Sony G90 units found locally. Trying to weigh the risk.
Goto page 1, 2, 3, 4, 5, 6, 7, 8, 9  Next
hardisj
Posted: Tue Dec 30, 2014 12:13 am    Post subject: Sony G90 units found locally. Trying to weigh the risk.
Hey, fellas. First time posting here. Actually just signed up now (after a while of dropping around reading) because I really would appreciate some feedback on a potential purchase and I need help from experts on the subject.
There is a fella who is selling a pair of the Sony VPH-G90 projectors. He lives approximately 6 hours from me. I spoke with him on the phone earlier and it boils down to this:
The original owner just went through a divorce and she just wants all her ex's stuff gone. The gentleman selling the PJs is doing so as a favor because his wife is friends with the original owner.
The PJs were used together to project one image in a home theater of two doctors (the original owner and her ex-husband).
He doesn't have the original cords. He didn't think to remove them from the home.
He also doesn't have the remotes.
He does have one of the original ceiling mounts.
Because of the lack of remote, He cannot tell me how many hours are on the tubes of either PJ. He mentioned he will contact the owner and see if she can locate the remotes. He still questioned how he'd find that info because he doesn't have a screen to project on to (showing his inexperience), to which I advised he could just project on to any wall.
He is a businessman in the area (I've done my sleuthing), and seems completely honest in the fact that he really doesn't know what he has nor the details of the items. Other than they worked when he went to take them down. He's just trying to sell them for this lady as a favor.
After explaining my concerns to him (such as the potentially high tube life, the certainty of replacing the Dallas chips, and just general condition) he said he understood and if I could take them off his hands he'd let them go for $1250/pair.
Normally I would have put the car in drive and headed out on down, but the issue of not knowing the bulb life is the major concern. My research indicates a single replacement tube are $1230 from Eisemann Theater (there may be other options I'm not aware of). So, if the bulbs are on the verge of replacement, the cost of replacements would almost bankrupt me! lol.
He did provide cell phone photos and the condition of both looks quite good, cosmetically speaking. Which backs up the story of them being in a personal HT. But I'm still left with the uncertainty of bulb life.
I know I can purchase a remote via eBay. Best case scenario they both have relatively low lamp life and function flawlessly. Given my use is personal HT, I'll still have to buy the HDMI card which is going to run me another $300/each. Then the Dallas chip is $40. I do understand the maintenance required, but if the PQ is there, I'm fine with that aspect.
My question to you guys is simply this:
Given the uncertainty, buying site unseen at $625/each, what would you do? From talking to him, I don't know if he'll be able to source the remotes from the owner to provide me the tube hours. I'm in a bit of a quandary here. Especially considering I was going to original just purchase a new Sony HW40ES digital PJ.
Thanks in advance,
Erin
Posted: Tue Dec 30, 2014 12:30 am    Post subject:
Worst case scenario, they're worth that much in parts value even if the tubes are roasted. I see no down side to buying them at that price. It can only get better if they're not roasted.
hal
Posted: Tue Dec 30, 2014 12:43 am    Post subject:
Here is my take on the Sony G90's....
1) Great unit when it is up and running. However, as these machines age they need to be repaired at great cost..
2) Tube life is important, finding the information to remove the lenses to view the condition is required. It is not a simple bulb change to replace the CRT tube.
3) Like Curt has mentioned, the green tubes on the Sony have wear after 1200 to 1500 hours. You might be looking at a replacement green tube.
4) I own 3 Sony G90's I bought 1 as a parts machine. I have used a lot of the parts keeping two machines running. Infact Curt recently repaired one of my machines (1800 hours). I swapped the PA and PB board only to find that my spare board was toast..
5) The dreaded YA board.
https://www.curtpalme.com/forum_archived/viewtopic.php@t=14696.html
I have a sour taste in my mouth now that I have two LOW hour machines that require monies to upkeep. Tubes are good, but the thought of a YA board crapping out would push me to digital.. Spending $1000 on a surplus YA board only to have it fail a year later makes one think hard about buying the G90's..
6) In hindsight, buying a Barco 909's like the ones that Curt has installed in his stack, with parts being available from Curt. OR building a Marquee with all the mods.
