Pis of re-tubing my Sony 1252Q
Audio_Geek_00
Posted: Sat Feb 21, 2015 12:55 am    Post subject: Pis of re-tubing my Sony 1252Q
Thought I would share these. Even tough it seemed a bit daunting at first, putting in the new tubes turned out to be a fun project. If the PJ hadn't worked after what I had done then not so fun.
New tubes!
 Filesize:  123.9 KB
 Viewed:  8556 Time(s)
Audio_Geek_00
Posted: Sat Feb 21, 2015 12:57 am    Post subject: Re-tubing
Nice and shiny!
 Filesize:  129.6 KB
 Viewed:  8555 Time(s)
Audio_Geek_00
Posted: Sat Feb 21, 2015 12:59 am    Post subject: re-tube
What a ball buster to get this down without adding more repair work. it was more of a controlled drop than anything.
 Filesize:  109.93 KB
 Viewed:  8554 Time(s)
Audio_Geek_00
Posted: Sat Feb 21, 2015 1:00 am    Post subject: re-tube
No wonder I've been sneezing.
 Filesize:  142.16 KB
 Viewed:  8553 Time(s)
Audio_Geek_00
Posted: Sat Feb 21, 2015 1:03 am    Post subject: re-tube
I have to admit when I took off the covers I got intimidated again. Fortunately the manual shows how to remove what to get out the tubes out. The chassis looks like a nightmare but it is made to be serviced with very few screws need removal (except the video boards and heat sinks).
 Filesize:  150.37 KB
 Viewed:  8551 Time(s)
Audio_Geek_00
Posted: Sat Feb 21, 2015 1:06 am    Post subject: re-tube
I took pictures of everything I would be taking apart so that I had a handy reference. Especially handy when dealing with cables and such. This is the green gun.
 Filesize:  115.87 KB
 Viewed:  8548 Time(s)
Audio_Geek_00
Posted: Sat Feb 21, 2015 1:08 am    Post subject: re-tube
Lenses' out. I should have done this before I took the PJ off of the ceiling. It takes about 35lbs off.
 Filesize:  121.47 KB
 Viewed:  8546 Time(s)
Audio_Geek_00
Posted: Sat Feb 21, 2015 1:10 am    Post subject: re-tube
Getting my nerve up to disconnect the yoke harnesses from the tubes.
 Filesize:  134.37 KB
 Viewed:  8536 Time(s)
Audio_Geek_00
Posted: Sat Feb 21, 2015 1:11 am    Post subject: re-tube
Don't get the colors mixed up.
 Filesize:  107.88 KB
 Viewed:  8535 Time(s)
Audio_Geek_00
Posted: Sat Feb 21, 2015 1:13 am    Post subject: re-tube
They follow the same logic on all three tubes.
 Filesize:  133.59 KB
 Viewed:  8533 Time(s)
Audio_Geek_00
Posted: Sat Feb 21, 2015 1:16 am    Post subject: re-tube
Tubes are out. I got really nervous at this point. I wasn't sure how badly I could screw this up but there looked like a lot of opportunity. I was worried I'd break something trying to remove the yoke assembly. The old tape didn't want to let go. But it is not quite as fragile as I thought and I was able to persuade them to come off.
 Filesize:  113.81 KB
 Viewed:  8531 Time(s)
Audio_Geek_00
Posted: Sat Feb 21, 2015 1:18 am    Post subject: re-tube
Yoke assemblies transferred to the new tubes.
 Filesize:  140.42 KB
Audio_Geek_00
Posted: Sat Feb 21, 2015 1:19 am    Post subject: re-tube
Tube assemblies re-installed.
 Filesize:  161.28 KB
 Viewed:  8529 Time(s)
Audio_Geek_00
Posted: Sat Feb 21, 2015 1:22 am    Post subject: re-tube
Back on the ceiling. Not having the lenses installed help tremendously, although it adds difficulty putting the lenses in.
 Filesize:  130.44 KB
 Viewed:  8528 Time(s)
Audio_Geek_00
Posted: Sat Feb 21, 2015 1:23 am    Post subject: re-tube
Raster adjustment.
 Filesize:  107.99 KB
 Viewed:  8527 Time(s)
Audio_Geek_00
Posted: Sat Feb 21, 2015 1:28 am    Post subject: re-tube
Lenses installed. Now the real fun begins. I used the CRT setup video to go through my PJ. I did OK but feel like it could be better. But overall I'm really happy with the added clarity and brightness. It perked the ole girl up a bit for not much money at all. Consider doing it if you can get a new set of tubes at a good price. It makes a worthwhile difference.
Best
Tim
 Filesize:  113.26 KB
 Viewed:  8525 Time(s)
Posted: Sat Feb 21, 2015 11:46 am    Post subject:
Well done mate, bet its much sharper now Smile
Audio_Geek_00
Posted: Mon Feb 23, 2015 6:28 pm    Post subject:
Yes, much sharper and a bit brighter.
Jeremy112
Posted: Mon Feb 23, 2015 6:58 pm    Post subject:
nice work Thumbs Up
the very first CRT projector I ever worked with and setup was a 1272, had I replaced the tubes as you did, I'm sure it would have looked a lot better. I only paid a $1 for it though so I couldn't complain, it was a really easy to learn projector and fun to use.
Enjoy your new tubes Very Happy
Audio_Geek_00
Posted: Tue Feb 24, 2015 10:52 pm    Post subject: Thanx
1$? Good deal! Yah, as far as these projectors go they are pretty simple.
The only reason I would consider getting rid of this PJ is 4k. The tubes bought me a year or two until more content is available. Someone may get it for quite cheap at that point but until then it will get me through.
