CRT for Retrogaming Mancave
Goto page 1, 2, 3  Next
Bodi79
Posted: Sun Jan 04, 2015 11:42 pm    Post subject: CRT for Retrogaming Mancave
Hey Guys !
I havenīt been posting for ages, just had to much on my plate the last couple of years. (Offtopic i know..sorry)
Anyway i have a question for all you CRT Veterans, i am currently finishing a dedicated Room for Gaming.
I wanna use it mainly for Retro Consoles ~Sega Genesis/CD , Turbogfx 16, Sega Saturn, Philips CD-i and such. All Systems are RGB Capable or i modded them to be.
I ainīt happy with all the scaling done on typical Digital Systems, so my Idea was to use an CRT Projection as an alternative. Donīt wanna put an old CRT TV in the Room. And i would really like a somewhat decent screensize (Room is not that big so it will be around 70-75" Diagonal).
What do you guys think of my idea? Do i need to worry about burn in that much if used in the completly darkened Room?
Or should i maybe choose an RPTV instead as an alternative?
I could get a Barco 808s very cheap, and i really canīt spend the money for an marquee (and even if could atleast currently i canīt find any).
Thanx for any Advice !
Posted: Mon Jan 05, 2015 2:33 am    Post subject:
If it is a dedicated room, then I say go for it. You are talking somewhere in the 65" width area, which any 8" CRT can handle with ease.
Posted: Mon Jan 05, 2015 6:09 am    Post subject:
I have been doing just that with all those said consoles for many years now, i would always steer you toward NECs due to their superior convergence, but an 808 should do fine, provided it doesnt have an issue with the composite sync from some consoles.
I was running on a 125" 5:4 screen with both a PG and then an XG, both were easily bright enough even for light gun games. Burn in has never ever been an issue for me even after many hours of constant Point Blank on the PS1
You wont get perfect scanlines like this on a digital Wink
Bodi79
Posted: Mon Jan 05, 2015 10:00 am    Post subject:
@Spanky Ham
Thanx for the reply, yep the screen size wonīt be that big. So i will opt with an 8" Model.
@CasetheCorvetteman
Thanx for the Pics (and advice), it really was my motivation cause retro consoles without scanlines is an nogo for me.
If you had no burnin issues i will go the CRT Route than , aswell i wonīt have composite sync issues cause every console i own is RGB Capable anyway. (Atleast at the moment)
I would really want an NEC XG but CRTīs became even rarer than a few years back here. (Austria, Europe)
So my options at the moment are very limited. The Barco would be fairly cheap, other than that i could get old 1271 Sonys which i donīt want.
Posted: Mon Jan 05, 2015 12:17 pm    Post subject:
Almost all consoles use composite video as sync or have dedicated composite sync for RGB. The NECs handle it fine, as does a Cine 9, but i can comment on other Barcos.
Posted: Mon Jan 05, 2015 12:20 pm    Post subject:
The Sega Saturn is a perfect example, it uses composite video as it's sync, unless youve got a Japan console that has dedicated composite sync.
The PS1 has no dedicated composite sync.
Bodi79
Posted: Mon Jan 05, 2015 9:58 pm    Post subject:
@CasetheCorvetteman
Sorry , i totally misread your earlier post.
I read Composite Video Output not Composite Sync.
You are offcourse totally right, almost all of the old console use Composite Sync.
Here in Europe many consoles came with scart leads which were prepared for RGB Output, but always via Csync.
I was aware off that (itīs my job cause i do console repairs and mods) but i just misread.. stupid me Smile
Posted: Tue Jan 06, 2015 7:40 am    Post subject:
(Pops head up )
Did somebody say RETRO gaming on CRT? Mr. Green
I was playing Space Invaders on the D50 just this past week.
Posted: Tue Jan 06, 2015 7:48 am    Post subject:
Yes Jeremy, i was waiting for your arrival Wink
There is not many of us around here, but CRT projectors are certainly the absolute best possible display choice for retro consoles and arcade boards. The arcade boards will connect directly to the RGB input on a CRT projector and sync fine, i add 220ohm resistors to the colour lines though to bring the levels down to something more usable.
I too have done many mods and repairs on consoles, and these days im not aware of any console worth playing that cant be modded to output RGB, there is now a kit available for the N64s and also for the Panasonic 3DO, there is a better mod available for the NES that no longer requires the PPU from a PlayChoice10 as well.
piratepowwow
Posted: Tue Jan 06, 2015 8:02 pm    Post subject:
So if it's an old NTSC broadcast - THESE LINES SUCK, DOUBLE THEM, WAIT....NO...QUADRUPLE THEM!!!! I'll pay you literally thousands of dollars to remove the black lines.