Lastly, Curt has two nice G90's.. If he was to warrant them for "X" amount of time, I'd almost consider that a SAFE bet vs worn green tubes AND possible power supply issues and YA board failures.
Posted: Tue Dec 30, 2014 1:23 am    Post subject:
CJ and Hal pretty much covered the bases, but I'll just add a little to this that I think the other guys missed. I can tell you've done a little reading and research given that you're talking about adding HDMI cards, but since you're referring to "lamp life" and "bulb life", I'm also going to assume you've probably never touched a CRT projector or perhaps even seen a modern one in person. Given that, I'd like to just add a little background.
A single G90 weighs well over 200 pounds and is large enough to take up most, if not the entire back end of most full-size SUVs, so it's not a trivial one-man job to even move one of them, let alone move and mount two in a typical home theater.
Next, to use two of them together in what we call a "stack" configuration and get the most out of them requires exacting precision in layout and mounting, but also time-consuming, methodical setup and occasional maintenance.
A single G90 is relatively tolerable from a noise perspective (fan noise), but two would be pretty obnoxious in anything but a huge room. Most people would want to put them in what we call a "hush box". If you do use a hush box, you'll also need venting to the outside or at least another room in a basement since the two projectors will dissipate several thousand BTUs per hour in heat.
However, for the large investment in time and resources, on a good 10-foot wide screen, a G90 stack will reward you with a reference quality display.
CJ's suggestion that you could part them out if the tubes were shot is a good point, but I'd suggest even that isn't for a novice. Ideally, you'll have some good solid mechanical/engineering background. If you're not afraid to tear an engine down or tear a clothes washer apart down to the bare bones and put it back together, then you'll be fine. Otherwise, I'd stay away.
A G90 (or similar) is the penultimate CRT projector. It's one of three models that most CRT enthusiasts graduate to after years of experience with CRT, and even more reading and research. Most who buy one go into it understanding all the pitfalls they could encounter, such as the boards that can be bad (and expensive to repair), the screws you don't want to remove if you don't want glycol to drain into the projector, the C-elements you can damage if you expose the lenses to direct sunlight, and more.
I'm not trying to discourage you from buying what you want. I just want you to be aware that these beasts are huge, heavy, and are at the opposite end of the spectrum from anything remotely "plug and play".
Cheers,
hardisj
Posted: Tue Dec 30, 2014 1:44 am    Post subject:
argh! dupe!
hardisj
:shame:
hardisj
Posted: Tue Dec 30, 2014 1:46 am    Post subject:
Thanks for the replies, guys.
ecrabb, you are right... I definitely don't have any hands on experience with these kind of beasts or any CRT type device at all other than being a teenager and throwing some in to a dumpster. Laughing
My A/V expertise leans much more to the "A" side. I have a website where I test and review raw speaker drivers (www.medleysmusings.com, /shameless plug), and I am an engineer by title, and I have a strong desire to learn (though, being an 'engineer' makes me no more a CRT-capable-genius than eating a tomato makes me a bottle of Heinz).
As far as the G90 being the cream of the crop and me seemingly jumping in too deep, that really is more coincidence than desire. Given the fact the G90 is, like you said, one of the more sought after units and I managed to find them for a very good price (which is currently up for debate) I figure... why not poll the experts on the matter to see if they think it's worth it to drive down the road. Additionally, when comparing my desires with the capabilities of the CRT, it seems the G90 and it's brethren are where I need to be looking, feature-wise. Again, until today, my plan was to order a digital PJ next week and just go on my merry way. But, the devil on my shoulder said "go ahead, man, look at CRTs" and here I am. :rolleyes:
Just to clarify, I wasn't wanting to run a dual PJ setup. I was only interested in the pair because that's how he wants to sell them. I was thinking IF I purchased them, I'd keep one as a spare or offer it up to someone else who may have a use for it (maybe even Curt?).
I certainly like Plug n' Play in particular situations, but when the opportunity arises to get something for a good price even if it involves a little dirty work... well, I'm always interested in that route. But, the 'challenge' here being unknown, I had to post this thread.
