| Posted: Sat Mar 07, 2015 11:14 pm Post subject: |
| CIR Engineering wrote: | | Nashou66 wrote: | Yeah I understand. But if I am going to spend the money for a beta unit and I NEED dual CMS capability , and it is not sure it will be implemented at all I'd have to pass. It would really suck if later they do add it when I could have gotten the beta trade in deal. And I'd only be able to trade one XS towards it( totally understandable).
Keep pushing Jim and Pat for dual CMS capability. I think that a lot of other Lumagen owners would love that. It could do dual duty
for the theater display and the main living display.
And In may that other company I am talking to will release their beta edge blend unit with what they say will have CMS. How much CMS is another question, and I need them to add 1056x800p@72 to the resolution outs. they will not offer user adjustable timings
Just my thoughts.
nashou |
Trouble is that unless someone is using both the projector in the theater room and a living room display at the same time, one CMS running at a time is enough. You can still use multiple CMS's with memory A-D as long as you don't want to use them simultaneously.
If I were you I probably wouldn't be willing to shell out without know for sure about dual CMS's or not.
Thing about a lot of companies is that a CMS can mean just hue and saturation, or 10-point grayscale, or phase and saturation for primaries... a lot of the time a CMS is just some simple HLS controls, not a true RGB CMS (as I am sure you know).
craigr |
Not if say your having a Superbowl party or similar and the theater has the game on and so does the 60 inch plasma in the bar area. Both would need a separate CMS then
Just saying.
| Posted: Sat Mar 07, 2015 11:42 pm Post subject: |
Exactly. If you are using two different displays at the same time than you would want the dual CMS. I'm certainly not denying that!
donaldk
| Posted: Sun Mar 08, 2015 12:14 am Post subject: |
Uh, an FPGA upgrade seems a bit much for in the field. even in a socket an upgrade to the largest FPGA in the world would most likely require a larger socket;-). An upgrade of the software in the field, duh! Field Upgradable Gate Array;-).
donaldk
| Posted: Sun Mar 08, 2015 1:08 am Post subject: |
Nashou I came across several software packages that offer two ramps one youtube clip even showed the gamma, rgb control screen for two ends of the blendzone. So look into those if you are finding the TV-Ones lacking.
