Ampro 3600 of course errors
Goto page Previous  1, 2, 3 ... 7, 8, 9 ... 12, 13, 14  Next
Luuk neele
Posted: Wed Mar 18, 2015 8:09 pm    Post subject:
Hey Luke !!!
Look at this!! I think you should get it and fast!!!!
https://www.curtpalme.com/forum_archived/viewtopic.php@t=37707.html
it's free yes,
but also 775 kilometres away from me Smile it's in denmark, i am in the netherlands Razz
Posted: Wed Mar 18, 2015 8:14 pm    Post subject:
Luuk neele wrote:
Hey Luke !!!
it's free yes,
I drove that far for a Sony G90 and paid money for the PJ, thats nothing!! A nice week end drive and you get parts for your 3600.
Luuk neele
Posted: Wed Mar 18, 2015 8:16 pm    Post subject:
Luuk neele wrote:
Hey Luke !!!
it's free yes,
that's true, i probably own one of the few 3600's in my country.
the wife would not be amused though, she's already pissed that this one doesnt work lol.
and because of teh fact that it's so huge Razz
mac
Posted: Wed Mar 18, 2015 8:17 pm    Post subject:
Ok, good.
So here is what I want you to do. When you start it up I want you to watch for a few things and be prepared to turn off the projector with the main toggle switch if anything is wrong. Do not wait for it to shut down itself. If it is not right, shut it down instantly.
So power it on and:
1)See if all the fans you can see start up.
2) See if all the green leds are lit on the power supply and are of the same brightness. Do not worry about any other leds anywhere else..
3) Watch for smoke anywhere.
4) Listen for constant arcing. Ignore any occasional minor arc sound.
If everything here seems ok then I want you to just put the remote down and let it run for 20 minutes to a half hour. Don't push any buttons, don't make any tests, nothing. Just let it run, even if there is nothing coming out of the tubes.
Let me know how the startup goes and if it is running.
mac
Posted: Wed Mar 18, 2015 8:19 pm    Post subject:
Luuk neele wrote:
Hey Luke !!!
it's free yes,
4200 parts do not work in 3600 series.
Posted: Wed Mar 18, 2015 8:21 pm    Post subject:
None of them?
mac
Posted: Wed Mar 18, 2015 8:37 pm    Post subject:
I am pretty sure none. Maybe neck board but even if they did they were an earlier version that had some problems. Even the 4300 to 4600 had some boards that were not interchangeable and these 2 are in the same family.
The 4200 was a family of its own.
Luuk neele
Posted: Wed Mar 18, 2015 9:04 pm    Post subject:
mac wrote:
Ok, good.
So power it on and:
1) All fans work!
2) all green leds on psu on, also the small red one on the back of the psu is on!
3) no smoke, but a cap i soldered onto the rgb card burst, i replaced it checked polarity the cap i put in first had polarity reversed, probably a misprint.
4) no arc sounds, just the occasional sound from the tube
no image though, but thats to be expected, remote shows "no input on channel 1"
lets run for 20 mins.
 Filesize:  136.47 KB
 Viewed:  3522 Time(s)
Luuk neele
Posted: Wed Mar 18, 2015 9:30 pm    Post subject:
mac wrote:
Ok, good.
system has been running for about half an hour now, no visible or audible problems.
whats next?
mac
Posted: Wed Mar 18, 2015 9:31 pm    Post subject:
All looks well. I see all 3 heaters on. So after the 20 minute to half hour run, on the remote press "test 1" and see if you get a grid on all 3 tubes.
Luuk neele
Posted: Wed Mar 18, 2015 9:36 pm    Post subject:
if i press test i see "rgb 1 mode" on remote, if i then press 1 i see "rgb 1 mode channel 1" but no image on tubes
whats wrong?
mac
Posted: Wed Mar 18, 2015 9:40 pm    Post subject:
Try clear first and then the test button.
Luuk neele
Posted: Wed Mar 18, 2015 9:42 pm    Post subject:
nothing happens, i had replaced the battery, that has somethign to do with it?
mac
Posted: Wed Mar 18, 2015 9:45 pm    Post subject:
Shouldn't.
Try pressing "code" then "30" and see what the lcd reads.
Luuk neele
Posted: Wed Mar 18, 2015 9:47 pm    Post subject:
mac wrote:
Shouldn't.
it shows: channel 3 acc = 0
mac
Posted: Wed Mar 18, 2015 9:50 pm    Post subject:
Ok, Shut the projector off and switch off main switch.
On the CPU board check each switch location.
Switch:
1)off
2)off
3)off
4)off
5)on
6)off
7)off
8)off
Luuk neele
Posted: Wed Mar 18, 2015 9:55 pm    Post subject:
Switch:
1)off
2)off
3)off
4)off
5)on
6)off
7)off
8)off
5 was off it is now on, no image
mac
Posted: Wed Mar 18, 2015 9:57 pm    Post subject:
How about the code 30? Are both round switches on the cpu set to "0"?
Luuk neele
Posted: Wed Mar 18, 2015 9:59 pm    Post subject:
code 30 still gives channel 3 acc = 0
the rotational switches are at 0
mac
Posted: Wed Mar 18, 2015 10:04 pm    Post subject:
Wonderful Sad
Try this. Have the main power toggle switch on but do not start the projector.
Press "808" then "KEY"
Tell me what the lcd says.
Page 8 of 14