I get the feeling that if one of you guys were in my shoes you'd probably jump in because you know your capabilities and experience level. Your apprehensiveness to suggest I give it a go lies in whether or not I'm capable to make something out of nothing, should these ultimately prove to be 'nothing'. I certainly appreciate that viewpoint. That's the kind of input I was hoping to get from the community. At this point, I know nothing. But, if there's a diamond in the rough, so to speak, then I may pursue it.
I'll sleep on it tonight. I may even just shoot the guy straight and explain that the risk is only worth $x amount to me. If he doesn't see that as a fair deal, I'll continue on the path I was going.
Thanks again for all your help and input, guys. It truly is very much appreciated, and any further feedback on the matter to help further educate me on the pitfalls of potentially buying these would be welcomed.
I also appreciate you not treating a nooB like a nooB. It's always a bummer when you want to learn and get hammered by a bunch of prideful know-it-alls. :/
- Erin
Posted: Tue Dec 30, 2014 2:52 am    Post subject:
You dont need the remote to get into the menu, just use the one built in under the hood. So you can for sure check the hours without the wireless remote.
The G90 ventilators make a lot of noise, and move so much air that if you sit in the draft behind it for some time, you quite sure to get a cold.
You will need to do something about the ventilator noise to use it in a HT.
And if its not in the projector, you will need a Moome HDMI card, if i remember right its around 325$
Ill say that a 1000$ offer for both of them if they look ok and working, would be a fair price these days.
The G90 trows a bright and sharp image, but ill never call it a good HT projector.
Posted: Tue Dec 30, 2014 4:21 am    Post subject:
Lord. OK, then using the same standard(s), which projectors would you call good HT projectors?
Posted: Tue Dec 30, 2014 4:54 am    Post subject:
I am not sure I would buy them even after owning two of them. But that is me and I don't have a dedicated HT.
For the price, you might be fine for the next couple of years which might be good to see how the 4k and laser/led situations plays out.
jarseneau
Posted: Tue Dec 30, 2014 6:06 am    Post subject:
I'll throw my 2 cents in from the perspective of a 5 yr G90 owner and recent buyer of a 2nd...
G90s are well designed and can be extremely reliable. They are mechanically and electrically built like a tank. The only repair needed on my first G90 was the PA board and that failed strictly because I did the SilenX fan mod which allowed the PA board to overheat. I've since found a much better solution which actually runs quieter and cooler as well. I bought the 2nd G90 for $999 and consider that a steal even though its YA board was faulting but was fixed by Craig Rounds so even this problem can be repaired if it did come along so you won't be stuck with an unusable machine.
You should consider replacing the YA board's Dallas chip because the battery is probably at the end of its 10 year life. This is a $50 item to have your Dallas data copied to a new one and the chip is in a socket so it doesn't require special skills to replace.
These projectors throw an outstanding image. The green tube does age fastest but I've run mine past 6500 hours and the red and blue have gone past 12000 hrs and still look decent.
As with any CRT projector, you'll need to do alignment and convergence. The CRT setup guide on this forum will step you through almost every adjustment.
The brackets alone are probably worth $300/ea but be sure to get both the ceiling and projector halves.
Jerry
Posted: Tue Dec 30, 2014 8:09 am    Post subject:
Kurt only prefers his super MP-modded Marquee as good, nothing else. Smile
Posted: Tue Dec 30, 2014 9:42 am    Post subject:
Sorry it was not my intention to cross blades with you G90 experts.
Ill try point out a few things who trow the G90 off. Would be interesting if you 2 would fire up your G90 and see if it do the same, lets try see if we can agree about some of it.
The G90 have quite a lot of streaking.
It adds some very harsh noise to the image.
Standard the ventilator noise is not to live with, it is the most loud CRT i have experienced.
And it has a flat boring washed out image who somehow must related to the very very over done video chain.
I do prefer my moddet Marquee over the G90, and ill also take my old JVC X7 over the G90 any day, as they might both trow about the same boring lifeless image, the JVC at least trows a clean image with better detail level from black to white.
Its no secret that the G90 has some very nice CRT features, it just cant compensate for the overly complex video chain, who seems to distort and wash out the signal.
