Marquee DIY Focus Board Mod
Posted: Tue Apr 07, 2015 1:32 pm    Post subject:
Try it.. but before you do. Post a picture here of where you put the inductors in the circuit on the board.
CSX
Posted: Tue Apr 07, 2015 4:28 pm    Post subject:
I'm not at home right now, and a terrible artist, but this is what I did.
This is exactly it without a photograph.
-The black lines on the traces indicate the trace cuts.
 Filesize:  6.83 KB
 Viewed:  9184 Time(s)
CSX
Posted: Tue Apr 07, 2015 10:42 pm    Post subject:
Gonna snap a pic of the mod, then I'll try to work out the convergence.
Damn. I feel like I almost need to buy a chalk line and a laser level to sort this one >..>
CSX
Posted: Wed Apr 08, 2015 12:54 am    Post subject:
Took a quick pic of the work.
I don't think I can converge this....
I think I need to undo this.
 Filesize:  43.02 KB
 Viewed:  9146 Time(s)
Posted: Wed Apr 08, 2015 12:58 am    Post subject:
Yeah, something looks wrong there.
CSX
Posted: Wed Apr 08, 2015 1:08 am    Post subject:
These go across the 24v traces exactly as shown in the pic.
Open to feedback or other.
Mike, Sent you an email as well.
Posted: Wed Apr 08, 2015 1:31 am    Post subject:
make your leads short as possible:
CSX
Posted: Wed Apr 08, 2015 2:18 am    Post subject:
Repaired the right most trace and moved the coil.
Swapped in new coils from the pack as well.
Redid the installation.
 Filesize:  77.71 KB
 Viewed:  9128 Time(s)
CSX
Posted: Wed Apr 08, 2015 2:46 am    Post subject:
A different result has been achieved.
I think I can converge this
 Filesize:  61.36 KB
 Viewed:  9122 Time(s)
CSX
Posted: Wed Apr 08, 2015 3:37 am    Post subject:
Well, after a bit of work, I now have a relatively good starting point.
I still have to really fine tune everything,bit this is gonna be a good start.
I noticed that with this mod on the Cva, the convergence grid is way easier to manipulate, as well.
 Filesize:  26.67 KB
 Viewed:  9113 Time(s)
CxTurbo
Posted: Wed Apr 08, 2015 8:38 pm    Post subject:
I might also have to give the CVA a shot. Still have like 20 of the inductors for the focus board.
After that I am going to try to locate some more inductors to do a mod to the VDM that Barclay had suggested.
Barclay's VDM mod
 Filesize:  83.78 KB
 Viewed:  9072 Time(s)
Paradigm Studio 100's,Studio 20's,CC-690, Paradigm DSP-3400 V1 SUB
Pioneer Elite SC-35 AVR
Pioneer Elite BDP-05FD Bluray
3x Bryston 3B's
URC Complete Control Medius TX-1000 Remote
HTPC (LGA775 Q6600, 8GB DDR2, 7TB Storage) Mediaportal
Lumagen MINI 3D
Moome FULLHD-EXT V2
Audioquest Cable Top to Bottom
9501LC
Posted: Wed Apr 08, 2015 9:34 pm    Post subject:
I've tried something like this before, but forgot the end results. With higher current inductors, maybe the results would would prove very worth while. Let us know..
CxTurbo
Posted: Wed Apr 08, 2015 9:43 pm    Post subject:
Will do once I get around to it I will for sure.
3x Bryston 3B's
Lumagen MINI 3D
Moome FULLHD-EXT V2
9501LC
Posted: Wed Apr 08, 2015 9:47 pm    Post subject:
This (below) is what I have on my Marquee the past few days. It is an addition to the four large inductors
I had someone over yesterday, and we installed a 4 inductor FGM mod only into my Marquee. Hit the static focus... To a few minutes later installed a FGM that had the 4 inductors and the changes shown. I liked the FGM with the changes shown.
In this circuit change, I've disconnected the Temp Compensation circuit. To include, a link from the Static to the Zone focus stages. We also went further to remove the 10K resistor and install the beads on another long leaded 10K resistor. That was done to help strip noise from getting into the Static Amp Driver. There's also a cap replaced from a .03 to a .039. This cap is in line as a filter to ground of the pulse that drives the Static Amp.
CSX
Posted: Wed Apr 08, 2015 10:54 pm    Post subject:
What about changing the amps instead of disabling the circuit? Or is the circuit just so noisy regardless?
I may try this for fun, but still curious.
redfox001
Posted: Sun Apr 12, 2015 10:10 am    Post subject:
Do you have to go back and forward between zone focus now the link is disabled? Will try at least the removal of the 2 resistors.
Posted: Tue Apr 14, 2015 1:48 pm    Post subject:
I'm just getting back to the projector to dial in the focus using this. I'll need to get back to this one, but for sure, the 15K has to go back in.
CSX
Posted: Wed Apr 15, 2015 8:58 pm    Post subject:
Why does the 15K need to go back in?
Posted: Wed Apr 15, 2015 10:10 pm    Post subject:
I'm going to cover all of that and some more, when I get a chance to write it all up. I want to also go over some focusing tips for 1080P as well. But right now, I get to catch up on a few things..
Posted: Fri Apr 17, 2015 11:53 am    Post subject:
I'm still have some catching up to do on some other non related things, before I can really get back to this.
From a fully modified FGM (as shown in the picture) it was reported to me that the focus when the board was tested in my PJ, to have had different results when installed in someone else PJ. I initially thought that my particular Barco 909 was the reason for the difference. But later found out after checking my unit out again (it had not been used), I too found a problem with the static focus. It turns out that the resistors where the Zone and Static (R152, R252, R352) link, needed to go back in. I have put a different value for now, but will look at that later as well.
Removing the 150K for the Temp Comp circuit I believe still to be best. But it's removal causes a difference in the static focus numbers, but that can also be corrected.
So far, the bigger difference noted from these changes is a bright image. Not sure why that's the case, but it's also what has been reported to me from someone who has one of the modified boards in the right Blend setup.
So this weekend I'm hoping to get back to this. And that's when I'll need to define the best central focus point for the static focus, to include look at the other more minor changes that I'd like to see happen.
Page 6 of 7
