Barco SEOS
gregstv
Posted: Sat May 30, 2015 8:27 am    Post subject:
Another shot.
 Filesize:  189.1 KB
 Viewed:  7194 Time(s)
Posted: Sat May 30, 2015 8:34 am    Post subject:
You have at least an XG 750 which is closer to the PG xtra in bandwidth... Smile
Posted: Sun May 31, 2015 11:36 am    Post subject:
Wow... There is something wrong with the focus there, i cant see any 1:1 at all!!! That could be the HDF2, but id say its more than just that.
gregstv
Posted: Sun May 31, 2015 8:16 pm    Post subject:
Yep its not good.
Put in a blu-ray and the picture was very sharp.
I thought it may of been because I put the test pattern on a dvd-r.
I put the same disk in and checked the Barco and it is very clean and sharp.
It could be the fury. Its the only change in the video chane the 2 projectors.
gregstv
Posted: Mon Jun 01, 2015 12:39 pm    Post subject:
CasetheCorvetteman wrote:
This is what it used to display before:
Can you send me this test pattern please.
Posted: Wed Jun 03, 2015 7:41 am    Post subject:
Yep, when i get on the computer again ill email it to ya Smile
gregstv
Posted: Wed Jun 03, 2015 8:47 am    Post subject:
This is how the new Green and Blue tube turned up. New, still sealed in Barco box with fitting instructions.
 Filesize:  141.53 KB
 Viewed:  7054 Time(s)
 Filesize:  133.26 KB
Posted: Wed Jun 03, 2015 11:02 am    Post subject:
Is your machine a 908 or an 808?
Posted: Wed Jun 03, 2015 5:50 pm    Post subject:
The CRT replacement box says 908, that is 909 electronics mated with 8" tubes. He has SEOS BG808s.
gregstv
Posted: Wed Jun 03, 2015 8:33 pm    Post subject:
I wish it was a 908. I checked before buying and the same tube kit is for the 1208s/2 on the parts list.
As much as the SEOS has some of the better boards it would be a fun project to turn it into a 908.
Anyone have a set of boards. I will need yokes and focus coils as well. The video chane and the vertical board seem to be the same as what's in the 908.
Posted: Wed Jun 03, 2015 8:41 pm    Post subject:
Nah, I don't think so, what IC do you see on the neckboard's heatsink VPH08?
Posted: Thu Jun 04, 2015 12:40 am    Post subject:
I can go one better, ive got a 909...
gregstv
Posted: Thu Jun 04, 2015 12:46 am    Post subject:
I will check. From memory its a vpj08b. They are the 120mhz boards. In the sub manual for the 908 its is 120mhz not 180.
The 908 also had the LC option.
Posted: Thu Jun 04, 2015 6:10 am    Post subject:
The 180Mhz figure is a poor attempt at humour, even for a 909.
gregstv
Posted: Thu Jun 04, 2015 6:55 am    Post subject:
What are you trying to say.
Not bad resolution for an 8inch projector
 Filesize:  70.24 KB
 Viewed:  6967 Time(s)
Posted: Thu Jun 04, 2015 7:35 am    Post subject:
You dont really believe those numbers are accurate or even remotely addressable do you?
Posted: Thu Jun 04, 2015 7:37 am    Post subject:
Ive displayed 2560x1600 on my Cine 9 before, and it wasnt real sharp at all. It is beyond the ability of the set.
gregstv
Posted: Thu Jun 04, 2015 8:12 am    Post subject:
Case, I cant believe you would question the manufactures sales pitch. Laughing
Posted: Thu Jun 04, 2015 8:13 am    Post subject:
Greg, if it was an NEC i wouldnt have to mate Wink
Posted: Thu Jun 04, 2015 8:15 am    Post subject:
The Reality 912 also lists those same specs, and there is a good chance it could sharply address 2560x1600, but 3200x2560 is a bit of a stretch.
Page 7 of 9
