BG808 upgraded vs BG1209s
Posted: Thu Feb 05, 2015 8:59 am    Post subject:
Decibel wrote:
... and lenses Keith
Sure thing Thumbs Up Laughing
Corleone88
Posted: Thu Feb 05, 2015 10:13 am    Post subject:
km987654 wrote:
The real difference in these set are the tubes and LC tanks. The 9 inch LC makes a world of difference. The video path is much the same.
The electronics on the 1209s should fit better than the 808 for HD 1080p@72 signal, isn't it?
Posted: Thu Feb 05, 2015 10:26 am    Post subject:
If you want to push things that far.
Posted: Thu Feb 05, 2015 3:20 pm    Post subject:
Bit of misinformation in this thread. both the 808 and 1209s are rated at 1200 lumens. The image is NOT brighter, and only select cards are the same. Most are different and not interchangeable. The big difference is the video stage (depending on your model of 808, it may be the same), the tube size and LC lenses. Well worth the upgrade. I am getting in about 800Kg of Barco 1209s and parts in, if you need anything...
Corleone88
Posted: Thu Feb 05, 2015 3:49 pm    Post subject:
Thanks Curt
Posted: Thu Feb 05, 2015 3:53 pm    Post subject:
If you have the G808, not the G808s, then the video boards are different too, as is the HV section.
Posted: Thu Feb 05, 2015 3:55 pm    Post subject:
Corleone88
Posted: Thu Feb 05, 2015 5:34 pm    Post subject:
I have the 808 and I can only keep the port3 board modified by Greg Eisemann (with HDMI ports) for my future 1209s.
I will have to sell the others not compatible with the 1209s...
Corleone88
Posted: Thu Feb 05, 2015 7:54 pm    Post subject:
What are the boards most frequently broken on a 1209s? Quad? EHT?
Posted: Thu Feb 05, 2015 10:14 pm    Post subject:
Quadrupler, HV splitter, SMPS, H board
Posted: Fri Feb 06, 2015 7:36 am    Post subject:
Oh Yeah that would be BG808s that has the same video chain. Thats why we have Curt Embarassed
Corleone88
Posted: Tue Feb 10, 2015 3:19 pm    Post subject:
What about the lenses?
What are the best lenses for a 1209s (for a 3m width screen)? I should get the HD-300 with the 1209s, but my BG 808 has HD-144. So which color corrected (Filtered?) ones should I get in order to get the best colours?
