ElTopo
| Posted: Sun Jul 05, 2015 7:59 am Post subject: |
1600 would give me 1.25 and not 1.33
The tube face is 4:3 as i know ?!
| Posted: Sun Jul 05, 2015 8:09 am Post subject: |
1920x800 is 2.40:1, 1920x818 is 2.35:1, and 1536 is less than double both of those numbers, so youll be scaling down from UHD or cutting bits off, making it a near pointless exersice.
haireez
| Posted: Mon Jul 06, 2015 8:47 am Post subject: |
But why add that?
noos@xp37+
Joined: 17 Jun 2008 Posts: 464 Location: Berlin/Munich
| Posted: Wed Aug 05, 2015 5:36 pm Post subject: |
Gentleman,
when I have time in winter, I will set up a PC based 4K Interlacer and 3D format converter. I did the same a while ago for the fist Oculus Rift. As you can see from the videos , I also was able to convert in "real time" 3d framepacked and protected outputs via products known to us here - to the format need by the Oculus Rift. I did shorten the description a while ago.
http://www.mtbs3d.com/phpBB/viewtopic.php?f=140&t=18494
The logic now is to use one 4k source and run it into a PC that is equipped with a 4k capture card. As you know from the past, the HDCP problem is solvable. The PC capturing the 4k input does preview in real time with super low latency. The preview resolution can be altered in the graphic card menu on the capture PC. So when using old 7xxx series GPUs for interlacing ( like I identified in the past) in the capture PC – you will be able to interlace all inputs. You will also be able to input high end gaming sources, and interlace them with low latency in the capture/playback PC.
I will do this in winter, but maybe someone wants to do it before me.
Regards
Marc
