Luuk neele
Joined: 04 Mar 2015 Posts: 186 Location: Wijk bij duurstede, the Netherlands.
| Posted: Wed Mar 18, 2015 10:07 pm Post subject: |
| mac wrote: | Wonderful
Try this. Have the main power toggle switch on but do not start the projector.
Press "808" then "KEY"
Tell me what the lcd says. |
using rom defaults
mac
| Posted: Wed Mar 18, 2015 10:18 pm Post subject: |
Damn. Might of lost the CPU from the battery failure.
One more try.
Again, main switch on but not running.
Press "808" and then press "code"
Hopefully the readout says main menu.
if it does then press "1"
Should read "baud rate = 9600
If not 9600 press 1 or 2 to adjust until reads 9600
Then press "3" for main menu
Then press "3" should ask "store changes ?"
Press "1" to accept
Press "3" to exit
Then turn off main toggle.
Then try restart and see what we got.
if all this does not work the we may be in trouble.
Luuk neele
| Posted: Wed Mar 18, 2015 10:22 pm Post subject: |
your advice worked though, i got all the options
i turn it on, i press "test" nothing happens
mac
| Posted: Wed Mar 18, 2015 10:24 pm Post subject: |
Ok, try this.
Press "30" then "code"
What do you get?
Luuk neele
| Posted: Wed Mar 18, 2015 10:28 pm Post subject: |
while its off: nothing
while its on: just switches to channel 3
mac
| Posted: Wed Mar 18, 2015 10:30 pm Post subject: |
This is while projector is running.
Press "31" then "code"
What does lcd read?
Luuk neele
| Posted: Wed Mar 18, 2015 10:37 pm Post subject: |
it doesnt respond to codes while its on it seems.
might it be in some sort of lockout mode for the various functions?
Luuk neele
| Posted: Wed Mar 18, 2015 10:43 pm Post subject: |
am i being and idiot? does the system not need an active input to even start displaying?
mac
| Posted: Wed Mar 18, 2015 10:44 pm Post subject: |
Try pressing "909" then "code"
LCD should read "disable executive mode"
If success again try "31" then "code"
mac
| Posted: Wed Mar 18, 2015 10:46 pm Post subject: |
| Luuk neele wrote: | | am i being and idiot? does the system not need an active input to even start displaying? |
No.
Luuk neele
| Posted: Wed Mar 18, 2015 10:51 pm Post subject: |
exec mode was on, it shows elapsed time.
when i do a self test by using code 30, it goes: vert sweep fail, no horz clam, grid 2 lo
| Posted: Wed Mar 18, 2015 10:53 pm Post subject: |
| Luuk neele wrote: | exec mode was on, it shows elapsed time.
when i do a self test by using code 30, it goes: vert sweep fail, no horz clam, grid 2 lo |
Code 30 or 31?
mac
| Posted: Wed Mar 18, 2015 10:54 pm Post subject: |
How many hours does it show? 31 code
The only thing there that concerns me is the vert sweep fail. The other 2 are normal.
At least we are making progress and the CPU board seems ok now.
Luuk neele
| Posted: Wed Mar 18, 2015 10:56 pm Post subject: |
time shows: 00004:09:39
mac
| Posted: Wed Mar 18, 2015 11:04 pm Post subject: |
The board at the bottom middle of the projector with 2 cards sticking up are the sweep reversal cards. Check harnesses from there to the vert board and the deflection yolks and check upright cards for correct orientation. Do all this with projector unplugged.
Luuk neele
| Posted: Wed Mar 18, 2015 11:16 pm Post subject: |
nothing wrong with the orientation of the cards and the wiring harnesses
mac
| Posted: Wed Mar 18, 2015 11:23 pm Post subject: |
Try turning it back on and do a "55" "code"
Should say registration on or off. Then try a restart and then a "30" "code" and see if vert sweep is still fail.
if still fail, shut it down, hook up a source, have the source running and start projector.
I doubt this will matter but no harm in trying.
If still says vert fail try a "89" "code"
Should say flyback narrow
Restart and try "30'" "code" again.
We may be going no where here but might as well rule everything else out.
mac
| Posted: Wed Mar 18, 2015 11:25 pm Post subject: |
Oh, If all this does not work, shut it down and pull the vert board and look for any bent pins on any connectors.
Luuk neele
| Posted: Wed Mar 18, 2015 11:39 pm Post subject: |
its still telling me that i have a sweep faillur.
do you mean the yoke interconnect board? or the vertical deflection board? the latter seems nothign wrong with it.
mac
| Posted: Wed Mar 18, 2015 11:45 pm Post subject: |
I meant check for bent pins on the vert board.
But before you do that, shut it down and on the CPU board set that last switch that is on, to off, so all switches are off. Restart it and I want you to tell me which red leds on the cpu board are on and which ones are blinking. Then check for vert sweep failure again.