Jeremy112
Posted: Tue Dec 30, 2014 1:29 pm    Post subject:
I don't suppose that 2nd G90 came from a guy in Neenah? I saw the Craigslist ad for it Laughing
Also, I would like to add to this as well. I have never owned a G90, but I was lucky enough to get to view Jerry's first G90 when I was buying my NEC XG from him.
I can tell you that my friend and I who went to pick the projector up were both quite impressed with the G90. Its bright, throws a nice clear & sharp image. I think I was lucky enough to even see it in operation with the new tubes?
The streaking that strids mentioned... I really don't know what he is saying there, I never saw any streaking during any scene of the Star Wars movie we were watching, and I was looking close at the detail. The only thing I noticed with the picture was the upper left corner wasn't 100% completely converged (but Jerry mentioned that to me as well so it wasn't like he didn't know about it)
I think if you want to get into CRT, and someone has a pair of G90s, and you want to try them out... I say why not? I don't know of any projector that will give you "cheap" operation if its a high end projector... they ALL need to be maintained at some point Wink
I say try it out!! Very Happy
Posted: Tue Dec 30, 2014 2:32 pm    Post subject:
Try an XG. I haven't seen/heard them side-by-side but I suspect the XG is louder.
Another thing to be aware of with the G90's (and the G70's) is that they seem to run the tubes "hot" -- they wear out tubes faster than any other projector I'm aware of. 10,000 hours on Marquee tubes is no big deal. 2000 hours on a G90 and you usually have a toasted green.
But 2 G90's for $1250 (less if you can talk him down Smile), that's pretty tempting. You've got spares in case anything blows.
jarseneau
Posted: Tue Dec 30, 2014 3:52 pm    Post subject:
The 2nd one was off Ebay from an AV place in Mecquon but he said it came from a 'summer house' in Appleton (close to Neenah). The owners were grandparents that installed the G90 with an $18, 000 first mirrored rear projection screen and it was for the kids to use when they were visiting Rolling Eyes The timers showed 4500 hours but you couldn't tell the tubes from new.
Hey Jeremy! When you saw the G90 in 2010, only the GREEN was new. According to the timer, the others had 6000hrs. I only had to replace the GREEN because the previous owner had left the thing on for who knows how long with the text 'Input not available' going.
Jerry
hardisj
Posted: Tue Dec 30, 2014 6:37 pm    Post subject:
I offered the guy a pretty low price on the pair. Based on the feedback here and from Curt, I didn't feel the risk was worth too much. I had the worst case scenario in my head that I get them home and six months later they're dead. The guy didn't seem to like my offer or care for my supporting rationale (ie; YA board potential failure, no idea about tube life, no remote, certainty of replacing at leas the green tubes at $1200/each, certainty of replacing the Dallas chip).
I actually felt good when he said no. Had he said yes, there was still some uncertainty on my part.
Based on the feedback here, I don't expect he'll get what he thinks he should. Not unless an interested party either a) knows exactly what they're getting by testing before they buy or b) have no idea of the pitfalls of these units and the risk involved.
Thanks for the feedback, guys. You've helped me make what I feel is the right decision for me.
Posted: Tue Dec 30, 2014 6:55 pm    Post subject:
hardisj wrote:
certainty of replacing at leas the green tubes at $1200/each, .
if they were side-stacked then almost certainly a trapezoid shaped wear pattern on the green tube, which would not be useable if you were planning to go back to a straight-on throw with a single machine.
Posted: Wed Dec 31, 2014 12:16 am    Post subject:
What a silly discussion. This is a hobby or interest so it doesn't need to make sense financially. Trying to do so is just nonsense.
Buy them and get into it or just do something else.
Posted: Wed Dec 31, 2014 12:38 am    Post subject:
It's not silly at all. There's nothing silly about weighing risk/benefit against your personal budget and tolerance for risk, and/or getting the information to make a more informed decision. What may be right for you may not be right for another. Hobby or not, it absolutely needs to make sense financially. I'm sorry, but saying it's a hobby so it doesn't need to make sense financially is beyond comprehension for me. Just because it's a hobby doesn't mean it all has to be "throw away" money.
That was precisely the exercise the OP went through. Get more information so he could make a go/no-go decision, and consider what how much money he was willing to risk.
Page 1 of 9
