Barco Graphics 1209/2 image flashing once every second
Goto page Previous  1, 2, 3
Posted: Wed Apr 15, 2015 1:38 pm    Post subject:
WEll, they are $800, but yes, I've only got 2 left..
winny
Posted: Wed Apr 15, 2015 2:44 pm    Post subject:
It figures they would go quickly.
Any update on that $100 box of useful boards?
Melifluonze wrote:
winny
Posted: Mon May 04, 2015 4:59 pm    Post subject:
Took a chance and swapped my r762700 for an r7621175. They looked compatible. The problem was identical. Sad
Curt, I could really use that 100 $ box of spare cards now...
Melifluonze wrote:
Posted: Mon May 04, 2015 5:16 pm    Post subject:
I am working on some 1209 stuff this week, so let me get them together..
winny
Posted: Mon May 04, 2015 5:18 pm    Post subject:
Yayyyy!
Melifluonze wrote:
winny
Posted: Tue May 19, 2015 4:35 pm    Post subject:
A box arrived today from Curt. Tried to swap the R7621127 and immediate result! No flashing and picture right away. Thumbs Up
However, red is very dim. Full brightness then 1 second fade to dim and stays there until I change something (resolution) where it goes back to bright and then dims down to low again.
The picture in the red tube is not distorted.
Any ideas?
Melifluonze wrote:
Posted: Tue May 19, 2015 6:04 pm    Post subject:
Well, that is one to remember! THe 1127 is the V board. Why it would cause flashing is beyond me.
As for the red, try swapping the CRT cards.
winny
Posted: Tue May 19, 2015 6:59 pm    Post subject:
Could a bad chrimp on the automotive style bullet connectors for what I assume is the glow voltage be the cause? It came off when I tried to swap the boards.
Melifluonze wrote:
Posted: Tue May 19, 2015 7:02 pm    Post subject:
No, that's the ground wire, that's not it.
winny
Posted: Tue May 19, 2015 7:07 pm    Post subject:
Ok. Original neck boards are r762701 and I have some r7621195's laying around which look identical apart from the red wire sticking out of the crt socket. The boards inside look identical. Source for spares/compatible in any way?
Swapping red and green in the meantime.
Melifluonze wrote:
winny
Posted: Tue May 19, 2015 7:20 pm    Post subject:
Same. Perhaps even a litte weaker red. Responds to black cut off and white gain in the menus but still 100 times less bright than green and blue.
Hmm, did I swap back to my old board with no red just to try it and didn't swap back?! Need to search my old thread.
Melifluonze wrote:
winny
Posted: Tue May 19, 2015 7:29 pm    Post subject:
Yup! :facepalm:
It's up and running now and I found some DIPA in the refrigerator to celebrate.
Thanks oce again Curt!
Page 3 of 3
