Finally my Barco CineMax
Goto page 1, 2, 3  Next
Decibel
Posted: Mon Jun 22, 2015 12:21 pm    Post subject: Finally my Barco CineMax
I finally bought the projector of my dreams. It's a Barco Cinemax.
Currently not working. The symptoms are describe below.
- All tubes show a very low light output. The blue tube show a noise and light more intense than others but no menu appear on the screen.
- Red led lit on vertical and rgb input boards.
- No backlight on fixed remote control.
I think that quadrupler and EHT board are good, otherwise tubes would not show anything.
No red led on EHT board.
Here some pictures.
Low light output, blue tube.
G2 board
RGB board
Vertical board.
Any suggestions?
Domenico (Barco fan!)
winny
Posted: Mon Jun 22, 2015 1:27 pm    Post subject:
Have you tried a known good source? Just in case the on-screen generation of menues are broken but not the video chain. Unlikley but should be easy to test.
Melifluonze wrote:
Decibel
Posted: Mon Jun 22, 2015 2:10 pm    Post subject:
Thank you winny, tomorrow I'll try to connect a source.
Other strange things that I just checked.
- the center back fan no turn. It's normal?
- from R7627195 RGB input board there's a free yellow multiwire. I must connect this cable somewhere?
barclay66
Posted: Mon Jun 22, 2015 2:40 pm    Post subject:
There shouldn't be any cable left unconnected. Check the document and see where it should be plugged in (check the connector numbers)...
Regards,
barclay66
R7627195_02_Connections.pdf
 Filename:  R7627195_02_Connections.pdf
 Filesize:  102.94 KB
 Downloaded:  555 Time(s)
Decibel
Posted: Mon Jun 22, 2015 3:34 pm    Post subject:
Thank you Barclay.
Connector J7 (from controller) actually is unconnected.
There's a connector on the motherboard between slots of RGB input and Driver boards labeled "to rgb input+switching board".
So definitely the unconnected cable must to connect from motherboard to R7627195.
Do you agree?
Tonight, when I back home I'll try to connect the cable.
barclay66
Posted: Mon Jun 22, 2015 3:57 pm    Post subject:
Well,
A missing connection at J7 would explain everything about the menus You can't see -> Missing video signal from controller. You better check for more cables being unconnected...
Regards,
barclay66
Hulio
Posted: Mon Jun 22, 2015 4:20 pm    Post subject:
Yepp, J7 should be connected with J129 on the mainboard.
Don't worry about the horizontal deflection fan. It is temperature controlled by a thermistor in the SMPS sub-board. Will start spinning when things are getting hot.
Congrats with the nice machine.
Decibel
Posted: Mon Jun 22, 2015 4:37 pm    Post subject:
Thank you Hulio 😉
ElTopo
Posted: Mon Jun 22, 2015 5:47 pm    Post subject:
Hey,
congrats to the most beautiful projector out there Thumbs Up
What year ? Runtime ?
cheers
Barco Cine 9 the one and only
ElTopo
Posted: Mon Jun 22, 2015 5:52 pm    Post subject:
Difficult to say what is Bad.
On mine i replaced
Quad + EHT + horizontal + temp sensor board
Decibel
Posted: Mon Jun 22, 2015 6:10 pm    Post subject:
ElTopo wrote:
Hey,
cheers
Very Happy
 Filesize:  47.12 KB
 Viewed:  10230 Time(s)
ElTopo
Posted: Mon Jun 22, 2015 6:37 pm    Post subject:
A CineMax in a Reality 909 case ?
Decibel
Posted: Mon Jun 22, 2015 6:41 pm    Post subject:
The top cover is blue like Reality.
 Filesize:  497.17 KB
 Viewed:  10220 Time(s)
Decibel
Posted: Mon Jun 22, 2015 6:42 pm    Post subject:
Lenses HFQ900
winny
Posted: Mon Jun 22, 2015 6:44 pm    Post subject:
You suck is usually reserved for when you get something for free or too cheap but...
Melifluonze wrote:
ElTopo
Posted: Mon Jun 22, 2015 7:00 pm    Post subject:
This need a repainting either to blue again or silver Mr. Green
But first it has to be up again Cool
Decibel
Posted: Mon Jun 22, 2015 7:04 pm    Post subject:
It will be totally black Thumbs Up
Posted: Mon Jun 22, 2015 8:42 pm    Post subject:
Like this??:
Decibel
Posted: Mon Jun 22, 2015 8:50 pm    Post subject:
CasetheCorvetteman wrote:
Like this??:
YEEEEEEEESSSSSS
Mr. Green Thumbs Up
ElTopo
Posted: Mon Jun 22, 2015 9:38 pm    Post subject:
Mine is dark blue glossy.
Page 1 of 3
