What does this extra board do? 909/Cine 9
Posted: Thu Apr 09, 2015 10:48 am    Post subject:
Its an R9240014, april 2005, BF909 EXT PFC.
Hulio
Posted: Thu Apr 09, 2015 5:37 pm    Post subject:
Case, don't you mean FR909 instead of BF909 ? (FR stands for fast refresh, usualy PT22 green tube)
Posted: Fri Apr 10, 2015 12:03 am    Post subject:
No, it is what i said it was.
The green fitted to it was a standard P19LUG.
Posted: Fri Apr 10, 2015 2:47 am    Post subject:
R9240014 = Barco Reality 909 CRT Projector with HFQ900 lens
I am going to take a stab at saying that the board you displayed is part of the contrast modulation system. I haven't seen anything like it but Barco and other CRT manufacturers did all sorts of custom builds for their customers particularly when you consider how these projectors were used.
Posted: Fri Apr 10, 2015 7:58 am    Post subject:
Yep, thats what the set is Keith, although it doesnt have any other add in boards that i can see in there apart from those two ive posted here.
donaldk
Posted: Mon Apr 27, 2015 2:31 am    Post subject:
barco r762268t
www.curtpalme.com/forum/viewtopic.php?p=188845
page 5 of http://www.barco.com/tde/(2552531702302320)/R5975385/05/Barco_InstallationManual_R5975385_05__Orbiting-Kit.pdf
Posted: Mon Apr 27, 2015 2:34 am    Post subject:
Its not an Orbit or HDTV board.
donaldk
Posted: Mon Apr 27, 2015 2:41 am    Post subject:
No, it says ORBIT beside the connector where you connect the orbit board Wink
Part number can be seen in the pic Keith, its on the sticker there.
There is also another small board in that set, its in with the tubes and connects to the neck boards. No idea what that does either.
It says TO ORBIT TO SUB, so as KM says it isn't the orbit board itself, nor is it the BD801 HDTV interface board, eventhough it is labelled as r762268t, and online sources like the barco manual says is just that.
Posted: Sun Feb 12, 2017 1:46 am    Post subject:
Here is the pic:
Case
Did you ever find out what this board was for.
Hulio
Posted: Sun Feb 12, 2017 7:30 am    Post subject:
This is called ABL controller and will work with newer-style neckboards only (they have an extra connector for this).
Here the sparepats list, including this board.
BR909_spares_matrix_~_(ref._TDE1320_03).pdf
 Filename:  BR909_spares_matrix_~_(ref._TDE1320_03).pdf
 Filesize:  10.38 KB
 Downloaded:  757 Time(s)