If It's an old video game - MORE BLACK LINES SCOTTIE!
You all deserve to die.
Posted: Wed Jan 07, 2015 6:37 am    Post subject:
The black lines are there for a good reason, my Gen-An close up is 240p, and any retro gamer that sees the NEO•GEO in full swing on my XG is blown away by those perfect scanlines and flawless corner to corner convergence... Its unmatched by even the almighty XM29 direct view CRTs...
piratepowwow
Posted: Wed Jan 07, 2015 6:55 pm    Post subject:
I run all my old consoles through a scaler because it looks better.
Posted: Thu Jan 08, 2015 12:31 am    Post subject:
I have a line doubler with something like 8 inputs I used for this. Just keep in mind that the gun based games won't work through a scaler.
Posted: Thu Jan 08, 2015 4:25 am    Post subject:
Do the world a favour then, sell your old consoles to someone that can appreciate them for what they are and use emulators. Youll be better off.
Edit: ive tried a few scalers for this, and never found a single one to make it look better, not to mension the horrible input lag you add by using a scaler... It makes some games almost totally unplayable. If you use an emulator, you can play without the lag, without the cost, and the image looks even better than a scaler. No serious gamer ever wants to add lag to their controls.
cosaw
Posted: Thu Jan 08, 2015 10:20 am    Post subject:
Was going to ask about scaling and if not using it then presumably the interlacing on 9" tubes means that you've continually got an interlaced field pattern on the tube - specifically with lower resolution consoles (N64 for example mostly ran 256 x 240 PAL). Is there the potential to wear a low res field pattern on the tubes?
Case - did you take that screenshot above of a paused image or moving? Either way, I'm trying to work out what your camera would pickup. Presumably it picks up two interlaced fields at once or could you time it to pickup just one field?
Interesting to hear about, scaling, lag, and light guns. Might pull out my N64 and Gamecube for some liquid smooth F Zero.
Simon
piratepowwow
Posted: Thu Jan 08, 2015 8:45 pm    Post subject:
What about a zero/low lag doubler? Seems to me that could work.
I give it a maybe, without thinking too hard. Gun games don't work on CRT projectors anyway, though I have been thinking about modding my guns with http://www.ebay.com/itm/High-Sensitivity-OPIC-Light-Detector-Sharp-IS489-3pcs/271727626266?_trksid=p2045573.c100033.m2042&_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20131017132637%26meid%3D7a75c3a7657b4e38bdc8863b00066a38%26pid%3D100033%26prg%3D20131017132637%26rk%3D2%26rkt%3D4%26sd%3D181161687558
To see if it will work with the projector.
I have an arcade cabinet with a light gun game designed for 30 khz but works fine at 15 khz as well - Ninja Assault.
Posted: Thu Jan 08, 2015 11:30 pm    Post subject:
Gun games DO work on CRT projectors. You just need a dark room.
Posted: Thu Jan 08, 2015 11:48 pm    Post subject:
Its 240p, as i said above, so there is no interlacing... its progresive scan, as almost every single retro game console ever made pumps out for almost every single game. There is only a handfull of games that have an interlaced output. Absolutely zero on the NEO•GEO do though, theyre ALL 240p
The camera was an iPhone 4S and was taken moving.
Are you kidding me??? Gun games dont work on CRT projectors??? Did you read where it was clearly said they do???
Well what is that image i posted above where it can be CLEARLY seen that my friend there has just shot two targets on Point Blank on what is very obviously a screen far too large to be a direct view set??? Thats a genuine PS1 console with real GunCons on a real CRT projector... And it works PERFECTLY.
You can even see the XG in the picture there... But you still come along and say they dont work???
You were told the guns wont work with scalers, there is NO WAY to make them work. The gun sends a signal to the console the instant it sees the scanning raster pass the point you have the gun aimed at, any lag at all will make that totally inaccurate. It all gets read and decided in just one frame, so adding any lag destroys any chance. If it seems to you it should work, youre missing the knowledge on HOW the consoles know where youre pointing the gun.
Posted: Thu Jan 08, 2015 11:50 pm    Post subject:
I found it rather a bold statement considering i just posted an image showing them working!!
Posted: Fri Jan 09, 2015 12:22 am    Post subject:
I know...Wasn't that Case in the game room with the light gun who dun it? Laughing
Page 1 of 3
