat Jul 25, 2015 3:07 pm    Post subject:
As the output stage in new and old VNB is very similar (except for the transistors used, one could probably translate the -1,4 to " Q12 to the same in the new VNB.
I donīt think it is just a matter of adjusting G2/Drive. Aparently the outputstage has some issues in linearity and dynamic range.
A couple of questions:
Why did they change the inputstage to HFA1100 and an emmitterfolower? Is the Z-in of 2SC4271 much lower than MRF5943?
Why did they change the I-sense/Over-I stage?
Why did they change the Brightnes driver and spotkill?
VDC had supposedly only simulator customers as their goal, and that calls for LUG tubes. Did they make the changes to be better with very hard driven LUG tubes , beside the fackt that they couldnīt get more Motorola transistors?
Speculations from my side
Page 2 of 3
