Ampro 3600 of course errors
Goto page Previous  1, 2, 3, 4, 5, 6 ... 12, 13, 14  Next
Luuk neele
Posted: Wed Mar 11, 2015 10:05 pm    Post subject:
macgyver655 wrote:
Please do not turn the power on any more until you are told. Remove that power cord and give it to a responsible person. Smile
possibility of damaging something i presume?
i removed the powercord and unplugged everything.
Posted: Wed Mar 11, 2015 10:07 pm    Post subject:
The +40v line looks ok but the -20v line is shorted. So start removing or disconnecting boards, starting where ever you saw smoke and test that -20v line upon each removal until that 0 reading comes up.
Luuk neele
Posted: Wed Mar 11, 2015 10:11 pm    Post subject:
I presume without turning the projector on right? Just with ac connected and the switch on the back in the on position?
I'll flip the switch whenever I take a board out
Luuk neele
Posted: Wed Mar 11, 2015 10:12 pm    Post subject:
The reading if the - 20v line should be 0?
Luuk neele
Posted: Wed Mar 11, 2015 10:23 pm    Post subject:
i removed the rgb board , this resulted in a reading of .454 with AC connected but projector not powered up.
Luuk neele
Posted: Wed Mar 11, 2015 10:31 pm    Post subject:
Took out the rgb board.
A resistor seems to have been replaced.
Shoddy work.
 Filesize:  212.75 KB
 Viewed:  3687 Time(s)
 Filename:  2015-03-11 23.30.24.jpg
 Filesize:  322.14 KB
 Downloaded:  241 Time(s)
Luuk neele
Posted: Wed Mar 11, 2015 11:03 pm    Post subject:
Aha, ic8 on the rgb card
 Filesize:  263.85 KB
 Viewed:  3680 Time(s)
Posted: Wed Mar 11, 2015 11:23 pm    Post subject:
Let me say this one more time. Remove that power cord from that projector and put it off to the side. I am not going to be responsible for your death, UNDERSTAND?
If you do it again before you are told I will no longer assist you.
Luuk neele
Posted: Wed Mar 11, 2015 11:32 pm    Post subject:
Allright, I am sorry. I appreciate your concern, won't be so stupid.
Everything is powered off and disconnected, I get .433 without the rgb card in its slot, and I get 0 if I plug it back in its slot
All is done WITHOUT POWERCORD Wink
See previous post, I went a little further and measured the ic.
It appears to short at several pins. Is this how it's supposed to behave? Because the same ic is at the left side of the board and thus one doesn't behave like that.
Posted: Wed Mar 11, 2015 11:35 pm    Post subject:
Forget that ic. That thing you call a resistor is really a transistor, a regulator to be specific. I need you to test it with your DMM on diode scale. Just test across different legs and give me the readings.
You do know NO POWER for diode and resistance testing, correct?
Luuk neele
Posted: Wed Mar 11, 2015 11:52 pm    Post subject:
Took rgb card out.
Tried to test the regulator
It came off the board.
Tested it anyway.
 Filesize:  132.58 KB
 Viewed:  3657 Time(s)
Luuk neele
Posted: Wed Mar 11, 2015 11:53 pm    Post subject:
Just to reassure you. There is no powercord anywhere.
Posted: Wed Mar 11, 2015 11:58 pm    Post subject:
Leave that regulator out and put the board back in the projector and see if you still show a short.
Luuk neele
Posted: Wed Mar 11, 2015 11:59 pm    Post subject:
Yup, still a short. Still reads 0 with the board in.
Posted: Thu Mar 12, 2015 12:12 am    Post subject:
Take the board back out. Verify that regulator id on the board is ic20, which it should be. If it is, then locate C84 in that board. Should be right near that reg.. Do a diode test across it and give me the readings.
Posted: Thu Mar 12, 2015 12:22 am    Post subject:
Looks really bad, looks like there might be a solder bridge on between one of those pads. clean that up in between there with a tooth brush and some denatured alcohol. so you can see clearly if there is in fact a short there.
Luuk neele
Posted: Thu Mar 12, 2015 12:26 am    Post subject:
Cleaned the pads, no bridge. Still a short. I'll do the diode test tomorrow. Thanks so far everyone. Smile
Luuk neele
Posted: Thu Mar 12, 2015 8:37 pm    Post subject:
diode reads 0, and in continuity mode the meter goes "beep" so its a short
Posted: Thu Mar 12, 2015 8:44 pm    Post subject:
You verified it is ic20 that is removed? And you are testing on capacitor C84?
Luuk neele
Posted: Thu Mar 12, 2015 9:00 pm    Post subject:
yes, i removed ic20. (the one that came off the board) and i verified that the cap i tested is c84. it reads: "0"
Page 5 of 14
